Discovery 3 Towbar replacement/Modification
Results 1 to 20 of 21
    Oct 2007
    Thanked: 7
    Default Towbar replacement/Modification
    Morning all,
    I am using the normal Disco 3 clip-on towbar, and has been using it for quite a while with a normal trailer. However, I now have a Off-road caravan, and the tow ball is slightly too low. Is there a "standard" replacement ball you can clip in like the original, without the downward u-shape turn, or anything else you guys can recommend?
    Thanked: 47
    Yes there is many replacements, the clip in kind from LR is VERY expensive. Front Runner and a number of other companies have developed a tow bar that is higher.
    I dont like their design as they use the recovery point to fasten the new tow bar. I al going to design another clip in tow bar at some stage and cut it with a CNC machine from high tensile steel that will be a bit higher than the old one.
    Here is a picture from what is offered in the market.
Name:	Disco 3 36.jpg
ID:	113540   Click image for larger version.
Name:	Disco 3 18.jpg
ID:	113541   Click image for larger version.
Name:	Disco 3 61 Hak.jpg
    Discovery 3 V8 SE
    Self designed Rock and Tree Sliders.
    Next: Project Bashplate
    1981 Series 3 S R6 88" Allmost Perfectly Restored
    Apr 2012
    Somerset Wes
    Following your post and photo's in September 11 wrt "I al going to design another clip in towbar at some stage and cut it with a CNC machine from high tensile steel that will be a bit higher than the old one"
    Did you eventually manufacture a tow bar and if so what was the outcome. As I’m looking for a “clip on” tow bar to accommodate my 4x4 trailer. Any suggestions?
    G
    Thanked: 47
    Hi Gert
    I have drawn it up but not yet made it. I am not really rushed as I dont pull a trailer.
    I will post when I made it.
    Discovery 3 V8 SE
    Fourways
    Thanked: 86
    Discovery 2 V8 XS
    Range Rover Sport SDV8
    Thanked: 2344
    I've got the Frontrunner one to tow the trailer (perfect height). Very nice and sturdy with the only downside of being picked up by the parking sensors. Either remove when not in use or disconnect the inner two sensors.
    Pta
    Thanked: 49
    Quote Originally Posted by Silver Shadow View Post
    I like the 2nd option... can i have more detail on that one please.
    Thanked: 47
    I like strenght and aestetics (spelling?) so I want to make the same thing as FR but I dont want to lose the recovery point.
    Discovery 3 V8 SE
    Thanked: 362
    George on my Disco3 I had the inner 2 sensors rotated. Worked a charm.
    Does not work on D4 since they are flat.
    www.lani4travel.com
    Louis Le Grange
    Thanked: 362
    If you use the towball with the pin I think you still have a recovery point. Problem is it stands out even further making pdc useless.
    www.lani4travel.com
    Louis Le Grange
    Thanked: 2344
    Ah, seems like a plan. Rotated, ie switch the left and right hand side sensors or just turn them upside down?
    Thanked: 362
    Just turn them to slope away from the towbar. Unfortunately not an easy job. Had it done when the fitted the frontrunner towbar.
    www.lani4travel.com
    Louis Le Grange
    Jul 2007
    Thanked: 12
    I use the Frontrunner towbar with the ball and pin towball fitted - still have a recovery point this way and my pdc still works fine.
    Andre du Toit
    Discovery 4 V8
    Jurgens Xplorer
    Apr 2012
    Somerset Wes
    Hi All,
    Many thx for the information. What a great forum. Take care.
    G
    Thanked: 321
    I have the G4outdoor one on my Discovery4 and it is a nice height for off road towing, strong enough for off road towing(SABS tested), leaves the recovery hook intact and does not interfere with the rear parking sensors when fitted. It can also be removed like the Land Rover one if needed.
    Beautiful design in my opinion. www.g4outdoor.co.za
    CATS
Name:	g4 towbar.JPG
ID:	196474   Click image for larger version.
Name:	g4 towbar2.jpg
    2003 Safari Xplorer
    Thanked: 47
    I like this one cats
    Discovery 3 V8 SE
    kempton park
    Also like the looks of this one what is the cost?
    1997 Defender 90 300TDI
    BF Goodrich Mud Tyres
    2008 Discovery 3 TDV6 SE
    BF Goodrich AT Tyres
    Dec 2012
    R4400 Madness
  19. #19
    kempton park
    Quote Originally Posted by Charles 3 View Post
    R4400 Madness
    just want a tow hitch, not a trailer as well
  20. #20
    Jul 2007
    Despatch
    Thanked: 28
    Quote Originally Posted by daveb_1 View Post
    That's exactly what I was thinking...
    Offroad junky
    '97 SsangYong Musso 602 EL exec
    '14 Citroen DS4 2.0 HDI swambo's platkar
    Previously;
    '03 Nissan HB 3.0TD D/C 4x4
    '07 Hilux D4D D/C 4x4
    '16 Ford Ranger 2.2 DC XL Hi-Rider
    '12 Disco 4 SDV6 SE - Beauty
    '06 Disco 3 TDV6 S (De-cat, EGR blanked, remap, Johnson rods suspension rods, 285/65-R17 Kuhmo KL61) - Beast
    '04 Terracan 3.5 V6
    '96 Ssang Yong Musso 602 (non turbo manual)
    '04 Ford Ranger 2.5 TDI D/C 4x4 with Solid front axle and 33" Maxxis
  1. Towbar extension
    By Koekies in forum Vehicle & Technical Chat - General
    Last Post: 2013/02/18, 12:08 PM
  2. Jimny Towbar Options and Bike carrier info
    By horsepower in forum Suzuki
    Last Post: 2011/08/11, 08:08 PM
  3. Lega requirement - Towbar 4 Corsa Ute
    By heeltydspeeltyd in forum The 4x4 Pub
    Last Post: 2010/03/11, 10:08 AM
  4. Touareg towbar
    By herbie in forum Volkswagen
    Last Post: 2009/12/15, 09:33 AM
  5. Towbar / recovery point
    By Elders in forum General 4x4 Discussion
    Last Post: 2009/09/15, 08:59 PM
