Results 1 to 8 of 8
Thread: WJ cabin heater
    Pretoria, South Africa
    Default WJ cabin heater
    Have any of you guys had the cabin heater fuse blow? I replaced it and it just blew again. It looks like the actual cabin heater itself thats causing this. Where is it located and is it a mission to replace?
    I also have a problem with my heating and cooling system and the quote I got from JEEP fourways came to
    Labour: R4160 excl
    Housing Air: R1380.71 excl
    Housing Heat: R834.54 excl
    Servo AC te: R4027.38
    There where other things on the quote as well to I am not sure if they are part of the heater.
    Insulater EN: R1581.47 excl
    Insulater EN: R1599.23 excl
    All I can say is good luck if you need to replace it with a new one, otherwise try and find a second hand one or get that one repaired if that is even possible.
    <a href="http://www.fuelly.com/driver/ernstkamffer/grand-cherokee" target="_blank"><img src="http://mefi.us/images/fuelly/sig-metric/97987.png" width="500" height="63" alt="Fuelly" title="Share and compare MPG at Fuelly" border="0"/></a>
    Bellville
    Thanked: 727
    Kobus the controller/relay thingy is in the passenger footwell. My son managed to break the pc board when he discovered the wires under the dashboard and started "playing" with it, using his toes. HennieZJ repaired it for me. It could be that you have a similar problem.
    Check out this site for complete instructions regarding the WJ heater blend door issues
    Thanks, guys. I shall have a look. Thys, at the moment we don't need it with 33-36 dgrees every day, but it annoys me if something is not working!
    Keep you posted!
    I love this JEEP, everyday I learn a new way of pressing a combination of buttons to give me different diagnostic options. I am going home tonight and the first thing im going to do is to see if I get those errors. Thys thanks alot for the link
    I checked my codes last night and i get the following.
    12
    14
    16
    22
    I have no idea what any of this means but all I know is that it isnt working. Luckly for me the aircon part kinda works especially if I put it on full blast so I am not to worried. When winter approaches ill start looking into getting it fixed so that I can have some warm air blowing.
    Bellville
    Thanked: 727
    Quote Originally Posted by Ernst.Kamffer View Post
    12
    14
    16
    22
    Here is a list of the climate control system codes:
    Input faults
    01 = IR thermister circuit open
    02 = IR thermister circuit shorted
    03 = Fan pot shorted
    04 = Fan pot open
    05 = Mode pot shorted
    06 = Mode pot open
    07 = IR sensor delta too large
    08 = Reserved
    09 = Reserved
    10 = One of four motor drivers has drive "A" shorted to ground
    11 = Engine air intake temperature bus message missing
    12 = Country code bus message missing
    System faults
    13 = Mode motor not responding
    14 = AI (Recirc) motor not responding
    15 = Left temperature door not responding
    16 = Right temperature door not responding
    17 = Mode door travel range too small
    18 = Mode door travel range too large
    19 = AI (Recirc) door travel too small
    20 = AI (Recirc) door travel too large
    21 = Left temperature door travel too small
    22 = Left temperature door travel too large (Result is no heat - Our kit repairs this)
    23 = Right temperature door travel too small
    24 = Right temperature door travel too large (Result is no heat - Our kit repairs this)
    25 = Calibration check sum error
    26 = Engine coolant temp bus message missing
    27 = Vehicle speed bus message missing
    28 = Engine RPM bus message missing
    29 = OAT bus message missing
    30 = Display intensity bus message missing
    31 = VIN number bus message missing
    32 = Raw OAT buss message missing
    Input faults
    33 = IR thermister circuit was open
    34 = IR thermister circuit was shorted
    35 = Fan pot was shorted
    36 = Fan pot was open
    37 = Mode pot was shorted
    38 = Mode pot was open
    39 = IR sensor delta was too large
    40 = Reserved
    41 = Reserved
    42 = One of four motor drivers had drive 9A9 shorted to ground
    43 = Engine air intake temperature bus message missing
    44 = Country code buss message missing
    System faults
    45 = Mode motor was not responding
    46 = AI (Recirc) motor was not responding
    47 = Left temperature door was not responding
    48 = Right temperature door was not responding
    49 = Mode door travel range too small
    50 = Mode door travel range too large
    51 = AI (Recirc) door travel range too small
    52 = AI (Recirc) door travel range too large
    53 = Left temperature door travel too small
    54 = Left temperature door travel too large
    55 = Right temperature door travel too small
    56 = Right temperature door travel too large
    57 = Calibration check sum error
    58 = Engine coolant temp bus message missing
    59 = Vehicle speed bus message missing
    60 = Engine RPM bus message missing
    61 = OAT bus message missing
    62 = Display intensity bus message missing
    63 = VIN number bus message missing
    64 = Raw OAT bus message was missing
    65 = Reserved
    66 = Reserved
    67 = Reserved
    Thys, my trekker het nie AZC nie, dis 'n Laredo, so ek kan nie foutkodes oproep soos julle nie. Ek het onder die panele gekyk aan die passasierskant en sien niks verkeerd nie. Ek sal volgende die cabin heater uithaal en sy weerstande ens meet. Die probleem le heel waarskynlik daar. Die gewone watergedrewe verwarmer werk 100%, so dis nie 'n krisis nie, maar as die funksie beskikbaar is, wil ek hom laat werk!8)
    Dankie vd inligting.
    By charlatan in forum Jeep
  2. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  3. Grand Cherokee Error code
    By Nick47 in forum Jeep
  4. Gas heater vs Electricity
    By Navigator in forum The 4x4 Pub
    Last Post: 2010/06/20, 08:17 PM
  5. Coolant Heater Hose types and alternatives?
    By justustwo in forum Land Rover
    Last Post: 2009/01/31, 06:35 PM
