Garmin Quest Not Working!!!
Results 1 to 14 of 14
    Mar 2007
    Panorama, CT
    Default Garmin Quest Not Working!!!
    hi all...
    ek het die naweek Garmin Quest gekoop
    (Makro, R4999 - goedkoopste in hele RSA, glo my!!)
    dit was die goeie nuus...
    sedert Sat. kry ek NIE daai @#$%^&* Mapsource software ge-'unlock' nie!
    het al 12x als oor en oor op die Garmin site loop reg., die unlock codes (op die geel pampiertjie 10 000 x ingetik), by friend Mario loop hulp soek, gevloek, gedreig en nou is ek oppad Groendakkies toe...!!!!!!!!
    wie kan help asb.??
    Disco II V8 GS Auto
    "Real men don't need lockers"
    Klerksdorp
    Hoofseun,
    What version mapping software was supplied with your Quest? Southern Africa Streets 1? Is it the original version or the Migration CD?
    Two things:
    1. Are you using the latest version of Mapsource (Ver. 6.12.3)
    2. Does your Quest have the latest version of OS software loaded? (
    Ver. 4.00)
    We'll try and work this out...
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
    Mar 2007
    Panorama, CT
    geees Eric....English plse...!!?
    what r u talking about??
    ok, bought unit brand new from Makro Milnerton Sat. - sealed box!
    on the sealed envelope cover of the incl. cd it says:
    Garmap Southern Africa Streetmaps Version 1
    there was also a white box with another cd in case:
    "Quest City Navigator Europe v8"
    there was a small yellow paper incl. with the Mapsourse & Garmin Quest manuals...
    I've typed in those codes over and over and over and over....!!!
    NO LUCK MY FRIEND!!!
    mapsourse stays LOCKED...
    only 'info' GPS unit shows (as we speak), when you go to Map Info in menu is:
    T4A Maps pro Africa CD*viewer*
    (witch was installed by friend at work earlier today via his pc).
    Have now send emails to Garmin, Techshop, Avnic, Johan GPS in CT, etc.
    what do u suggest?
    Disco II V8 GS Auto
    Just clarify something for me
    If it's Southern Africa Streetmaps V1 or South Africa Streetmaps V4 you can only unlock it at GARMAP not GARMIN... Unless you got SA City Select, in which case call AVNIC because all GPS bought from official Garmin Dealers are supposed to be supplied with one of the two GARMAP products
    The code you are using is the one supplied on the CD... that's not the unlock code but the serial number
    Or have I got the wrong end of thee stick.
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    Give a man a beer, waste an hour. Teach a man to brew, and waste a lifetime!
    Mar 2007
    Panorama, CT
    hi Simon...
    it def. is Garmap Southern Africa Streetmaps Verion 1
    well that's what it says on the cd cover!!
    what do u suggets?
    Disco II V8 GS Auto
    Mar 2007
    Panorama, CT
    o, and there's no code on the cd...??!
    there's a product serial no. though - 20 letters!?
    the yellow paper contains the unit serial no, reg. code and the unlock code.
    and yes, I did reg. at Garmap!!!!
    what now??
    Disco II V8 GS Auto
    Nov 2006
    Perth, Australia
    First things first...... vat n pilletjie en sluk hom met n koue glasie wyn...
    Take R50 bucks of fuel and go down to Muizenburg to Avnic head office.
    Take the whole lot of papers and cd's .. .. everything to them. Talk to Rene or Colleen. They are very friendly. That cant take you longer than 2 hours to sort out (driving included). Lekker thing is...... you can sit around their office and wait while they do everything for you. So you got plenty of time to have a look at all the gadgets and gizmos around the place. (most deurmekaar office I have ever seen).
    Trust me...... dont sukkel like that at home.
    No more Jeeps for me for a while.
    2009 Ford Ranger PK 3.0
    Nov 2006
    Perth, Australia
    Jan 2007
    Boksburg
    Hoofseun
    Ek het nou al twee van die goed gehad eers die M5 en nou die streetpilot en glo my elke keer het ek my gat afgesukkel. Die laaste keer Avnic gebel Midrand baie behulpsaam hy het my n unlock code gegee en walla daar werk alles.
    Ek kan nie verstaan hoekom hulle dinge so gekompliseerd maak vir jan en alle man op die straat nie met respek gese almal is nie Computer boffins nie en dit kan nogal tricky raak om die software te laai.
    Hoop jy kom gou reg
    Frik
    Klerksdorp
    Hoofseun,
    If you've entered the following:
    * GPS Unit ID (as per Mapsource)
    * GPS Serial Number (as per the Box or Quest sticker)
    * Product Code (as per number imprinted on the CD packaging)
    * Product 25-digit code (as per yellow paper (?))
    and the maps still do not unlock, then it is time for Avnic support. This can be done via email (as you've already done), telephonically, or as JD says, a personal visit. The whole procedure is a bit tricky, which is why a good Dealer would have already done all this for you
    Let us know the result.
    -F_D
    White Fang:
    jd's probably right... but you shouldn't be battling like this. It's odd that you have the serial number, reg-code and unlock code together as normally you can only receive your unlock code from the Garmap web-site.
    I'm speculating here that potentially someone bought that unit from Makro and returned it after having gotten an unlock code... Now you can't unlock the maps again.
    Did you actually register at Garmap and then apply for a reg-code from them? If you did, then just call pop into AVNIC who are in Marina da Gama.
    Carpe Diem Scrotum
    Hoofseun
    You are not totally incompitant as I am sure you feel by now, a month ago myself and my dad bought from Makro as well, my registration went smooth but my dad battled, thinking that it was my dad's inaptitude I told him to give it to a 9 year old to sort , turns out I had to eat my words, the unlockcode that was stuck to the CD cover did not match the CD, he phoned the support center number and after they took him through the process again and confirmed that he was actually doing everything right, they gave him a new unlock code over the phone and that worked on the first try.....maybe yours is a mismatch as well, phone the support line and whinge a bit, you will either be sorted or have egg on your face in 10 min flat.
    Hope this helps.
    Jaco
    You can follow.....but it's gonna hurt, even more!<br>FJ Desert Cruiser<br>Patrol 4.5<br>Stock standard....for now...
    Mar 2007
    Panorama, CT
    Frik, Eric...dankie vir julle concern, moeite en kommer!
    ek het toe reggekom dankie, en ja, Avnic is die beste in die weste!!
    die trick was om 'n 'ander' unlock code v Garmap se site te kry en dan weer deur die unlock procure te gaan.
    toe skielik werk als klopdisselboom.
    ongelukkig het my T4A in die slag gebly, maar dit is vooraf deur 'n pel v sy pc af op die Quest gelaai.
    die trick is nou om T4A op MY laptop te kry, dit saam met SAsmV1 te 'select' en dan die hele lot weer op te laai na die GPS toe.
    will keep you posted...
    Disco II V8 GS Auto
    Jan 2007
    Boksburg
    Hoofseun
    Ek is bly jy het regekom dis presies wat met my gebeur het .
  1. Quest problem with t4a and streetmaps
    By Johan Barnard in forum GPS & Mapping
    Last Post: 2014/01/01, 04:27 PM
  2. Garmin Quest 2 Replacement
    By garywinter in forum GPS & Mapping
    Last Post: 2010/10/18, 08:52 PM
  3. Replies: 34
    Last Post: 2010/09/23, 10:50 PM
  4. Garmin Quest speaker mount
    By ELU in forum GPS & Mapping
    Last Post: 2010/05/20, 09:58 PM
  5. Loading T4A onto Garmin Quest
    By JAS in forum GPS & Mapping
    Last Post: 2007/09/23, 10:01 AM
