I have a semi-permanently mounted 60l grey plastic water tank on the back of my bakkie slide. It's supposed to be OK for water storage, but still new, so is giving off a bad plastic taste whenever water is left in there for more than a few hours, especially in hot weather. Any ideas on how I could get rid of this plastic taste?
2011 Pajero 3.8 GLS LWB
Carpe Diem Scrotum
Thanks for the quick reply, Simon. There are too many long weekends coming up to be stuck with such a problem now...
What about adding a Milton tablet? Thats supposed to sanitize and sterilize?
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster "
By Jeremy Clarkson (I think)
Lemon juice maybe?
* "Wat Spike probeer sê in sy min woorde" -Die Skim "
Milton can ruin the tank, be carefull...
500gr of "koeksoda" aka BiCarbonate of Soda mixed with 3/4 tank of water. Drive it around for one week.
Make sure thast you do not fill the tank up with a gargen hose pipe. That is the biggest problem when it comes to a plastic taste in the water. Use the addidas jerry can with the spout. It gives off zero taste.
If a tank got badly poluted with plastic taste due to fillign with a gargen hose pipe it might never recover....
Also have a look at what outlet you are using. Poor plastic pipe, even if just a few cm long will also contaminate the water and give a plastic taste.
So identify first the source of the plastic taste.
For an outlet make use of potable pipe (Foodgrade pipe) that is avialable from Flex-o-tube or make use of the flexible rubber hose with the metal mesh on the outside that gets used in to connect kitchen and bathroom sinks to the water supply. It is also food grade and is available at brights in up to 1 meter lengths.
Good luck, you might just need it.
TLC 105 Fully Locked
Carpe Diem Scrotum
a good dose of the finest whiskey maybe![]()
i only work to support my hobbies!!! 2006 mazda d/c sac intercooled, optimised, 31' bfg's
Jik is near the same as Miltons..... and now
Yes, an old hose that has been lying in the sun is horrific. Ever tried drinking water straight from a hot hose? You will burp for a few hours after that. A lekka Plastic burb.![]()
Thanks Bongani, Will get some proper pipe before I install it....
My tank is still in the box...
