Recovery points - From and engineering perspective
Results 1 to 14 of 14
    Thanked: 81
    Default Recovery points - From and engineering perspective
    Dunno if this is a double posting, but I found this article very interesting reading.
    Vehicle Recovery Points by Mike Lauterbach.
    Downloadable document can be found here
    Looking at the strength of most vehicle's recovery points and then comparing it with the required strength as per the tables in the article, I have to think ... and then think again ...
    Jul 2010
    Thanked: 47
    I'm going to use these values to calculate my recovery point's strengths and see if mine are sufficient?
    NISSAN PATROL GU 4.2D
    “Donkey”
    Life is a journey, not a destination!!
    Try slowing down once in a while
    and soak up your surroundings.
    You might just surprise yourself.
    Stilfontein
    Thanked: 618
    Sticky!!
    Sent from my Plaas telefoon using Tapatalk
    Brooklyn
    This is indeed more complex than I anticipated. Thank you very much for this valuable insight.
    Mar 2012
    Link not working anymore
    2004 Discovery 2 TD5
    yip, link not working
    Boksburg
    link she is still broken
    Kb300 Dtec 4x4 ...let the mods begin
    2003 Kb300Tdi d/c lx 4x4 - sold
    GP0274 batmandiver
    Thanked: 983
    landy spares. How do you expect it to work!
    [email protected]
    +27824453301
    Thanked: 292
    Got oil in the computer box.
    Thanked: 81
    Found the downloadable document on this board, so I fixed the linky.
    Feb 2015
    My previous G350 bluetech had the obvious proper recovery hooks and have used them extensively.However,noe have a new engined ML500 and it has none.Did use the towbar as well as the screw in ring provided.This has never been an issue,but do realize that it could become one.Safety then the first priority if you have to.
    Langs die rivier, op n berg
    Thanked: 2462
    Default Re: Recovery points - From and engineering perspective
    Tel die as n recovery point?
    Jhb, Lesotho
    Thanked: 139
    Yes the Towball does
    Jan
    1988 110 CSW V8
    1961 S2 SWB
    Thanked: 2462
    Dankie. Waardeer
