Results 1 to 2 of 2
    Apr 2011
    Booysens Pretoria West
    Thanked: 20
    Default Ford 2.5tdi problem.
    I have a problem with my ford.
    It pulls well with out problem but as soon as you select 3rd gear and start to get at say 3000 to 3200 rpm it starts jerking.
    From there it does this in the rest of the gears as well meaning 4th and 5th so you cant do anything more then 120km/h.
    I fitted a fasset low pressure fuel pump just before the diesel filter and now the problem is gone.
    My main concern is that this only made the problem better but it did not solve the problem because it is not factory standard.
    So what can I replace to solve the problem so the system works like it should?
    Is there a low pressure pump in the tank does the diesel pump have a low pressure side what??
    Danie
    Hoedspruit
    Sounds like fuel starvation. Read the thread below, perhaps it might help.
    http://www.4x4community.co.za/forum/...ad.php?t=47252
    And then it happened ....
    2012 Volkswagen Touareg 3.0 V6 TDi Bluemotion
    Previous:
    2006 Land Rover Discovery V8 HSE
    2009 Ford Ranger 3.0 TDCi Supercab 4x4
    2006 Land Rover Discovery TDV6 HSE
    2005 Mazda Drifter 2.5 D/Cab SLE 4x4
    2004 Ford Ranger 2.5 Supercab 4x4
  1. Ford & Mazda ford ranger starter just clicks
    By corne0002 in forum Ford & Mazda
    Last Post: 2014/10/25, 09:08 PM
  2. How likely is your vehicle to be stolen?
    By mvcoller in forum The 4x4 Pub
    Last Post: 2010/12/18, 03:10 PM
  3. Defender 2002 TD5 Clutch problem. Advice needed.
    By Sabie in forum Land Rover
    Last Post: 2010/02/25, 09:04 PM
  4. Ford 3.0 tdci ranger gearbox replaced
    By NIEKO in forum The 4x4 Pub
    Last Post: 2010/01/29, 08:57 AM
  5. 3.0 tdci ford - gearbox problem
    By NIEKO in forum Ford & Mazda
    Last Post: 2010/01/13, 01:04 PM
