Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 21 to 40 of 103
  1. #21
    May 2007
    Daar by die gat,in die NK
    Thanked: 59
    Quote Originally Posted by C Africa View Post
    Frans,
    in the Tzaneen case, it could either have been an altimeter error (these instruments rely on air pressure, and a sudden change in pressure can cause you to be out by a lot of height).
    C
    Why aren't GPS sets used in these older plains? They tel the altitude immediately.
    No one ever ruined their eyesight by looking at the BRIGHT side!!
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Nissan King Cab (aka Navara )
    Albert Einstein
    Whoooopa 3 The Goat strike back
    https://www.youtube.com/watch?v=uqw5...ature=youtu.be
    Another teazer.....
    https://www.youtube.com/watch?v=51KljMSXOnI
  2. #22
    Klein Karoo (CBR)
    Thanked: 978
    Quote Originally Posted by Spike View Post
    Papsak could you maybe post a picture from Google Earth showing the location of the memorial? Pretty please
    I've trapped that mountain flat (with my blinkers on) and never noticed one.
    Trying to install google earth now... surely I can't be THAT confused Tony?
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
  3. #23
    Mozambique/Cape Town/Other
    Thanked: 24
    The only blip on google earth that looks like it might be a monument is right over to the left low down just behind UCT. That seems like the wrong location from what I've researched
    * "Wat Spike probeer sę in sy min woorde" -Die Skim "
  4. #24
    Thanked: 48
    Reading thru this link http://www.avcom.co.za/phpBB3/viewto...5fbb7&start=15
    post 24
    To find the crash site, park at Rhodes memorial and head upward untill you reach a jeep track about halfway between the parking and the Kings block House. Head right on the jeep track on a gentle slope and follow it to the top of Plumpudding hill (trig beacon) and a view point. Look for a path following the ridge upward (quite clear). As was previously mentioned the area has many silver trees and quite thick fynbos.
    About halfway between the Block house and the top of Plumpudding hill down to the left is what was the crash site. If you comb carefully you might be able to find the scars of one of the impacts. (If I remember correctly from visiting the site after the crash it appeared as only two impact zones, maybe something to do with the formation flying.
    Google earth shows this "trail" very clearly.
    Coenraad Basson
    Hilux D/C 3.0 D4D
    Prado 4.0 V6 Auto VX
  5. #25
    Thanked: 24
    Fodie attached showing Plumpudding hill which was the altitude of their approach, plus my guestimation of the impact of Plane 3 based on memories of photos seen years ago, and in the lower left corner are to things that look like they could be memorials. If so then it seems that they are placed at a general area and not the points of impact according to stuff I've researched
  6. #26
    Klein Karoo (CBR)
    Thanked: 978
    Ja, I must be confused.... BTW why do you refer to Rhodes Memorial as "That big monstrosity"
    Thanks for the Fodie
  7. #27
    Jan 2009
    Oral
    Thanked: 1535
    Uys, it is actually protocal to fly at least 1000ft higher than the highest point in your immediate area AT ALL TIMES.
    The things here were:
    1 CT, the people were practicing for an air show, and obviously were not flying "normal" flight rules.
    2 Tzaneen, the pilots took off in bad weather to climb to a cruise altitude. Obviously they planned a route to miss obstacles during their climb. Which is why I say, they either deviated from route OR they had wrong info on their instruments.
    GPS, quite correct, your GPS will give you the CORRECT altitude, problem is you have to navigate to the specific screen to check that, and in this instance the pilot would have been extremely busy monitoring his other flight instruments, no time to "fiddle" with the GPS.
    The GPS also has a "low terrain" warning system which comes up if you're flying closer than certain level to obstacles, BUT this warning would have been going off continuously from liftoff until they reach altitude above higherst peak, so the pilots would have ignored it, KNOWING that they were low, and relying on their dead reckoning to fly safely.
    C
  8. #28
    May 2007
    Thanked: 59
    C
    As I sums it up, don't fly in bad weather!
    Ford Ranger 4l 4x4
    Nissan Patrol 4.8
    Albert Einstein
    Another teazer.....
  9. #29
    Jan 2009
    Oral
    Thanked: 1535
    Quote Originally Posted by Frans Reichert View Post
    Pilot error is the MAIN cause of air crashes.
    More of them are weather related than any other cause.
    The thing that gets you, is called impatience. It is terribly hard to sit on the ground waiting for the weather to clear when you have a long way to go and you are in a hurry (and you are optimistc (maybe its a bit better up there, it will be OK).
    Virtually the same thing happend couple of years ago near Hoadspruit. Pilot did not want to take off. His important customer put prassure on him (i.e. I have to get back to the Free state by ....). Pilot took of against his better judgement, and half a dozen people died when he flew into a mountain.
    C
  10. #30
    Thanked: 48
    spike in combo with your pick and the quote i reffered to earlier
    I got this as more ar less the area. Possible?
    Coenraad Basson
    Hilux D/C 3.0 D4D
  11. #31
    Thanked: 48
    Coenraad Basson
    Hilux D/C 3.0 D4D
  12. #32
    Thanked: 24
    That's exactly what I thought Coenraad but Tony's reference to a memorial confuses me because I haven't seen anything there.
    EVERY SINGLE TIME I go to that area (over the last 40 years) I find a spot to survey the area and try to picture the scenario. And I ain't seen a memorial yet in that particular area.
  13. #33
    Thanked: 170
    When I grew up I read quite a bit on aviation. On a few ocasions the Table mountain crash were mentiond in books like Africa's Superpower etc. At some stage there was an article in Nyala, the SAAF's Aviation Safety Magazine. Before I left the SAAF, in 2005 IIRC I converted quite a bit of Buccannner footage for the then upcoming Buccanner reunion http://www.af.mil.za/news/2005/24.htm
    During this process I had long chats with a colonell that used to work in the same directorate as me. He took quite a bit of the original 16mm film of the squandron. Included in there were prior footage of some of his squadron mates. As we watched the footage he remarked on some that were flying as passengers in a Mercurius that day and perished in the crash. He himself was flying in a Buccanner as navigator and he recalled that as they approched Goodwood stadium the visibility decreased dramatically and they aborted towards the left, the Mercurius formation was in front of them and veered right, impacting the mountain. If one would seek more information it would always be possible to request if via the Access to Information act from the Air Force's Directorate Aviation Safety
    Wynand
    2005 Discovery 3 HSE v8
    2002 Discovery II XS v8 (sold)
    1974 Chev K 25 (julle dink 'n v8 is dors)
    Land Rover - making mechanics from motorists since 1947 and electronic engineers since 1989!
  14. The Following User Says Thank You to Dr Jones For This Useful Post:
  15. #34
    Thanked: 568
    I just found this Info if it helps:
    Those who perished included Commandant LAS Henning,
    Major GJ Euvrard, Major N Beetge, Major WA Prinsloo, Major HHAMC Lamoral, Captain D du Plessis Lombard, Lance-Corporal E Hays, Private GH Wassermann, Captain GN Snyman, Major MC de G Genis and Corporal RN Grobler.
    *Major "Willa" Prinsloo had survived a plane crash in the sea off Cape Columbine as a spotting pax two years earlier and had tried to save the life of the Pilot, Aubrey Clews, then spent two hours in the cold Atlantic before rescue by a fishing vessel.
    * Renier Grobler played for the Northern Transvaal Rugby Team and accompanied the Springboks on the 1969-1970 UK tour
  16. #35
    Thanked: 568
    & this - it mentions Impalas
  17. #36
    Thanked: 24
    This photo is at the place marked "3" on my photo
    http://www.flickr.com/photos/warrenski/1324473370/
    The bottom photo here is just above the other spot, The road make a hairpin and cuts back to the right. That is this spot. The trees aren't there today. The tree nazi's cut them down but that is another story
  18. #37
    Thanked: 568
    Another Photo - notice the fence in the photo
    http://www.flickr.com/photos/warrens...n/photostream/
  19. #38
    Thanked: 568
    It doesnt appear that a memorial has been erected, as at last year. On of the sons of the pilots is here
  20. #39
    Thanked: 145
    We will never know, but it might be that the guys, all coming from the relative flat north, forgot that there is a mountain in Cape Town when the increased speed for the turn.
    I'm no flight expert so please accept any ignorance.
    Gerrit Laubscher
    Angola sempre
  21. #40
    Ceres Tankwa Karoo
    Thanked: 897
    C Africa.
    Why is it not protocol to fly much higher in poor visibility. IE, visibility goed down, increase altitude with 1km.
    Uys
    That is what you should do! People take chances (won't happen to me) Two of my good mates flew into a mountain close to Tzaneen in a Impala. Think it was 1989. We were flying there everyday and knew the area well. They were flying low level with low cloud in a mountainous area - not a good combination. They should not have been out doing low level flying in that weather.
    A lot of private pilots are not instrument rated and therefore can't fly in clouds. A person would fly somewhere for the weekend in their plane, they don't have a instrument rating, on Sunday the weather is bad and he has to work on Monday. Now the pressure is on to fly home. They fly back trying to stay below the clouds. Most of them make it - some don't.
    Freelander 2 SD4
    Isuzu Dmax 300 4x4 SC
    Discovery 3 HSE V8
    Defender 2.8i sold
    Audi SQ5 Tdi sold 😢
    Range Rover 4.4 V8 sold
    By charlatan in forum Jeep
  2. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  3. Series II Air suspension problem
    By Disco Smiley in forum Land Rover
    Last Post: 2011/02/03, 09:26 PM
  4. Grand Cherokee Error code
    By Nick47 in forum Jeep
  5. First hand account by passenger involved in Brazillian air crash
    By Bartho in forum General 4x4 Discussion
    Last Post: 2006/10/03, 12:56 PM
