Baboons Pass with a 2006 Prado 4.0 VX
Results 1 to 3 of 3
    Default Baboons Pass with a 2006 Prado 4.0 VX
    Hi,
    We are planning to do the Baboons Pass early November with a convoy of between 8 to 10 vehicles.
    I have a stock standard 2006 Prado 4.0 VX. Will I be able to do the Baboons pass?
    I want to replace the current Dunlop tyres with BFG and keep the standard size of 265x65x17. Will I be able to fit 265x70x17? If so what is the Pro's & cons beside the small ground clearance benefit?
    I'm a little bit concern about the fuel tank on the side. Will I need rock sliders or will it be ok to just remove the side steps?
    Has anyone done the Baboon pass with a Prado as mine?
    Any other advise will really be appreciated.
    Thanks.
    Anmos van Pretoria
    2007 Toyota Hilux 4.0 DC 4x4 AT
    ARB, TMax Winch
    Full OME suspension
    Air Helpers at the back
    Long Range Fuel Tank
    285x70x17 BF Muds with 30mm Wheel Spacers
    Jan 2009
    Sean Swart
    Toyota LC200
    2018 KTM 300tpi
    2015 KTM 1190 adventure (for fun)
    Thank you!
    Anmos van Pretoria
    ARB, TMax Winch
    Full OME suspension
  1. 232 Mountain Passes
    By malangi in forum 4x4 Trails / Routes / Clubs
    Last Post: 2018/09/13, 01:50 PM
  2. Baboon's Pass Trip Planning
    By Sakkie in forum Lesotho
    Last Post: 2008/12/09, 06:41 PM
