Results 1 to 11 of 11
    Default DIY Prado Roofrack
    I thought I'd post these pictures of my DIY roofrack for the Prado 120 series so that someone else can also save R2500 for the Thule racks.
    These are two 25x25 square tubings with angle iron on the sides welded on. Inside the existing aluminium tubing on the roof, slide a piece of flatbar in with two M6 bolts welded on. Attach top rails when needed, otherwise remove.
ID:	103407   Click image for larger version.
ID:	103408   Click image for larger version.
ID:	103409   Click image for larger version.
ID:	103410   Click image for larger version.
    Looking nice Heinri.
    Have you loaded anything on it yet? Is the square tubing that you used steel or Alu?
    Pat
    Hilux 3.0 D4D 4x4
    No I haven't had a chance yet, but will shortly. Its all steel construction. Its really strong, I tried to rip it off the rails with my hands and couldn't move it. It will definitely carry the 70kg which is what the roof rails are rated at. I can also move them closer together and fit my jerry cans on top if I need to.
    My rails doesnt have those "tracks" where your bolts is comming out. I was also thinking of a DIY roofrack.
    Florida
    Default Prado Roofrack
    Heinri,
    Thank you for sharing. This is exactly what I was wanting to do.
    Will be making mine soon. We are planning a trip to Northern Namibia in October need some extra space.
    LeonC
    Toyota Prado 4.0
    Toyota RunX
    BushLapa 357
    Thanked: 15
    Quote Originally Posted by Die Skim View Post
    Thats not tracks. Its a reflection of the square tubing. If you look at the other pics its the same rails as mine with no tracks.
    Sent from my iPhone using Tapatalk - now Free
    Feb 2013
    Thanked: 24
    Great idea Heinri! I'm busy working on a DIY load bar idea for the fortuner but unfortunately my rails do not have those inside slots. If there is anyone that's done something similar please post pics or you idea! I'm only looking to carry max 30kg every once in a while.
    May 2010
    Thanks for the info, this is exactly what I wanted to do for my Prado 120, but did not think of welding the bolts onto the flat bar.
    Nice.... easy and solid..
    Thanked: 15
    I have to apologize.
    I made a mistake. There is a track in the rail!Click image for larger version.
    AJ van den Berg
    Feb 2013
    Doornlaagte, Rustenburg
    Nice! Ek soek al lank 'n oplossing en hier kom hy op die forum verby. Slim Plan!
    * '03 Prado 120 3.0 diesel
    Iron Man suspension
    Snorkel, DIY fitted
    LED light bar
    ARB bumper (almost black...)
    Custom 63mm exhaust
    Charging thing for...
    * '11 Oryx campervaantjie
    C-Tec DC-DC charger
    Jun 2007
    Brackenfell, Cape town
    Thanked: 16
    Default Re: DIY Prado Roofrack
    " Inside the existing aluminium tubing on the roof, slide a piece of flatbar in with two M6 bolts welded on"
    How do you slide this flatbar in? Do you remove the black housing on the end of the rail? And if so how do they come off?
    Shorty...........aka Renier
  1. My new DIY Vitara roofrack
    By Gert du Preez in forum Camping, Fridges, Accessories
    Last Post: 2010/11/30, 03:49 PM
  2. DIY Aluminium Roofrack for Defender
    Last Post: 2010/06/15, 04:45 AM
  3. Prado 90 Fire Extinguisher DIY
    By hoenner in forum Toyota
    Last Post: 2009/08/24, 06:03 PM
  4. DIY roofrack
    By Bush Wacked in forum Land Rover
    Last Post: 2008/10/23, 07:46 PM
  5. DIY Modular Roofrack
    By Stefan in forum Camping, Fridges, Accessories
    Last Post: 2008/09/15, 08:38 PM
