Dammit! I have an itch!
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 67
    Jo'burg
    Default Dammit! I have an itch!
    And now I'm even dreaming about it at night, 2 nights in a row now
    But the timing is off! The itch is only supposed to come early 2012 so I can pick up a 2011 demo for a bargain...
    Definitely the 3.6
    At 210kW, it's like the volumetric efficiency of European and Japanese engines.
    The 5.7 at 259kW is just too American.
    SWAMBO even loves it!
    Ai, just the bloody timing
    White, 3.6 Overland or even the Limited will be fine. Around 20k km on the clock, registered "last year".
ID:	90905   Click image for larger version.
ID:	90906   Click image for larger version.
    SWAMBO
    Me
    2003 Ford Focus 2.0
    Eurard: For T=2; T=1 but, 1/2T=
    Bellville
    Thanked: 727
    Quote Originally Posted by RedLineR View Post
    Definitely the 3.6
    Which means it is unstressed and will last forever
    Just do it Red - you know you want to !!
    Middelburg
    Thanked: 74
    Only one thing that can scratch that itch. Buy it.
    Jo'burg
    Quote Originally Posted by ThysleRoux View Post
    hehehehhe, that may be true Thys, but I won't last forever. Don't want an engine outliving me! Jap reliability and longevity is just fine
    After I posted, I thought: You know you're posting this on the wrong forum for sound financial advice And I figured you'd be first
    But I have to be strong! I have to resist! Just for 9 more months!!!!
    SWAMBO
    Me
    2003 Ford Focus 2.0
    Jo'burg
    But just like when I saw the WJ for the first time...
    I think this is the most beautiful SUV on the road today. It's even prettier than the GV.
    Would this then be the "WL"?
    SWAMBO
    Me
    2003 Ford Focus 2.0
    Gordon's Bay
    Thanked: 4378
    Welcome to the Dark side Redliner
    nobody can hold out for long!!!
    the dark side leads to Diesel... Diesel...
    Jo'burg
    They don't put crap engines in these new GCs
    SWAMBO
    Me
    2003 Ford Focus 2.0
    Bellville
    Thanked: 727
    Since when has buying a vehicle been a financial matter ?
    Are you pregnant ?
    Jo'burg
    LOL Thys, you're not helping, you know that!
    SWAMBO
    Me
    2003 Ford Focus 2.0
    Dec 2007
    Harties
    RR, you and me both dude... If you do find a sales guy willing to do some work that is.....
    I like anything with 4 or more wheels...
    Feb 2007
    Randpark Ridge Jhb.
    For some reason they call it the WK2!
    Johan van Niekerk. I can't spell and my grammar sucks, so deal with it!
    2010 Jeep G/C 5.7 V V T Hemi Overland
    2007 Xplorerhttp://www.fuelly.com/dashboard/
    Gordon's Bay
    Thanked: 4378
    NO DIESEL OPTION
    That's OUTRAGEOUS!!
    I thought it was coming with the new V6 biturbo diesel?
    RA 630 DOHC
    A 3.0 L (2,987 cc/182.3 cu in) double overhead camshaft V6, featuring four valves-per-cylinder and common-rail direct fuel injection.
    Applications:
    • 2011 Jeep Grand Cherokee
    Estimated available power: 247 hp (184 kW); torque: 406 ft•lbf (550 N m)
    [edit]
    thats insane.
    by the way Redliner - the V6 may make good power, 210kW and 347Nm vs 259kW and 520N.m. for the V8...
    but the torque is way down. Torque is what does the accelerating bit
    Jo'burg
    Torque (as in wheel torque for acceleration) is gained through gearing.
    kW cannot be made by anything but the engine.
    That's why the petrols still do better in the 0-100 department
    Not to mention the wider rev range
    People put waaaay too much emphasis on engine torque.
    Edit:
    Yes I know I'm over-simplifying. You can roast me about that later. But you understand the gist of what I'm saying!
    Having 8000Nm of torque, means nothing if your rev range is 0-2rpm. That just means you're sitting with about 2kW.
    Having 300Nm of torque means much more if you have a rev range of 1500-6000. That means you have 200kW.
    Yes, I'm too lazy to do the calc to pin down the exact rpm, and work through the drive-train to calc wheel torque and speeds.
    But, an Excel sheet might work a charm.
    In the end, the kW dictates the performance you can achieve via the total driveline ratio. From engine, through gearbox, through final drive, through tyre diameter. The less kW you have, the more limited your options to achieve overall performance.
    PPS:
    Biturbo, just means Bi-cost when it comes to replacing them
    Sheesh! Now I'm stirring!
    SWAMBO
    Me
    2003 Ford Focus 2.0
    Jo'burg
    Quote Originally Posted by Johan View Post
    Thanks Johan!
    SWAMBO
    Me
    2003 Ford Focus 2.0
    Thanked: 568
    347Nm is more than sufficient. Anyway, you don't need torque when you've already got plenty of momentum from the 210 kw . You don't need traction whilst airbourne
    RLR - go scratch the itch & please keep us posted
    Gordon's Bay
    Thanked: 4378
    Edit:
    show me the petrol motor under 3 litres, or even under 4 litres that has 200kW available from 1500rpm to 6000rpm...
    or anything other than a big spike in the torque and power curve and drifts off either side of it...
    Acceleration is a function of the area under the Force at wheel graph vs the SPEED range. and thats a function of torque, gearing and tyre size... nothing to do with power.
    most petrol motors are geared for over 300km/h in top, diesels for 200km/h or so... my diesel will pull 200km/h, I bet a V6 Wrangler won't come near that...
    bit pointless being geared for 300km/h on the road
    Gordon's Bay
    Thanked: 4378
    oh dear. are we back on this again
    I see the GC will be available mid 2011 with the diesel...
    just in time for you to buy one Redline
    Thanked: 371
    Quote Originally Posted by redliner View Post
    but just like when i saw the wj for the first time...
    I think this is the most beautiful suv on the road today. It's even prettier than the gv.
    Would this then be the "wl"?
    rr as they say.......its a jeep thing;d;d;d
    Pajero GLS Exceed 2014 LWB &
    Jeep Cherokee 2001 2.5 Diesel, Gone to Jeep Heaven
    Toyota Hilux, plaas bakkie
    Platkar Swambo's MB
    Thanked: 960
    Kyk ook na die Prado......
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Jo'burg
    hehehehehehe
    I win!
    SWAMBO
    Me
    2003 Ford Focus 2.0
  1. Defender Puma itch, that needs to be scratched.
    By Jacque W in forum Land Rover
    Last Post: 2011/02/16, 08:30 AM
  2. V8 itch won't go away
    By bvandyk in forum Land Rover
    Last Post: 2010/11/30, 11:33 AM
  3. Dammit
    By Rond Loper in forum The 4x4 Pub
    Last Post: 2010/07/09, 06:17 PM
  4. Dammit is is back!
    By Uys in forum The 4x4 Pub
    Last Post: 2008/07/10, 09:49 AM
  5. Dammit, hoe vloek ek nou
    By willysjeep in forum General 4x4 Discussion
    Last Post: 2006/10/06, 07:30 AM
