Td5 coolant bleed screw
Results 1 to 20 of 31
    Dec 2010
    Groblershoop
    Thanked: 7
    Default Td5 coolant bleed screw
    My disco's coolant bleed screw is leaking/dripping coolant. I think the top part of the thread in the pipe is stripped.
    Is there a fix or must I replace the complete pipe?
    Melkbosstrand
    Thanked: 195
    I think the pipe thread is stronger than the screw thread, so it's more likely that the screw is damaged. If it's the pipe then you don't have much option but to replace.
    If you are on a tight budget and want to buy some time, I would suggest doing a bush-mechanic type fix- remove screw, smear with gasket maker and replace. I would also clamp it in with 3 hose clamps- one either side around the pipe, one from clamp to clamp over the screw head so it can't eject itself. Wouldn't leave it like this forever though.
    Rob
    V8 Defender 90 pickup. Lexus, Spitronics, 33" KL71, beadlocks, +2" Terrafirma, ATB's, 3.75 CW&P, 1.21 TC.
    Series IIA 88" pickup
    Disco 1 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    MG TF160 VVC ZandF remapped
    Buell XB12R
    Wuxi, China
    For the sake of enlightenment, where exactly is this screw located?
    camelman
    Dec 2010
    Groblershoop
    Thanked: 7
    Camelman its a screw with a screw driver slot on the top hose comming from the engine, about 250mm from the engine, on the right hand side of the engine.
    Hagu the 'nut' inside the pipe came loose, its a round piece of rubber with thread, it fell into the pipe.
    It's a new pipe for me!
    Wuxi, China
    Quote Originally Posted by Greenandgold View Post
    Thanx, I found it in the RAVE manual
    camelman
    Springs
    Thanked: 248
    because of these issues with these bleed screws, the local Silverton is making a short copper pipe with a bleed screw in it.
    you cut the rubber pipe off either side of the bleed screw, slip the copper T into the ends of the pipe and fit on with hose clamps.
    will see if i can get costing and photos on Monday.
    0833006099
    Dec 2010
    Groblershoop
    Thanked: 7
    Thanks LL will wait for you before I order new pipe
    Bellville
    After many failures, I too had a copper pipe made up with a bleed screw. Mine incorporates all the tap offs so I can fit standard "straight" hoses from it which I buy p/m, lately I've also changed those to silicone. Much better and a big cost saving at the end of the day.
    Worth the effort and a place to fit extra coolant sensors for your EMS unit and elctric fans!!
    Driven by passion
    Jakes 071 9855 258
    Springs
    Thanked: 248
    you could use the coolant sensor as a bleed screw by unscrewing it in that configuration.
    0833006099
    Bellville
    Correct, as many know another weak area are the "ears" of the outlet housing braking off. This I've improved with a much heavier 10mm plate and pipe and moved the temp sensor now to where the bleed screw use to be. Like LL said, one then just bleed by unscrewing that sensor.
    Can't find a pic of the latest version, this was the first one the made for me.
    Driven by passion
    Jakes 071 9855 258
    Springs
    Thanked: 248
    nice compressor.
    T-max?
    0833006099
    Interesting thread. If one has a choice is it better to make one up from copper or to use stainless? Any possible issues with electrolitic corrosion?
    Bellville
    Quote Originally Posted by Landyluvver View Post
    nice compressor.
    T-max?
    T-Max-4 years in THAT spot and lots of pumping!! Plumbed quick couplings to each steel bumper.
    Don - I think most guys would prefer to work in copper since most of the threat type nuts/flanges only come in copper - those needed for sensors.
    So they prefer to go copper on copper with silver solder. Dunno, never felt like questioning them....
    Driven by passion
    Jakes 071 9855 258
    Springs
    Thanked: 248
    normally the copper is easier to roll to shape. also easy to add fittings.
    stainless normally has to be machined for ribs etc.
    stainless will not be affected by corrosion but neither will copper.
    Allie is however another option.
    0833006099
    Dec 2010
    Groblershoop
    Thanked: 7
    I've found a piece of ssteel pipe that will fit but have never welded or brazed ssteel. Will do the test tomorrow.
    Discomad where do you get the silicone hoses?
    Springs
    Thanked: 248
    ok, promised i would come back on this issue.
    attached the photo of the bleed screw setup i was referring to.
    with bleed screw as shown, it is R200 complete and excluding leaving a hole with standard (NTP thread??) to fit a temperature sender it is R175.
    0833006099
    It is very important that you tend to it sooner than later. That little bleeder screw cost me an engin overaul.
    2003 Disco II GS V8 Auto
    2000 Disco II GS td5 Man "Groenie" Sold
    2004 Disco II GS td5 Man "White Lady" No more
    2000 Disco II XS td5 Auto Sold
    Jan 2009
    I made my own bleedscrew, rubber washer, metal washer and bolt from hardware store. Stealers quoted me R80 for the screw and R700 for a new hose.
    Defender 110 Puma
    BMW 320i
    Yamaha XT660z
    Gautrain
    Dec 2010
    Groblershoop
    Thanked: 7
    Thanks,for all the help and advice, fixed with a copper pipe and a bleed plug.
    This disco has had 3 go's, with in a month, at destroying the engine. I was lucky to see and smell it every time before the engine overheated.
    Guess a Madman is the next toy.
    Or at least the coolant level monitor from Landyonline
    By charlatan in forum Jeep
  2. antifreeze
    By Landyluvver in forum Land Rover
    Last Post: 2012/08/13, 12:29 PM
  3. Defender TD5 Coolant Temperature
    By bvandyk in forum Land Rover
    Last Post: 2010/09/13, 10:37 PM
  4. Cherokee Bleed screw size?
    By Anton72 in forum Jeep
    Last Post: 2010/04/15, 04:50 PM
  5. New thermostat - engine overheats
    By phuma in forum Land Rover
    Last Post: 2009/10/28, 10:58 PM
