ABS light on - Blister
Results 1 to 2 of 2
    Post ABS light on - Blister
    Hi All
    After long though, I decided to fit a new exhaust system, incl branches. I received the vehicle back and all just fine. Went home and feels like a school boy again....
    Had to go to the shops for some baby food (Yes, twins). The ABS light came on as usual and didn't dissappear. I tried to switch the car off and also removed the Batt terminals, but light is still on.
    Could the exhaust guys damaged some wiring.? Where can I start with some fault finding
    1998 3.5 Blister
    Barberton
    Thanked: 898
    Jos,
    I suggest you do the basics first:
    Check brake fluid level
    Check brake pad thickness
    Check the fuse.
    Then take the car back to the exhaust shop and explain to them your concern Get the car back up on the lift and inspect their work for possible damage to the brake/electrical system.
    Good luck and please keep us posted.
    Roelf
  1. Replies: 70
    Last Post: 2014/10/24, 09:45 AM
  2. X-Trail ABS and 4x4 Light stay on
    By TheWall in forum Nissan
    Last Post: 2011/03/08, 07:42 AM
  3. 3,0L TD D/C 4x4 - ABS light stays on
    By Siggi in forum Nissan
    Last Post: 2010/05/24, 11:24 AM
  4. Replies: 48
    Last Post: 2010/05/04, 07:29 PM
  5. ABS Light in 4H
    By Vee6 in forum Mitsubishi
    Last Post: 2008/04/05, 10:38 PM
