Urgent Advice Please: fitting spots to nudge bar
Results 1 to 2 of 2
    Default Urgent Advice Please: fitting spots to nudge bar
    Hi Guys,
    I have searched and not found a answer to my question:
    I have a stainless steel nudge bar fitted to my Fortuner, it does not have lugs to mount spotlights. i want to mount a pair of LightForce Genesis 210 spotlights to this nudgebar (not willing to fit a replacement bullbar).
    Can i simply put a hole through the nudge bar and bolt the spot on, or must I have lugs welded on, or should I use the nudge bar mounts that bolt around the nudge bar?
    Please assist.
    Broekskeur
    Have lugs welded on it will look alot better than any of the other options there's a good chance the others will end up looking like a "plaas" conversion, depends on where you are but it shouldn't be hard to find some-one that can do decent stainless welding
  1. Ford & Mazda Mazda BT50 Nudge bar / spot lights
    By etiennee in forum Ford & Mazda
    Last Post: 2011/06/21, 08:07 AM
  2. To keep nudge bar on or not?!
    By x-ray3 in forum Toyota
    Last Post: 2011/05/24, 03:59 PM
  3. Urgent advice on Korando
    By BlackBull in forum Ssangyong
    Last Post: 2008/10/03, 02:50 PM
  4. LC 70 SUV Tow Bar Advice Please
    By aubreys in forum Toyota
    Last Post: 2008/07/28, 11:08 AM
