Results 21 to 26 of 26
    May 2007
    Kraaifontein, Cape Town
    Thanked: 18
    OJ you are so funny. Must say currently I ride da beast to work more often due to parking arrangements at home. Beast does not fit into a normal garage bro. Had the merc a year now and only put on 4600km's a bit disgusting hey. However more girls look at da Beast rather than a common old merc, he,hee
    Morton the " BEAST " Berg
    3 Skid plates;75mm lift;275/70/16 Maxxis MT's;Merrit 16”rims;Maxe spots+ night breakers on all lights; Solace protection;TJM snorkel;TJM XGS shocks;TJM coils+Bellows; Maniac front & rear steel bumpers;Spare wheel and 3x Jerry can carriers;Rock sliders;Side awning;Front Runner roof rack; Dual batt system;Procool fridge/freezer;2xGarmin;clinometer;Twin free flow exhaust,Fini comp; ARB independent Airlockers F&B; Winch; Drawer Sys;50Lt Water tank;VHF&29Mhz(2)radios; 8x ss Fish road holders; Safety whip&flag.Future mods,Viper V10or Lex V8 Lumina 6lt
    Jun 2008
    Terenure, Kemptonpark
    Thanked: 364
    I'm going to do my diff this week end, but add Lube later. Then its the actuator thingy!
    Centurion, Pretoria, SA
    Thanked: 1260
    Default A word of caution.
    A word of caution gents - Castrol EP 90 is a GL4 gear oil and is not suitable for most differentials.
    Check the specs for your vehicle (sorry I can't at the moment) and I am pretty sure that as with 99% of all diffs you need a GL5 product ie Castrol EPX SAE 90 or with a LS Diff as mentioned Castrol LSX SAE90. Castrol Gear oils with an "X" are "GL5" and just "EP" are GL4 performance level products. Ie Castrol EP 90 = GL4 and Castrol EPX 90 = GL5
    The GL5 product has twice as much "EP additive" as a GL4. Use a GL4 iso a specified GL5 and you will have serious problems.
    So be very careful - check what is specified for the vehicle and when selecting from the shelf make sure it is the GL4 or GL5 you are looking.
    Remeber SAE 90 specifies the viscosity only (just the thickness)
    The GL no (1 to 6 increasing in additive level) specifies the amount of additve.
    If anyone else is shopping for an axle oil for other vehicles my favourite axle oil is Castrol EPX SAE 85W/140 (seen it at Midas outlets - try a big one I know Centurion has) and is just so good for 4x4 -ers. ie Hilux Pajero etc not requiring a LS oil. Reason being it is a heavier viscosity than SAE 90 and being a heavier viscositynis ideal for those low range obstacles giving a better "cushion" between final drive gear teeth. Is it not too "thick" you ask - Answer is no - we ran trials with a SAE 140 viscosity diff oil in Ford Sierras while developing a product for Gearmax in PE and that was at a constant test speed of 160km/h with absolute normal / excellent wear levels.
    The 85W also gives the 140 gear oil a low temp performace so as mentioned EPX SAE 85W/140 is just so good for you serious offroaders. We had a LS GL5 SAE 140 gear oil but I think my successors have done away with it. So sorry for LS diffs you guys will probably have to settle for LSX SAE 90.
    Oct 2007
    [QUOTE=offroad junky;827765]Now you've got me worried..... I had all the oil changed on the 145 000km service (had them do a 120 000km service again because I didn't know if the previous owner had a proper full 120 000km service done which included ALL oils, engine, gearbox, both diffs and T/C) and I don't recall seeing that redline stuff on the Hyundai service invoice....
    When I get back in SA I'll have to go see the stealer then because Swambo also complained that she felt a shudder every time she'd reverse out the driveway and turned.... I just made it off as the Cooper tyres rubbing on the rubber splash covers in the wheel arch because mine are loose and I still need to tie them down...
    Looking for new tyres now for my 2.9 diesel manual. What size Coopers did you fit? and was it the original rims?
    Dawie
  5. #25
    Jun 2008
    Thanked: 364
    I did the change on the rear diff and now that slip when suddenly accelerating is gone. I'm going to put in a bottle of that stuff to see if it helps as well.
    How long does the torsion bars last? When I turn left or right, it feels as if something gets caught and then comes loose causing the Terry to have a slight jolt only once on the turn? Any advice?
  6. #26
    Jul 2007
    Despatch
    Thanked: 114
    [QUOTE=Boskloof;880806]
    Quote Originally Posted by offroad junky View Post
    Dawie
    Dawie,
    I still have the original rims on but got a set of 245/75 tyres if I can recall correctly...
    Offroad junky
    '24 Ford Ranger Tremor
    '16 Ford Ranger 3.2 auto Wildtrak d/c 4x4
  1. General Pajero Information
    By SimonB in forum Mitsubishi
    Last Post: 2023/04/20, 09:17 PM
  2. Terracan diff whine solved
    By hkleyn in forum Hyundai
    Last Post: 2017/08/29, 06:35 PM
  3. Hyundai terracan 3.5 v6 auto 2005
    By Sweetthorn in forum Hyundai
    Last Post: 2008/11/18, 02:31 PM
  4. Lost Reverse in Auto box
    By LRFan in forum Land Rover
    Last Post: 2007/07/12, 07:20 AM
