Results 1 to 20 of 26
    Undisclosed
    Thanked: 2248
    Default Disco 2 TD5 to Matroosberg - First impressions
    My brother in law bought a Disco 2 TD5 last week and we were in CT this weekend for a wedding.
    Of course I insisted on a proper test drive and we took the Disco to Matroosberg Sunday Morning.
    There was not snow on the track, but it was quite misty and the track was fairly wet.
    While I cannot criticise the on-road handling, power and comfort, I was a bit disappointed with the off road performance.
    His model is still one of the earlier Desco 2's and do not have the centre diff lock. We also did the track with Michelin Synchrone tyres and IMO. that was most definitely an important part of the disappointing experience.
    He did the entire climb to the top and me and another experienced off-road buddy of him, could watch from the side.
    My impressions are that the traction control on this vehicle is not a great success. First of all, there must be quite some wheel spin before the TC starts working and in one case it was clearly spinning cross-axle with little correction from the TC. The Hill Descent Control is also a gimmick I do not care for. Braking against the motor in a lower gear works great.
    I took the Disco some way down and the engine braking is very good. It is a very nice vehicle to place on the track, but the throttle is way too light for my taste.
    All in all, I would still need some time with it for final verdict.
    Spring Creek
    Thanked: 23
    See my comments here on my Td5 this past weekend in the sand.
    http://www.4x4community.co.za/forum/...4545#post84545
    Similar experience with traction control.
    Gqeberha
    Thanked: 9701
    They should have removed the Disco2 badge from all models with CDL! It does the vehicle absolutely no justice!
    Honeydew
    Thanked: 95
    A comment from the sideline is that I went driving with amadisco quite alot when he first got his D2 TD5 and you have to get used to a different driving technique than other vehicles.
    Hang in there and try different drive styles and techniques, I dont believe that the vehicle is that bad, he kept up on all of the trails with his vehicle...
    Ranger Wildtrack
    2.0
    Bi Turbo
    Gqeberha
    Thanked: 9701
    True words, go and play with it, you need to understand the traction control, and how to effectively use it. Also with the TD5 when doing a steep uphill, most vehicles might do it in 2nd low, with the TD5 I found slowly in 1st low is the best option, it keeps the revs high enough, and then the TC also seems to work at it's best. You cannot drive the TD5 like you would another vehicle and expect the same result.
    Dec 2006
    We went to Moz in April and my experience was that TC is not for sand. I also found that third and fourth gear in low range is the best gears for thick sand. I have a 99 Disco Td5 with centre diff lock fitted later. When I engaged the CDL with traction control enabled it still felt as if the vehichle is braking itself when the traction control was disabled it performed much beter and that is why I prefer to drive in sand with CDL engaged and TC disabled
    _______________________
    Hugo
    Alberton - Gauteng
    99 TD5 DiscoII
    Conqueror Commander
    Spring Creek
    Thanked: 23
    If you do a retro fit of the CDL, do you automatically have the abilitly to disengage traction control, or do you have to ask them to do that when installing the CDL?
    Dec 2006
    If I want do disable the TC, I engage CDL while the motor is running, switch the motor of for about 20 seconds and restart. All the downhill decent, ABS and TC lights will then be illuminated and TC is disabled. To enable it again I disengage the CDL with the motor running, switch motor off, wait 20 seconds and start again, everything is then back to normal and TC enabled, you can also use TC with CDL by just engaging CDL with motor running.
    Hugo
    Alberton - Gauteng
    99 TD5 DiscoII
    Conqueror Commander
    Gqeberha
    Thanked: 9701
    This is not true for the post 2003 models, TC is always enabled, I still need to fit the switch to disable TC for sand.
    Disabling TC
    http://www.4x4community.co.za/forum/...ead.php?t=5164
    Nov 2006
    Durbanville, Cape Town
    Thanked: 27
    My TD5 with upgraded ECU cannot handle sand in low range. Just too much power.
    I do sand in high, with only centre diff lock on.
    TC works well on rocks ................
    Gqeberha
    Thanked: 9701
    Did you also fit a larger intercooler?
    Quote Originally Posted by maverick64 View Post
    Nov 2006
    Thanked: 27
    Exclamation
    No.
    I am still using standard intercooler, but i fitted a EGT gauge that shows you when to back off, on long hills especially. She normally runs at about 450 - 600 C,and when pushed can go to 800, my limit is set to 740, the display starts to flash, and then you back off on the throttle.
    You learn quickly to keep your eyes on the gauge all the time.
    Jan.
    2020 Fortuner 2.4 GD6 4x4
    Jurgens Penta
    (Wild Dog Forum Member- Maverick64)
    (Past drives)
    2012 Fortuner D4D 4x4 White, 2007 R1200 GS, 2005 Discovery 3 V8 SE Silver, 2000 D2 TD5 White, 2005 Merc C180 K Cobalt, 2003 D2 V8 SE Gold, 2001 D2 TD5 GS Gold, 2000 Hilux 3000D 2x4 White
    Honeydew
    Thanked: 95
    This might sound like a stupid comment but alot of guys increase or decrease revs while doing the incline and the car starts spinning, with the TC you keep on the revs and keep it stable, if you vary the revs the car then gets confused and disengages the TC and you loose the advantage.
    Ranger Wildtrack
    2.0
    Bi Turbo
    Spring Creek
    Thanked: 23
    What pressures do you guys run your tyres at in thick sand? I dropped mine to 0.9 - could I have gone any lower?
    Gqeberha
    Thanked: 9701
    If you are running the standard tyres, 235/70/R16 no then even 0.9 is getting a bit low, I've driven it off the rim couple of times with lower pressures.
    Undisclosed
    Thanked: 2248
    Aha, the switch to disengage he TC sound like a good idea. Should be very easy to install too!
    Adelaide
    Thanked: 62
    It is interesting to read the comments regarding the performance of the Disco on Matroosberg as I did Matroosberg as my second off-road excursion in my XJ Cherokee. I did it with a stock standard vehicle and Firestone Wilderness tyres, and had no serious problems with traction in the wet and snow up Matroosberg. Maybe I was just too inexperienced to notice.
    2012 Jeep WK2 Limited CRD
    2" Murchison Lift
    265/65R18 Dick Cepek Trail Country
    TJM sidesteps
    Uneek4x4 Recovery points
    Gqeberha
    Thanked: 9701
    Read here.
    Quote Originally Posted by biltong View Post
    Nov 2006
    Thanked: 27
    I run my 245 Coopers at 0,8 bar in the sand, and have yet to loose a tyre off the rim.
    Jan.
    Jurgens Penta
    (Past drives)
    Thanked: 3413
    In loose sand you can go down to 0.6 bar in those size tires, but then remember - the lower the pressure the easier it will climb off the rim so avoid sharp cornering. With BFGs I wouldn't go that low on alloy rims and you will get them climbing off, because of that lovely thing called rim protectors.
    Disclaimer - All my posts on this forum is without prejudice, is based on my fair assumptions or perceptions, might not be factually correct, is in no way intended to cause harm to anyone and is acted upon at your own discretion.
  1. Discovery 2: Buying and running a Disco II (Td5)
    By Craigb in forum Land Rover
    Last Post: 2023/12/26, 07:58 PM
  2. Disco TD5 going nowhere
    By Murphy in forum Land Rover
    Last Post: 2011/08/18, 07:29 AM
  3. Discovery 2: Disco td5, 140 000km service
    By RANDYTD5 in forum Land Rover
    Last Post: 2010/06/01, 10:27 AM
  4. Maintenance on a TD5 Disco 2
    By fgrobler in forum Land Rover
    Last Post: 2010/05/19, 12:55 PM
  5. Disco TD5
    By Wielie in forum Land Rover
    Last Post: 2007/03/28, 11:56 AM
