Fortuner Nudge Bar
Results 1 to 20 of 20
    Sep 2011
    cape town
    Thanked: 50
    Default Fortuner Nudge Bar
    Okay, so against my will I had a nudge bar fitted to my fortuner. So now I am fairly happy with it. However today, I was involved in a small fender bender.
    No damage at all to both cars, but my nudge bar is now touching the bumper on the left side.
    I am at work now and didnt get to check the ins and outs as to why, but I figure the the bolt at was not fastened correctly.
    Is this assumption right?
    and if so isnt it supposed to be tight in a sense that it wont budge from an impact below 20Km/h?
    I basically gather that if it is the bolt that is loose then I should be able to adjust it again. If not who can I go to that can make this small adjustment?
    Thanked: 364
    So the cosmetic nudgebars does serve a purpose in some cases. 8)
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
    Thanked: 959
    Nudge bars are not as strong as they look.
    FJC - Just Cruising
    Sep 2011
    cape town
    Thanked: 50
    Yeah, I know hence why I didnt want it, but if you given things, you basically cant say no
    the upper mountings are adjustable and takes no efort to push it in. So you can just loosen it a bit, pull the bar away from the bumper to where you want it and tighten again.
    I had same last week, thinking of a steel bumper now.
    Discovery 4
    Wrangler 4dr
    Africa Twin
    Husky 501
    Husky 250
    MTB Morewood Zula
    Sep 2011
    cape town
    Thanked: 50
    cool, thanks. and the bottom mountings wont be affected at all, I gather
    Bottom mouts are much better but still allow a bit of swivel. tighten anyway.
    Discovery 4
    Wrangler 4dr
    Africa Twin
    Husky 501
    Husky 250
    MTB Morewood Zula
    Sep 2011
    cape town
    Thanked: 50
    cool, worries over, will sought it out his eve when I get home.
    Thanked: 48
    The nudge bars actually cause more damadge to the vehicle than the fender bender. Take is off and throw it away. It also makes your aproach angle worse.
    Coenraad Basson
    Hilux D/C 3.0 D4D
    Prado 4.0 V6 Auto VX
    Thanked: 361
    They serve no purpose IMO.
    Ross
    Sep 2011
    cape town
    Thanked: 50
    true they only purpose they serve is that it provides a place to mount your spots.
    Thanked: 7
    Quote Originally Posted by riyadh View Post
    I beg to differ.
    A young lady, in a Fiat, hit me head on.
    The Fiat's front end was demolished with bonnet against the windscreen and was taken away on a flatbed.
    I drove home and had to point out the damage to wife.
    Fourways GP
    I had a Fortuner with a Nudgebar ride into the back of my Wrangler JK on Tuesday afternoon in peak traffic....
    His nudgebar was pushed up into the grill, front left fender creased, front left light cracked, bumper broken on the front left....
    My bumper has a slight, and i mean slight, kink on the plastic..
    JK 2dr Silver
    Sep 2011
    Dundee
    nudge/nəj/
    Noun:A light touch or push.
    Why are we debating this again?
    I just fitted it cos it came for free and lets face it... the Tuna looks naked without it
    2011 Toyota Fortuner 3.0 D4D 4x4 Auto (Facelift)
    Previous: 2009 Toyota Fortuner 3.0 D4D 4x2 Auto (Facelift)
    Sep 2011
    cape town
    Thanked: 50
    Quote Originally Posted by sashton View Post
    nudge/nəj/
    LoL indeed, same here, however after fiddling around with it on sat, I realised that the entire thing is a bolt on accessory. It would have been so much better if it was welded on and if the parts that went under the bumber actually went thru' it. However I suppose thats why there are bullbars
    Thanked: 959
    I would have some very bad scratches/dings (expensive) if it wasen't for my nudge bar - it works for me!
    FJC - Just Cruising
    Oct 2007
    Germiston
    Nude bar is useless! caused more damage in a fender bender I had. Did not fit it on my new Fortuner.
    Thanked: 1373
    Quote Originally Posted by x-ray3 View Post
    I strongly disagree!!!
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Oct 2007
    Germiston
    HaHaHa!
    Middelburg Mpumalanga
    Sa Uys, vat hom!!! Hy wil mos iets onverantwoordeliks kwytraak!!
  1. Fortuner; Towbar & Nudge Bar
    By Gelliott in forum Toyota
    Last Post: 2011/09/02, 11:25 AM
  2. Replies: 1
    Last Post: 2011/08/29, 10:16 AM
  3. Fortuner Nudge bar
    By Bulletjie77 in forum Toyota
    Last Post: 2011/07/28, 01:06 PM
  4. Pajero front recovery points on nudge bar
    By Grant Anderson in forum Mitsubishi
    Last Post: 2010/05/25, 07:12 PM
