Diff Replacement options
Results 1 to 3 of 3
    Mar 2007
    Witbank
    Default Diff Replacement options
    Hi,
    A buddy of mine has a 2002 Mazda Drifter 2.5td with a seriously humming diff. it is 4x2. What is the diff replacement options available, that is if the diff is beyond repair status.
    Other makes or ratios.
    tx
    Ford Ranger 2.5td 4x4 XLT
    KB250 swb 4x2
    Ford Figo 1.4tdci
    VW Transporter 2.5TDI 4MOTION
    Bundutoe
    Bethlehem
    Thanked: 135
    Stick with the gearmax - relatively cheap to maintain and spares freely available
    Ratio is 4.44, standard the 2.5TD has the M82 diff as far as I know, you can have the crown and Pinion replaced if sideshafts, etc are still good. You can also check at scrapyards, might pick one up for a bargain - the same diff is used in the 2.7 / KZTE hilux 4x2 models and the nissan Hardbody as well, although probably all with different ratios
    You can fit other ratios, but don't deviate too far from the original - higher ratios will result in higher RPM at the same speed...
    If you need a stronger diff, go for the M89, but it is expensive and parts are expensive too... plus you will have to do a ratio change before fitting it to the 2.5...
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
    Mar 2007
    Witbank
    Thanks a mil, will let him know
    T
    KB250 swb 4x2
    Ford Figo 1.4tdci
    Bundutoe
  1. Terios Lock Diff question
    By platvark in forum Softroaders
    Last Post: 2014/02/25, 06:10 AM
  2. I Finished My 1998 Pajero 3.0 Difflock Retrofit
    By Joop Brown in forum Mitsubishi
    Last Post: 2009/06/30, 12:32 PM
  3. Diff swop
    By Rocks&sand in forum Ford & Mazda
    Last Post: 2009/06/21, 10:55 PM
  4. Rear Diff Lock for LR Defender 90
    By Defenderman in forum Land Rover
    Last Post: 2009/06/08, 12:40 PM
  5. Diff oil replacement
    By Edgar-Sorento in forum Kia
    Last Post: 2009/01/24, 10:46 PM
