Who knows a "zorse"
Results 1 to 20 of 22
    Nigel
    Thanked: 1895
    Default Who knows a "zorse"
    Come on. Where are the guys with "die dik brille en die wit jaste".
    +27 zero eight 2 four 95 9252
    Aug 2010
    Wydsbeen
    Is a meatpie.
    Half a horse mixed with half a zebra.
    From Wikipedia:
    A zorse is the offspring of a male zebra and a female horse. This cross is also called a zebrula, zebrule, zebra mule or golden zebra. The rarer reverse pairing is sometimes called a horbra, hebra, zebrinny or zebret. Like most other animal hybrids, the zorse is sterile.
    Aug 2010
    Wydsbeen
    Quote Originally Posted by Mapome View Post
    From Wikipedia:
    In namibia you shall find a Donze and a Zedo, also sterile and extremely lazy.
    Nigel
    Thanked: 1895
    Well we found one with the wild horses on Namibia.
    The owners of the farm didn't even know about it.
    They did however say that there was a zebra that thought and was convinced, that it was a horse. This was close to Aussenkehr.
    We found about 40 horses
ID:	116531   Click image for larger version.
Name:	IMG_4938 (Large).JPG
    More or less Cullinan
    Those Zebras seem to be sneaky buggers.
    The (in)famous Zonkies at Hennops.
    Sneaky bugger Zebra "surprised" a Donkey.
    Jacques
    Never trust a Chinchilla to hold your balloon.
    Aug 2010
    Wydsbeen
    Henris,
    Ek kaap nie die thread nie, maar dit is interessant van wilde perde teen die rivier.
    Baie mense maak die fout as hulle 'n klompie perde in die Suide sien om te aanvaar dat dit die sg wilde perde van die Namib is.
    Wat hulle egter nie aan dink nie is die feit dat perde en donkies vir baie jare die enigste vervoermiddel in Suidwes was en op byna elke plaas was 'n paar perde vir boerderydoeleindes en donkies van die werkers.
    Namate hulle as vervoermiddel vervang is die motorvoertuie is die diere maar net gelos en het hulle aangeteel, deur drade gebreek en weiding en water gesoek. Veral in die suide met skraal weiding en groot onomheinde plase asook groot bewaringsgebiede en geen natuurlike vyand nie het die diere vermeerder.
    In die Noorweste het ons eenvoudig, veral wilde donkies voor die voet geskiet omdat hulle weiding en drade geskadig het'
    Hulle het in areas inbeweeg waar hulle nie gehinder is en daar aangeteel. Hullle het dan ook weerstand opgebou teen honger en dors.
    Ek het in 'n ander thread genoem van die Herero's wat juis hierdie diere opgekoop het en hulle na die noordweste geneem het. Die gebruik het ook nou uitgesterf.
    Die slotsom is dat nie alle klompies perde nie noodwendig die sogenaamde Wildeperde van die Namib is nie.
    Nigel
    Thanked: 1895
    Well, we were told that these were the wild horses.
    Then probably not the ones that were left by the Germans then.
    Rustenburg
    Thanked: 119
    A Zorse is some thing a "Woesrander" puts on his Bakkie/Tuned Uno/Corsa....
    Aug 2010
    Wydsbeen
    I am sure that a lot of the horses in Namibia actually stems from german horses which was left all over.
    All I am trying to state is that unattended horses/donkeys get wild in a short time.
    It also may be that "German" horses mixed with domesticated animals.
    I am no expert on this and only try to underline a less known fact.
    Thanked: 397
    And there I thought a zorse is Brakpan slang for a lekker freeflow exhaust system
    '89 LR 110 V8
    Thanked: 397
    Quote Originally Posted by Andrewfus View Post
    So I wasn't the only one confused with these horse/donkey/zebra talk.
    '89 LR 110 V8
    Aug 2010
    Wydsbeen
    If a zebra can believe it is actually a horse ( Henris post), I can now understand some people behaving like a donkey.
    Oct 2006
    Thanked: 78
    Ek sweer dit was nie ek nie
    Oct 2008
    Grabouw
    Thanked: 165
    Question Sir Henri
    From the pics i cannot see when these were taken. Did you just come back from a trip? The you succeeded in making my mouth water!!
    Nigel
    Thanked: 1895
    Quote Originally Posted by BarnieH View Post
    Yes.
    Taken on 22/9/11. At about 13h00.
    At about here
    S28 23.113 E17 33.218
    Aug 2010
    Wydsbeen
    Volgens die ondergemelde is die Namib se Wilde Perde 'n afgesonderde groep:
    Die Republikein
    7.10.2011
    Jan Coetzer, onbesonge held van die Namib se wilde perde
    Oom Jan s dat baie mense op verskeie wyses tot die oorlewing van die wilde perde van die Namib bygedra het. Terselfdertyd het hy alle krediet aan die eertydse CDM gegee vir die volgehoue steun wat tot die voortbestaan van die perde in die goed gepolisieerde Sperrgebiet gelei het. In dieselfde trant het hy sy dank teenoor die Suid-Afrikaanse Spoorwe uitgespreek wat gesorg het dat water ononderbroke vir die perde by Garub beskikbaar was.
    As n man wat altyd n liefde vir diere gehad het, veral perde, het die mistieke aard van die wilde perde hom aangetrek. Die feit dat hulle in hierdie afgesonderde gebied onder uiterste toestande kon bestaan en n suiwer ras kon word weens dekades se afsondering en natuurlike seleksie wat slegs die sterkstes laat oorleef het, het hom getref.
    Jan 2009
    Thanked: 224
    Quote Originally Posted by galius View Post
    Is a meatpie.
    Is this a bit like the Irish horse and rabbit pie? Its also 50/50. One horse and one rabbit.
    C
    Aug 2010
    Wydsbeen
    En dan kry jy nog 'n "Kammorse"
    Wat is dit?
    Default Zorse
