Disco 2 auto gearbox adaptation
Results 1 to 7 of 7
    Thanked: 290
    Default Disco 2 auto gearbox adaptation
    When one reset the gearbox adaptation, is it just a matter of taking it for a drive afterwards so the gearbox ECU can "learn" new adaptation settings?
    Reset Adaptions
    Allows you to clear any adaptions the ECU
    might have made
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
    HHhhmm I havent a clue what you are talking about, but im keen to find out.
    2004 DISCO TD5 GS Auto
    ex - 1997 DISCO Tdi
    Thanked: 290
    FRAM RAVE;
    With time, the components in a gearbox wear and the duration of the gear shifts tends to increase, which has an adverse effect on the brake clutches. To counteract this, the EAT ECU applies a pressure adaptation to each shift. To calculate the adaptations, the EAT ECU monitors the pressure modulation used, and time taken, for each shift. If a subsequent shift of the same type, in terms of throttle position and engine speed, has a longer duration, the EAT ECU stores an aptation for that type of shift in a volatile memory. The adaptation is then included in future pressure calculations for that type of shift, to restore shift duration to the nominal.
    Increased load/reduced torque compensation
    To aid performance and driveability in the high range economy mode, the EAT ECU has three adaptive shift and lock-up maps. These maps delay upshifts and torque converter lock-up similar to the sport mode if the inputs from the engine indicate:
    1. A sustained high load on the engine, such as occurs when the vehicle is ascending a steep gradient or towing a
    trailer.
    2. A lower than normal engine torque, such as occurs at altitude or high ambient temperatures.
    The EAT ECU monitors the engine inputs and selects the most appropriate adaptive map for the prevailing conditions.
    ORRA Z07
    Bellville
    For my driving style, I found it better to reset and then drive her in sports mode for a day or 2. Much better then.
    Driven by passion
    Jakes 071 9855 258
    Thanked: 290
    Quote Originally Posted by DiscoMad View Post
    Jakes, after resetting the adaptation, should I drive in any style, or just my normal (heavy footed ) manner?
    I assume that you have done this before.......
    ORRA Z07
    Bellville
    Yip, done it plenty times by now. Played with it to see what is best. It's a brilliant system since it will adapt to numerous changes you make regarding your drive train and even torque converter.
    If you have a heavy foot drive her like you're in a hurry. There's probably specs somewhere, but I found 2 days driving and she's back to normal/better !!
    Driven by passion
    Jakes 071 9855 258
    Thanked: 290
    Txs Jakes, much appreciated...
    ORRA Z07
  1. Replies: 10
    Last Post: 2011/06/20, 09:41 PM
  2. Disco II Auto box
    By boeniel in forum Land Rover
    Last Post: 2010/08/27, 12:20 PM
  3. Bigger Tyres Than OE for Disco Td5 Auto?
    By royboy in forum Land Rover
    Last Post: 2010/07/25, 07:21 PM
  4. Vibration DISCO II V8 Auto???
    By Rookie in forum Land Rover
    Last Post: 2008/07/03, 08:28 AM
