Window switch
Results 1 to 20 of 23
Thread: Window switch
    CarloJK Guest
    Default Window switch
    Hi ,does anyone maybe know where i can get a lhs front window switch for a 2005 hb d/c ? The stealers are quoting me r715 + vat for the switch.>:d
    what's wrong if i may ask? mine still works but very SLOWLY up....down is fine though
    have you tried scrapyards?
    Everest 2.2 XLS 4x4
    Invader Quattro
    CarloJK Guest
    Quote Originally Posted by LS d2 View Post
    Doesn't want to go down and going up it is veeeeeeeeeeeeeeeery slow ( note: it isn't locked on driver side switch ),yet i can open and close fromdrivers side.
    No luck at the scrapyards.
    Jun 2007
    Thanked: 16
    be thankful, Ford want R4k foir the drivers door switch and R900 for the passenger door on my ranger.
    Mar 2007
    Old problem on the HB's. Mine is the same.
    See u'r in Cape
    1 Tonner spares in pta has a couple.
    Don't replace. open the unit and bend the contacts back a little. spray some electrical contact cleaner and it should be sorted for a while.
    even a replacement unit only lasts so long. It's always the left hand side
    CarloJK Guest
    Quote Originally Posted by devilliers View Post
    old problem on the hb's. Mine is the same.
    See u'r in cape
    1 tonner spares in pta has a couple.
    Don't replace. Open the unit and bend the contacts back a little. Spray some electrical contact cleaner and it should be sorted for a while.
    Even a replacement unit only lasts so long. It's always the left hand side
    will give it a go ,but do i only need to loosen the door handle with the switch in or do i need to remove the entire door panel ?
    CarloJK Guest
    So i took the HB to my local AUTO ELECTRICIAN ,yesterday and was quoted R1290,sh****t ,evwn more than the stealers!!!
    Can anyone help or maybe tell me where i can get a unit for a fair price.
    Crestholme
    "Don't replace. Open the unit and bend the contacts back a little. Spray some electrical contact cleaner and it should be sorted for a while.
    Even a replacement unit only lasts so long. It's always the left hand side "
    The switch just pops out.
    "We have enslaved the rest of the animal creation, and have treated our distant cousins in fur and feathers so badly that beyond doubt, if they were able to formulate a religion, they would depict the Devil in human form." William Ralph Inge
    "I don't believe in the concept of hell, but if I did, I would believe it to be full of the souls of people who were cruel to animals." Gary Larson
    The world is changed by people crazy enough to believe they can
    CarloJK Guest
    Quote Originally Posted by TiggerKZN View Post
    Have already tried your advice ,without any luck.
    Will need to get a new unit, but i cant justify spending that kind of money. Surely there has has to be someone that can help .
    Hi HARDBODY,
    Did you manage to get this sorted eventually? I have a problem with the driver switch.
    Thanks,
    Ryo
    Hardbody 3.3 V6 D/C
    ARB Bumper
    Ironman 4x4 Suspension Kit
    Dastek chip
    Apr 2011
    Brenthurst
    Quote Originally Posted by ryo123 View Post
    Hi HARDBODY,
    Thanks,
    Ryo
    I have the same problem with my h/body. unfortunately its not the switches but the mechanism themselves (on both sides) The guides on the mechanisms are warn and when you try to close them the windows goes a bit skew and then they start slowing down. the l/hand side is worse than the right.I tried readjusting the window and the mechanism which made it a bit better but still not fixed. I suspect you might have the same problem.
    Oct 2006
    CAPE TOWN ,SOUTH AFRICA
    Thanked: 490
    How do you know its the switch. ?
    ORA
    Ian
    well in my case, all the other switches are working and I am unable to control any of the windows as well as the mirror from the driver side switches.
    So in my case i am guessing it should be the switch. The switch broke after the window was rolled down, my buddy did a manual override to get the window up and ran ok as per normal so guessing its the switch.
    Think i'll give the agents a try
    Hardbody 3.3 V6 D/C
    ARB Bumper
    Dastek chip
    CarloJK Guest
    My RHS switch is also starting to give problems.Will need to get it looked at.
    You are welcome to contact me - I should be able to organise a switch directly from te Nissan plant at a much better price than the dealers...
    Oct 2006
    Thanked: 490
    Only the V6 switches seem to have issues now, i wonder if the diesel and 2.4 has the same switch.
    I am pretty sure all that stuff would be the same though.
    ORA
    Ian
    Thanked: 36
    Dag S Manne, bly om te sien dat ek nie die enigste een is wat met die probleem sukkel nie. Ek het al sekerlik 3 keer my bakkie se skakelaar uigehaal en skoon gemaak, maar na net omtrent 2 maande dan wil die skakelar nie meer werk nie, dan is dit maar dieselde storie.
    Spaar jouself die moeiete en gaan soek een by sie scrap yard, hulle behoort te he.
    Thanked: 36
    Quote Originally Posted by OFFROAD ADDICT View Post
    Almal het probleme, single en double cabs, almal gebruik dieselde switches..
    Thanked: 24
    Phone Toyota for one from the 7 million vehicle recall for similar problems - heard on the news this morning
    "A clear conscience is usually the sign of a bad memory"
    CarloJK Guest
    Hi HARDBODY,
    Thanks,
    Ryo
    Quote Originally Posted by natoburgoffer View Post
    See post # 15 ,i have just e-mailed Dawid.
  1. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  2. Part catalogs & other useful info
    By charlatan in forum Jeep
  3. Electric window switch
    By wigs in forum Ford & Mazda
    Last Post: 2015/06/03, 09:27 AM
  4. Jeep P1388 ERROR CODE
    By Zuk Doep in forum Jeep
    Last Post: 2011/04/20, 01:34 PM
  5. Grand Cherokee Error code
    By Nick47 in forum Jeep
