About 4 days ago when trying to start my Ranger 4l, I was surprised with a run down battery.There was no apparent reason (lights on etc).So we did a running start (fortunately parked on a hill) and drove home.Stopped at home, started engine 3times with no problems and pulled into the garage.Next morning the engine would not turn again, and again it was obvious that the battery was run down.Running started it again in reverse and drove of to the nearest battery centre.Turned out that the battery was faulty and I had it replaced.(The 3 starts the day before probably was too much for it and the short run into the garage not enough to charge).
However now I have a new problem: since the last running start, the yellow RFW light and green 4x4 lights flash alternatively.I'm not even sure whether this is a mechanical or electrical problem.Other than that the bakkie runs fine with no apparent problems.
Any ideas or advise please?
