Painting the bottom of a speed boat
Results 1 to 16 of 16
    Apr 2008
    Table View Cape Town
    Thanked: 8
    Default Painting the bottom of a speed boat
    I am fixing up speed boat (Fibre glass) and want to paint the whole hull/boat. How do I treat the bottom before I paint it? What paint do I use? should I use a resin or resin based paint or epoxy paint? advise and tips needed. Regards
    Eric
    Eric
    2017 Discovery Sport SE
    2011 Discovery 4 V8 HSE
    2016 Audi A1 Sportback (Sold)
    2012 Range Rover Evoque (Sold)
    2009 Defender SVX 60th Limited (Sold)
    1997 Discovery V8 ES (Sold)
    2009 Freelander 2 TD4 (Sold)
    2012 Spite Tourer SP
    2010 Jugens XT140 (Sold)
    2008 Jugens Xplorer (Sold)
    Hillcrest, Malaysia
    Thanked: 5717
    We used to use Glatex 8. I am sure there must be better products by now.
    Out of interrest what colour ?
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Apr 2008
    Thanked: 8
    The boat is white at the moment and I want it black. It's a long project / hobby. It will take a long time. I don't want to rush anything , it must be perfect.
    Eric
    Thanked: 260
    Quote Originally Posted by Swanny View Post
    Eric
    I don't know if paint will last ??
    The best would be to apply a layer of black gel-coat... (Black fiberglass resin)... It will bond perfectly and should last !
    2017 Mitsubishi Triton 2.4 D/C 4X4 6 Auto Diesel
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    I've been told to keep hull colors white or light colors , the reasons im not exactly sure but has to do with heat softening (fiberglass resin ) , hull tempreture ,u.v. degradation & oxidation . Docking and beaching ur boat might leave some very visible marks on black .
    Might be a good idea to get professional advice.
    Clayton Miles
    D4 V8 HSE
    Navara 2.5 DCI 4x4
    Thanked: 260
    Quote Originally Posted by rage101 View Post
    I think the "reason" for keeping it white... Is more with deep sea fishing boats, where you have a chance of flipping the boat...
    A white hull will be more vissible by rescue boats
    Lynx Bashplate
    DIY Drawer system
    Hillcrest, Malaysia
    Thanked: 5717
    Quote Originally Posted by SinWolf View Post
    A white haul will be more vissible by rescue boats
    This is a great subject.
    Lets see now.
    A boat is most likely to flip or get into trouble when the water is rough, ne.
    And when the water is rough it is full of WHITE horses, ne.
    And when the helicopter is search for you your WHITE hull is going to very visible amoungst all the WHITE horses - NOT.
    Thats why rescue craft are ORANGE - visilibilty at sea.
    EDIT - that is why a large ORANGE plastic sheet is part of the safety equipment.
    ZS5KAD
    3 V8's
    agreed , reading some of the other forums - coastguards moan about this often as they would prefer brighter colors for all boats
    Clayton Miles
    D4 V8 HSE
    Navara 2.5 DCI 4x4
    Apr 2008
    Thanked: 8
    Thanks guys for the tips. I think I should pop into boat world and ask some questions there.
    Eric
    Thanked: 260
    I've had 2 jetski's done with Gel-coat... And it seems to work fine...
    Lynx Bashplate
    DIY Drawer system
    Thanked: 72
    No it's much simpler than that - have you any idea how hot a black boat can become? And then you have to sit/stand on that (normally with little clothing for protection)
    Here's a snipbit from some googling ,
    another side effect from a professional boat painter
    There is one important factor not yet mentioned on this thread. On a fiberglass hull the extreme heat caused by dark colors causes the glass to shrink over time. This causes what we call "print-through". If you walk down the dock in your marina and look carefully at any dark glass hulls you see, you will notice that you can see the weave of the fiberglass through the paint. If a boat has been faired at any point in her life this problem is exacerbated by the different shrinkage rate of the fairing compound and the glass. If you look at Interlux' painting manuals there are temperature ratings for different colors in exposure to bright sunlight for long periods. Flag blue is rated at 280 degrees fahrenheit! Thats like putting your boat in an oven for months at a time. While it wont "soften" or structurally damage your boat in any way, it will make it impossible to keep a fair hull.
    Clayton Miles
    D4 V8 HSE
    Navara 2.5 DCI 4x4
    May 2010
    Use a polyacrethane twin pack paint (we use Plascon)with a sigma cover primer which is epoxy based, the colour is up to you allthough all of the arguments above are valid. Should you need any specific advice give me a shout on [email protected] and Ill send you my number, I am a boatbuilder by trade and can give you unbiased advice based on many years experience.
    Justin
    JUSTIN
    Boat building and fibreglass moulding
    What I know about driving off road is dangerous at the best of times............
    2000 Defender 110 - TD5
    1997 Defender 2.8i
    Sep 2008
    Big Bay / on a boat
    Thanked: 7
    have a look at marine paint. yacht paint.
    available at the yacht shops in parden eiland
    http://www.international-marine.com/MarineHome.aspx
    http://www.jotun.com/
    http://www.hempel.dk/internet/inedkc...9?OpenDocument
    Hello! That's what he did!, he came to the forum! He he he!
    Marc
    2003 Colt Rodeo D/C 2.8TDi 4x4
    32" BFG A/T
    40mm Body Lift
    ARB Front Bumper
    Bellville
    Thanked: 727
    Quote Originally Posted by Ubermarc View Post
    And he got it from Itchy
  1. New boat Question
    By Mitsu Bushy in forum Fishing
    Last Post: 2011/12/20, 12:36 PM
  2. Tyres and Insurance?
    By Johan in forum General 4x4 Discussion
    Last Post: 2010/12/24, 10:12 AM
  3. 4x4 speed
    By topgun in forum Ford & Mazda
    Last Post: 2010/01/04, 08:48 PM
  4. Beach launching with a boat
    By ponki in forum General 4x4 Discussion
    Last Post: 2009/04/22, 02:43 PM
  5. Taking boat to Bots ?
    By Rico in forum Botswana
    Last Post: 2007/07/23, 12:48 PM
