Korando 2.9TD rear diff hazard
Results 1 to 5 of 5
    Mar 2011
    Thanked: 15
    Default Korando 2.9TD rear diff hazard
    A warning to all Korando drivers. I am aware of two cases, both 2005 Korando TDs, +-100 000km, both not very intensive offroaders that experienced this problem.
    If your Korando has a noisy diff, remove the prop, and check the drive pinion lock nut located inside the flange. Mine and a gentleman from Namibia's Korandos both worked their lock nuts loose. In both cases this destroyed the bearing and oil seal, and in my case caused the drive pinion shaft to jam into the gears while coasting. I'm still waiting for a damage report
    A greedy mechanic will most probably say a total rebuild is needed, and that as we know is not very cheap. The fellow from Nam simply retightened everything and he did not even have to replace the bearing and seal. I'm afraid it's going to be a different story for me though.
    If you are part of the UK SsangYong club, see my post and the Namibia gentleman's story for full details.
  2. The Following 3 Users Say Thank You to getack For This Useful Post:
    Thanks for the feedback and info.
    Sorry to hear about the problem. Is your Korando back home in a safe and loving environment?
    Gideon Naudé
    2006 VW Touareg 3.0 V6
    Thanked: 41
    i've replied to your previous post.
    When nature calls
    Jacques Steyn
    2009 Toyota Prado 150 VX (202kw)
    OL Front bumper | Snorkel | OME Suspension
    Swambo : 2012 VW Polo 1.4 Comfort line
    Ex 2008 Nissan Patrol 4.8 GRX A/T (199kw) | TD Suspension | Outback Extreme Rear Bumper | Ironman Front Bumper | Air Helpers | Snorkel | FR Roofrack
    Ex 1996 Ssangyong Musso 602EL TD A/T Exec (82kw) |Snorkel | Bilstein B6 | Disco 2 springs | FR Roofrack | ARB Front bumper | Rear Bumper
    Ex 1982 Citroen CX Prestige automatic
    Ex 1976 Citroen GS Club
    Ex 2013 Honda CRV Exec Auto AWD
    Ex 2007 Toyota Auris 2.0 D4D
    Ex 2010 Honda Accord 2.4i Exec Manual (148kw)
    Ex 1997 Isuzu KB280LE TD D/C 2x4
    Ex 1997 Toyota Corolla RSI (121kw)
    Ex 1989 Toyota Corolla GLI TwinCam Exec (98kw)
    Feb 2012
    Default Re: Korando 2.9TD rear diff hazard
    Hi getack,
    I know it's an old thread but I just wanted to say thanks for your post, it saved me a lot of problems and money. The diff on my Korando started whining last week and after a discussion with my mechanic, the worries about finding parts etc., I found your posts and decided to check the drive pinion lock nut, as you described. I tightened it as much as I could without proper tools, and the whining has disappeared completely, no whining or any noises whatsoever. Now I'll take it to my mechanic to put some Loctite and tighten everything properly. Hopefully, that will be all that is needed.
    Anyway, thanks a lot!
    PS: The size of the socket for the lock nut is 27mm.
    2005 Korando 2.9Tdi
  1. Gen 4 3.2DID GLS LWB No rear diff lock
    By jako_kruger in forum Mitsubishi
    Last Post: 2014/12/18, 05:02 PM
  2. Grand Cherokee WJ 3.1 Rear Diff Plug
    By CJ v H in forum Jeep
    Last Post: 2011/02/15, 09:57 PM
  3. Help rear diff clicking
    By SteveL in forum Mitsubishi
    Last Post: 2010/10/17, 09:55 PM
  4. An interesting TJ Jeep Article.
    By Big Hilux in forum Jeep
  5. Rear Diff
    By FiveTen in forum Mitsubishi
    Last Post: 2007/01/11, 12:48 PM
