Good Ground Clearance Advice
Results 1 to 11 of 11
    Jan 2007
    Milnerton ,Cape town
    Default Good Ground Clearance Advice
    Found this info on lifting of disco very good.
    The call for ground clearance
    Main drawback for a Discovery in the rough stuff, is the general ground clearance. The standard fitment wheels (29") are rather small, compared to a Defender or a series vehicle (32"). Bigger wheels translate directly into improved ground clearance - also giving better angles. The tow hitch and the small wheels will let the Discovery behind, when the Defenders keeps going. But as any thing Land Rover - rectifying this lag-behind is all in the range of some tools and a wallet!!!
    For those still thinking a Range Rover is more capable in the rough stuff than a Disco, it's worth mentioning that the wheel wells are bigger on Disco than RRs, which means they will take bigger wheels before they're bottoming out and you're rubbing top of the well (this is only one of a lot of things improved by the designers after nearly 20years of experience with the Range Rover).
    Standard fitment for a Discovery series 1, is 205/80-16 or 235/70-16, which are some 28,9 inches high. Compared this with a Defender with standard wheels at say 235/85-16 which are at 32 inches, the Defender has 1,5 inch more clearance under the diffs. This is what stops the Discovery when Defenders move on into the deep ruts.
    The reason for fitting such smallish tyres, are of course the need to keep a low centre of gravity for mainly roadgoing vehicles - but the wheels fitted to RRs and Discoveries are still bigger than the opposition. And as a dedicated offroader manufacturer Land Rover has a joker up its sleeve: the huge amount of axle articulation make easy work of even big boulder crawling with standard fitment sizes. Nonetheless - improved clearance will improve the vehicles capabilities even more, and let the vehicle fly through areas beyond reach with standard sized wheels. Bigger wheels also translates into better traction.
    There's always practical and economical considerations in every modification, so it's worth summing up everything connected before commencing any work - and checking every issue in detail with fellow Land Roverists having done same thing before as you intend to do. The economic side of it also calls for addressing the issues in this article whenever you're into changing tyres or springs or shockers - you won't like to invest in new springs this year and buying bigger wheels calling for taller springs next year... But you can fit taller springs this year and wait until next year when tyres wear out; but there's only some instances when you can fit bigger wheels this year and only next year fit taller springs.
    Fitting bigger tyres
    If you're fitting bigger than standard tyres, they might not fit the vehicle without modifications: trimming of fenders, adjusting steeringstops, higher bump stops etc. are often called for when going bigger. The bigger wheels "fills" more of the wheelwell, and might rub onto the top of the well. To prevent that from happening, you must fit higher bump stops, which restricts the axles upwards movement. Basically, the axle always moves freely up/down - restricted by two factors: length of shock absorbers, and height of bump stops.
    Restricting the movement of the axle means the vehicle will more easily lift a wheel - i.e. poorer traction, translating into poorer RTI (though still far above the opposition). You gain offroad competence by fitting larger wheels - and then loose some of it by restricting upward axle movement... Obviously you need to allow the axle to move more freely - as much as it did when it was on the standard tyres. The correct height of the bumpstops are determined by the height of the wheel (from wheel centre to top of wheel-well or where-ever it's rubbing) - so whatever setup, you'll need bumpstops conforming to the size of the wheels fitted. To regain the upward axle articulation despite the restrictions of a taller bump-stop, you will need to lift the vehicle by fitting taller/longer springs (or adding spacers under the coils).
    The downward axle articulation is determined by the length of the shock absorber - the downward travel will be stopped by the shocker being to its full extension too early. To break even, you will have to extend shock absorbers by the same amount as your lift (though, the shockers must not bottom out when compressed, which will fast break the shocker).
    The discussion on height of bumpstop and length of shockers, are theoretical considerations which may not come into account on a specific setup. Not all bigger wheels will rub inside wheel well with a stock axle bump stop - usually there's something to go on the original setup. The length of shockers will not always limit the downward travel - or these factors will be of less practical importance.
    Rubbing along the fenders are determined by the width of the treading - but this problem is easily rectified by slight cutting, which (when done properly) will not be visible for an inexperienced eye.
    The John Barge site here and the Discoweb here describe different tyres and what work is needed on the vehicle, though these are not covering all issues you might run into with your vehicle and a specific setup. To my knowledge, this is the most thorough resources available on this issue.
    Lifting
    In general, there's no need to lift a vehicle if bigger wheels are not fitted (but longer springs give more articulation), and the amount of lift must take into consideration also length of shockers and brakelines, suspension angles etc. A lift of +1" usually create no problems, reportedly a +2" lift should also work with standard setup, but above that the lifting calls for longer brakelines and longer shockers. You should probably budget for brakelines and longer shockers if you're in the +2" segment.
    Lifting the vehicle is usually done by fitting taller springs or spacers under the springs, which is called a suspension lift. For seriously high lifting, there's the issue of "bodylift", meaning the body is lifted higher above the chassis by the fitment of new bodymountings; this is more of a specialist work. Taller springs means more articulation, meaning the good stock articulation is improved to become even better. So lifting also improves traction by increasing the ability to keep all wheels on the ground. Fitting taller springs means more sway and general instability - so stiffer (heavy duty) springs are used - which counters the effect of taller springs by restricting axle movement from the stiffness of the springs...
    Fitment of Medium or Heavy Duty springs (Old Man Emu is a make often cited), or using standard springs intended for other models (Defender), means the body will sit higher above the axles. This will make more room in the wheelarch for bigger tyres, thus gaining more clearance under the axles.
    A lift of 1" should be within the reasonable and the effect on gravity will not render the vehicle with problematic on-road performances (especially vehicles with anti roll bars), though the handling will worsen. Usually, owners fit taller coils to achieve 1" lift.
    A spacer is a cheaper option, but requires the coils to be of the Heavy Duty type to retain a proper stiffness when cornering. You will not improve articulation with spacers, but it will enable fitment of bigger tyres for cheap, and not add more coils to roll and pitch.
    Check this link for manufacturing your own spacers, and these two Discoweb article#1 and article #2 on fitting spacers. For higher lifts, you'll need taller/stiffer coils. Many owners seem to install +1" (or +2") coils and then a 1" spacer (or even 2") to gain a 2-3" lift. Installment of spacers, is considered the poor-mans lift, as you won't gain any articulation using spacers, while fitting taller coils will give some. This article covers a 3 inch lift. It is reported that a fender/wing reloaction (forcing wing outwards) will enable using 235/85-16 without trimming the wing - go here.
    (drawing for spacers)
    You'll also find more extreme versions, giving an articulation previously unheard of - utilizing extremely long coilsprings, extremely long shockers, modified angles throughout the suspension and drivetrain. These have more popularity in US than Europe, though systems are now being developed also in Europe (Scorpion Racing). These long travel systems allows the vehicle to crawl over huge boulders, partially overcoming some of the problems associated with low ground clearance, and partially allowing fitment of bigger tyres. These must be considered extreme setups for extreme use.
    No cure-all
    It seems a good proposition to increase the size of the wheels, but nothing comes cheap... The wheelarches, gearboxes, diffs, halfshafts, coils, shock absorbers, propeller shafts, steering and suspension geometry etc. etc. are all made to fit and suit wheels of a certain size - and moving up (or down for that matter) will turn into problems elsewhere. Bigger wheels might not fit wheelarches, might rub radius arms, will hit top of wheel well at full flex, change gearing (worse acelleration - better top speed), increase loads on the halfshafts, steering will not self-center anymore. These issues are technical, and can be addressed using tools and your innermost pockets of your wallet. But there's more to it...
    And as the vehicle grows higher, it also raises its point of gravity - translating into feeling more unstable etc. Suspension specialists Famous Four says their +1" HD coils are for regular heavy duty towing or offroad clearance - and say "you'll loose in road handling what you gain from using heavy duty springs", and +2" coils are "for specialist use only" and not advisable for road use... Some US owners claim better on-road performance over standard springs after the fitment of Old Man Emu HD springs of +2" height. Confused?
    A caution and a call for experts!
    Lifting the vehicle is a specialist issue, and the judgment of different propositions calls for expert knowledge. The fitment of wheels slightly larger, and maybe rather large, should be within the range of advice possible by internet/e-mail discussions; some of the better sites (like Expedition Exchange) offer thorough advice in articles on their sites - other companies calls for discussion by phone. You're strongly advices to work thoroughly on the subject and consult experts and other owners before commencing any work.
    It's advisable to ride lifted vehicles to get a "feel" for what it means for ride-comfort on road. Most Discoveries are daily rides, and are supposed to work as family transport as well as offroader-toy for daddy... Don't forget: a bog standard Discovery is capable of really dirty doings, going places the opposition will have to look at from a distance. Don't commence any lifting or fitment of large wheels until you have a feel for what the Disco can do as is, and make sure you really know what you want before commencing the work and purchasing new goodies.
    The taller the lift, the more problems associated - as is the taller the wheels, the more problems... Anything and everything has been done before by someone else, so can be done. But it might turn out to become a huge project of revamping the whole vehicle, which was probably not why you started the process...
    Sizes & makes of tyres
    For a table of different wheel sizes and what you'll have to do to make them fit, go to John Barge site here and to the Discoweb here. Expedition Exchange has a tyre size calculator. The Disco2 site also has a tyre-calculator, with comments on Disco2-uses etc.
    Only 16" wheel rim sizes listed here, but also 15" wheels are available . Disco2.com has this article, splitting the alternatives into standard tyres (29inch), slightly larger (30-31inch), rather large (32inch), and oversized (33inch+); this article use this distinction for systematizing the information. A thread on the Expedtion Exchange Forum covers the issue of lifting pretty well, though the wheel-sizes are not an issue in that thread (which is why you lift the vehicle). This article deals with Range Rovers, but gives a very thorough overview of experiences with different sizes, tyres and brands for RRs.
    Deciding which size you would like to go for, it's worth mentioning that only half the increase in wheel size will be present under your diff. Moving up 1 inch in wheel size, give you 0,5 inch better clearance - as only 50% of the size is below diff, i.e. from hub-down, and the rest is from hub up where you don't need it - rather it's useless to a degree where it creates the need for butchering and for lifting the Disco... If you want +2 inches under the diff, you'll have to fit wheels 4 inches taller. Wanting an increase of 3 inches under diff, you'll need even 6 inches taller wheels...
    Beware: No tyre brands are the same when it comes to rubbing and need for trimming and so on (nor are any Land Rover identical) - so check the actual size on your vehicle before purchase of tyres of a disputably huge size! The taller and wider the tyre - and especially with of the tread, the more important to actually check it works!
    And sadly, not all manufacturer make the sizes you want in the type of tyre you want... E.g. BF Goodrich does not supply A/T in 215/85-16...
    This table shows the calculated tyresizes (which as mentioned above varies between manufacturers and between different models of tyres) gives an overview of some of the relevant sizes for Land Rovers (only 16" sizes covered), including what you gain in height over the stock tyre size:
    Tyregroup Tyresize Calculated width (cm) Calculated height (cm) Calculated height ( inches) Gain in diameter over stock (cm) Gain under diff over stock (cm)
    Standard sized tyres 205/80-16 20,5 73,44 28,91 0 0
    235/70-16 23,5 73,54 28,95 0,1 0,05
    225/75-16 22,5 74,39 29,28 0,95 0,475
    245/70-16 24,5 74,94 29,50 1,5 0,75
    255/65-16 25,5 73,79 29,05 0,35 0,175
    Slightly larger tyres 215/85-16 21,5 77,19 30,38 3,75 1,875
    245-75-16 24,5 77,39 30,46 3,95 1,975
    255/70-16 25,5 76,34 30,05 2,9 1,45
    265/70-16 26,5 77,74 30,6 4,3 2,15
    7.00-16 . . .
    Rather large wheels 235/85-16 23,5 80,59 31,72 7,15 3,575
    265/75-16 26,5 80,39 31,64 6,95 3,475
    7,50x16 . . 32,1
    Oversized wheels 255/85-16 25,5 83,99 33,06 10,55 5,275
    285/75-16 28,5 83,39 32,83 9,95 4,975
    Standard height (29")
    Tyresizes: 205/80-16, 235/70-16, 225/75-16, 245/70-16, 255/65-16 and others
    The tallest tyre not affecting anything, is 225/75-16. You'll gain some 5mm height under diff over stock tyres, and should experience no problems like rubbing, speed change or anything. This tyre is thus a very conservative way of improving traction and giving the vehicle a very slight lift under the diffs - shouldn't harm on road handling or anything. If you intend to go "just a bit off road", and not compromise on road performance, this tyre would be as far as you want to go.
    The wider tyres in this category might force you into some adjustment or trimming (as reported in a recent Discoweb posting), but are supposed to be a direct swap.
    Slightly larger wheels (30-31")
    Tyresizes: 215/85-16, 245-75-16, 255/70-16, 265/70-16, 7.00-16 and others
    For slightly larger wheels (30-31"), you're likely to encounter moderate problems (not all of these are even applicable on all wheels):
    Problem, Drawback,Remedy
    Wider wheels rubbing on radius arms Adjust steering stops Slight increase in turning circle
    Bigger/wider wheels rubbing rear wheel arches Cut bigger rear wheel arch (trimming) If not done properly/exact it doesn't look good. Can not be reverted to original...
    These sizes are reported not to need lifting (taller coils and/or spacers), but most people seem to have lifted their vehicles anyway for a more worked-through setup. Wider wheels call for more work than slimmer ones, i.e. trimming of wheel arches and adjusting steering stops. Discoweb has an article on trimming for larger tyres. Fitment of the wider options in this category without any adjustments, calls for rubbing. Camel Disco trimmed for 7.00x16
    215/85-16 is the tyre of this size reported having fewest problems associated. . 7.00x16 was the choice of Camel Trophy Discovery, and seems to have needed only rear wheel well trimming and trimming of front endcaps. A reasonable option for lifting, will be the use of slightly taller/stiffer coilsprings. A lifting of 1-2" are reported to need no change of shockers or longer brakelines. Wheels in this category seems to be the biggest size advisable if you don't want a specialist vehicle with expensive and extensive changes. Again: slimmer tyres give fewer problems than wider. Only slight modifications over the original setup's reported on these sizes, but vehicles and tyres differ, so it's worth checking.
    Otto were shod with 245/75-16 august 2003. Rear wing took a cut that possibly were not needed (at least not this size of cut), but the steering stop one side needed adjustment. Read more here.
    This is a size oftenly chosen by US Disco-owners, and gives a sensible lift under the diffs, while still not posing too much problems to make them fit or compromise too much. A bit bodywork is needed it seems, but several owners report fitting this size on a totally stock setup; I suspect though rubbing might occur when wheels are fully stuffed when offroading. The vehicle looks well balanced, even on stock suspension, and has a more aggressive stance.
    This vehicle is on 245/75-16, and has a lift of 2 inches (taller springs). This is a moderate setup, but it seems the owner has done some butchering on his wheel wells, and there's also a modified bumper. On the Discocrazy-site, there's a thorough write-up on fitment of this tyre.
    This Discovery has Old Man Emu (OME) springs: #751 front and #762 rear. These are rated HD, and will lift the vehicle ~1.4" at front and ~2" rear. Tyre size not reported on this, but justmight be into the segment of "rather large" 32 inch tyres. More info on OME-suspension lifts here.
    Mike Peters has this article on the Discoweb on fitting 265/70-16
    Rather large wheels: ~32"
    Tyresizes: 7,50x16, 235/85-16, 265/75-16 and others
    For rather large wheels (32"), you're likely to encounter more substantial problems, in addition to the above mentioned; for instance (not all of these will be applicable on all wheels):
    Problem, Remedy, Drawback
    Bigger wheels increase turning circle, i.e. worse accelleration (but also higher top speed); Speedo not correct. Change gearing in both diffs or in T-case You'll have to stick with bigger wheels - or revert to original setup.
    Off-camber: Steering will not self-centre Adjust camber: change radius arm to chassis bush. Angled radius arm.
    Driveline vibration Altering driveline angles by lifting calls for propshaft CV-joints etc.
    Wheels just don't fit... Suspension lift: taller springs and/or spacers. Longer shockers. Taller bumpstops. More fender cutting, also up front. For even more substantial wheels: Lifting body by increasing height at bodymountings. Higher point of gravity, substantially worse roadhandling etc.
    Wheels rubbing bumper Modify bumper. New bumper
    Just the work and cost of it...
    Brake lines too short Fit brake lines of increased length
    Shockers limit travel Fit longer shockers
    Spare wheel doesn't fit above bumper Fit spacer to carrier, invert carrier, purchase/make an adapter
    These sizes seem to need some kind of lift: taller coils and/or spacers - they seem to call for 2" lift or more, but the reports are not accurate on this. The 7.50-16, as a fairly slim tyre, reportedly have fewer problems; RR-owners report only marginal rubbing at top of rear wheel at full articulation (which calls for taller bumpstops only), but then again: tyres differ between brands and types. Change of gearing will be necessary to regain acceleration and power, which must be considered a seriously involved job. Using these sizes, you're into standard Defender-height territory!!!
    Fitment of these sizes without trimming of wheelarches might work on-road, but with increased flexing off-road, tyres will rub - and you might destroy a tyre or bend fender flares. The wider wheels call for more work than slimmer ones, i.e. trimming of wheelarches and adjusting steering stops. Terry West has an article on the Discoweb detailing fitment of 235/85-16, a tyre seeming to be a popular choice among US Discovery owners.
    This vehicle has a total of 4 inch lift (3 inch taller coils + 1 inch spacers). Size of tyres are not reported, but seem to be rather large or probably oversized... Not knowing the tyresize makes the picture less interesting than could have been, because the lifting in and of itself is not interesting - what you do the lifting for is to be able to fit taller wheels to increase ground clearance by fitting larger tyres.
    Oversized wheels: 33"+
    Tyresizes: 255/85-16, 285/75-16 and others
    (Disco2 285/75-16) Not covered in this article. This is really specialist work. Rovertym and other US-based companies does interesting conversions addressing any issue connected to the fitment of wheels this big. Going for these sizes includes what's mentioned on the 32" wheels + some more: reworking of steering geometry via new radiusarms, new propshafts and so on and so on.
    This LANDY has NO Oil Leak yet
    Bellville
    Excellent info and write-up. I suspect this should belong in vehicle mods section.
    On D2 - I'm running 31" tires and 2" dobinson lift coils and springs all round. Apart from double front prop, I didn't need to do any further mods to brake lines or bump stops and have yet to find a problem with the setup apart from the absence of a locker or 2...
    Driven by passion
    Jakes 071 9855 258
    Thanked: 545
    I am running General Grabber 265/70R16 with full Old Man Emu kit.
    It only feels wobbly on top with 4 jerry cans and tent etc on the roof.
    Next time from P.E. to Kgalagadi will be with empty diesel and water cans, fill up in Upington, much safer.
    And of course the spare is odd size to fit on the back door.
    Jan 2007
    imgreg, just be careful that spare better be same dia as/than on truck wheels ! Not the width is a problem but circumference if not within size you will wind up your diff as the smaller one has to work harder than the others.
    That is megga bucks
    Rather get same or compensating tyre and lift your spare wheel holder to accommodate bigger wheel.
    Kuilsriver
    Very usefull info, i am going from 245/70/16 to 265/75/16 and i am worried if it will fit without encoutering some problems. i have a ironman suspention on wich give me a bit of a lift. Any thoughts?
    __________________
    LROC-C5066
    CLRC-1031
    LRFC
    '95 LRover Disco1 3.9 V8i -Pappa beer
    '08 Range Rover Sport 4.2 V8 SC-Mamma beer8)
    '05 1.3 Ford Ikon -Baba beer
    Melkbosstrand
    Thanked: 427
    Kalahari, very nice find. Please post the link as there are missing pics and links out to other sites which are gone.
    My D2 has a 2" Terrafirma lift and 31x10.5x15 Kumho KL71 muds. No handling or clearance issues.
    Speedo underreads by about 0.5% compared to GPS
    Rob
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Klerksdorp
    Heeltemal te veel om te lees!!
    Niel Bierman
    Ford Ranger SupCab 4X4 3.0 XLT
    Nissan Hardbody 2.7D 4X4 SC
    Honda XR400R
    ORRA Call sign: B192
    Amateur Radio Call sign: ZS6NEB
    Thanked: 545
    Thumbs up
    MMMM, makes me think, i punctured comming out of "Die Hell" and used the spare all the way to P.E. the amber engine light came on once,
    I was then worried if somehow the spare was the reason It has never come back on with the correct wheel size?? I better check circumference, thanks Kalahari.
    Thanked: 1891
    Good one Kalahari!
    I was faced with the exact same problem when I bought my Disco 1. At first, I was pretty sad that I could not fit my favourite 235/80R16 tyres without mods to the Disco, but thinking hard about what I really used my 4x4 for, made me decide to stick with the standard wheels.
    I do have one irony with the writeup though. It (fairly I should admit) compares the Disco capabilities with other Land Rovers and not with other makes of vehicles...
    From personal experience of the above: I had a Nissan Safari (4 actually) before the Disco. It were awesome off roaders and I am still sorry I sold them. However, compared to the Disco, it had 330 mm of ground clearance under the gearbox member on a 116" wheel base, versus 360mm and a 100" wheel base. Since Disco, I managed to hang it up one single time ever (HAGU13 had to pull me off the dune). I am still not used to the fact that I can simply sail over places with my Disco where there was no question that the Safari would lie down just after the front wheels.
    On the Disco 1, I found 3 vulnerable areas. The plastic front bumper is a real problem, the rear wheel arches comes next and to a lesser extend, the rear bumper. All those can easily be solved with some cash and for the rest, dare I say that I can hardly see the real NEED to make a Disco more capable since it already comfortably keeps up with all modified IFS double cabs.
    1999 Discovery 1, 300 Tdi - "Tink Tanky"
    2004 Discovery 2 Td5 - "Blink Tanky"
    "Logic is a systematic method of coming to the wrong conclusion with confidence."
    "A technician will let a system degenerate to the level of his understanding and maintain it there."
    "...it is abundantly clear that you are an arrogant C-nut." - Estee. (I was overwhelmed. It was the nicest thing someone has said to me in a week!)
    May 2012
    Melkbosstrand
    Thanked: 427
    My new D2 runs 33" KL71's
    2" Terrafirma coils and shocks in front
    2" Terrafirma shocks rear. 2" airbag spacer and 1" spacer at the height sensor to give 50mm lift.
    40mm body lift
    Slight rubbing on extreme articuation, solved with mild camel cut.
    Speedo is about 7% under. New diff ratios on the way.
    Rob
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
  1. Colt lift en tyres - nog een !
    By NetEddy in forum Mitsubishi
    Last Post: 2011/08/15, 08:26 AM
  2. Replies: 6
    Last Post: 2011/02/24, 02:22 PM
  3. Replies: 9
    Last Post: 2011/02/16, 11:30 AM
  4. Define Ground clearance on 2x4 and 4x4's
    By mfezi in forum General 4x4 Discussion
    Last Post: 2010/12/28, 03:27 PM
  5. New vehicle - your opinions, please
    By HennieL in forum Vehicle & Technical Chat - General
    Last Post: 2010/01/11, 01:45 PM
