Jimny Shovel Bracket on Spare Wheel
Results 1 to 12 of 12
    Jul 2010
    Bellville
    Thanked: 22
    Default Jimny Shovel Bracket on Spare Wheel
    Here's what I did:
    I visited a metal retailer/fabricator and asked them for galvanised steel offcuts. They had a large bin for me to rummage through and I eventually dug up some pieces that seemed usable.
    Unfortunately it wasn't free and I had to pay per weight but it was still pretty cheap (no more than a MacDonalds meal).
    I chose a 3mm backing plate (A) which didn't need to be particularly thick or strong.
    I also took a short length of angle iron (B) because it was easy to weld. It didn't need to be exceptionally strong but it was.
    Lastly I picked a short 4mm strip of iron (C) which wouldn't deform too easily.
    At home I cut and shaped everything to length using a hobby angle grinder and a metal file. I then took it to a friend who welded it up for me.
    Then I drilled holes and checked the fit on the vehicle.
    Finally I gave it a good coating of Hammerite's anti-rust metal primer.
    Here's how it works:
    The backing plate needn't be very strong because all it does is touch against the inside of the spare wheel hub, holding the contraption in place. The angle iron passes through the spare wheel hub but does not stick out beyond the tyre (or the horizon of the tyre if you like).
    When I bolt the shovel down using the antennae clamp the shovel is pulled against the tyre wall and held there with friction and pressure exerted by the clamp. So in effect the spare wheel is carrying the shovel, not the shovel bracket which merely secures it into place.
    The shovel weighs practically nothing and doesn't put noticeable strain on the back door or spare wheel mount.
    Thanks to Renard38 for the idea and inspiration. I didn't follow his design exactly because it needed too much fabrication. I wanted something simpler.
    Speaking of simpler; I plan to remove the antennae clamp from the design. I want to drill a hole through the shovel shaft, weld a bolt to the shovel bracket and simply secure the shovel with a big wingnut.
ID:	90085   Click image for larger version.
ID:	90086   Click image for larger version.
ID:	90087   Click image for larger version.
ID:	90088   Click image for larger version.
Name:	Graaf houer.jpg
    Hermanus
    Well done and with a wingnut will be a doddle to use.
    Jun 2008
    Thanked: 7
    Very nice. I like it more than the original
    But...
    Quote Originally Posted by Chris Viljee View Post
    ....or steal
    Suzuki Jimny
    Jul 2010
    Bellville
    Thanked: 22
    Quote Originally Posted by Junior View Post
    ....or steal
    That is true
    but it is also easier to remove the spade during the week and only put it on for trips or weekends.
    I feel a bit like a moron driving around with it all the time
    Why do I have a shovel at all?
    1. To dig the car out when stuck (unlikely)
    2. With no place to keep a hi-lift jack, I can use the spade under a bottle jack to lift the car.
    3. Dig a toilet hole
    4. Carry hot coals from a bonfire to the potjie
    5. Decapitate Zombies and other walking dead
    mmm, what else is there?
    Jun 2008
    Thanked: 7
    Quote Originally Posted by LuckyStriker View Post
    That is true
    That is good to hear, so it is not just about the looks then
    No, I think you kinda covered all the options- Digging, supporting/carrying and decapitating
    Suzuki Jimny
    Jul 2010
    Thanked: 15
    Thanks LS!
    Was it Kingsley Holgate who said that a good spade was all the recovery equipment you ever needed?
    Wilderness
    Thanked: 1171
    Dont drill that handle. That is exactly where it will break.
    I still bear the scars of trying to use such a broken spade in the swamps in Mozambique
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    If you want less screwing unscrewing ;-) bend over the one leg 8-0 let it just hook into the hole and just put the straight leg through the other hole... and screw that one with wingnut... ai... it would require measuring well to work first time...
    Gauteng/ Boksburg
    Thanked: 16
    Brokediff I have no idea what you mean.
    Kemsington, Jhb
    Stunning, I want one. You never know when zombies will appear
    Jul 2010
    Thanked: 15
    I feel like a zombie... Going fishing tomorrow. Just finished packing the Jimny. Think I set a record for how much useless [email protected] one can take camping. Don't have a spade, though. If only I had a bracket to bolt one onto the spare wheel.
    __
    _| |
    The "bent" leg goes through first, then the straight leg with the thread, then that thread is the only thing that gets a wingnut...
    Looks like it may be a bit of a struggle to make everything fit...
  1. Spare Wheel Covers
    By SimonB in forum The 4x4 Pub
    Last Post: 2014/03/27, 05:03 PM
  2. Discovery 3 Spare wheel on bumper
    By alancal in forum Land Rover
    Last Post: 2011/03/23, 12:45 PM
  3. Spare Wheel Carrier - Defender
    By EVH in forum Land Rover
    Last Post: 2010/07/30, 03:50 PM
  4. Jimny Spare Wheel Cover
    By MikeHenry in forum Suzuki
    Last Post: 2009/05/26, 01:06 PM
