Fortuna Replacement Bumper issues
Results 1 to 13 of 13
    Mar 2011
    Joburg
    Default Fortuna Replacement Bumper issues
    I have recently fitted a MCC replacement bumper on my fortuna. Looks very good (similar to the Iron Man), but a couple of isues:
    1. The vertical movement on either end seems excessive. Is this because of the Fortuna's bad suspension, the bumper design or the fitment?
    2. It rattles a bit as well
    3. If you are considering getting chrome plated bull bars bear in mind that the bars surrounding the headlights reflect light when brights are on, which can be a bit annoying
    Thanked: 16
    3. I know some guys stick black material (not sure what exactly they use) on the chromed pipe on the drivers side where the light reflects. Sometimes done so you cant really see it from the front
    Eduan Erasmus-Since 1980- 2016 Merc B200 Cdi2012 Scott Aspect 30 2012 Silverback Roadie
    Quote Originally Posted by NetEddy View Post
    Duct tape works well.
    Thanked: 14
    That excessive movement is due to the bumper moving with the chassis now and the body moving with the suspension, takes some getting used to.
    I was also worried about the reflection, ASKED exactly the same questions! but you get used to it quickly.
    Hilux Dakar & Comfort trailer
    The first 40 years of childhood are the toughest!
    Jan 2011
    Thanked: 2348
    Should the thread not have been titled MCC Replacement Bumper issues? Not the Fortuner that's at fault.
    See the thread entitled;
    Fortuner Replacement bumper
    PS. Post a pic of the Bumper please...
    Jan 2011
    Thanked: 2348
    Quote Originally Posted by Randy View Post
    What?
    The Bumper is bolted to the Chassis.
    The Body is bolted to the Suspension.
    Mar 2011
    Joburg
    Mad Manny. You are quite right. The body and chassis are both joined together. The reason I called it "Fortuna Replacement Bumper issues" is because I didn't have this with my Pajero. My suspicion is that it's due to the "bakkie" type suspension of the Fortuna which is far less comfortable than my Pajero. I'm just hoping I haven't got an inferior bumper
    Klerksdorp
    Thanked: 11
    that bumper movement is something to get used to! looks terrible when you look over the bonnet and the chrome bar shakes all over the place and you know its bolted tight to the chassis.......
    "Blue Thunder"
    Gert Ferreira
    Jan 2011
    Thanked: 2348
    I are confussed.
    My replacement bumper moves as much as the original tupperware?
    Maybe it seems, to you, that it's moving cos you can see it...?
    Spiko, post a few pic's from different angles please...
    Thanked: 1053
    you have a chassis. right
    You have suspension Right.
    So suspension is bolted/pins/ to the chassis.
    Right.
    The body is bolted to the chassis. Right. some rubber spacers to get rid of vibration. Right.
    The bull bar or bumper is bolted to the chassis, right. no rubbers.
    so.
    If there is movement your chassis is busy bending and falling apart.
    The pajero has a different system, no chassis, but integrated system.
    The body is thus not bolted to the suspension cos then you will not need a chassis.
    Uncle manny, oom thys will tell you those nice smelling diesel fumes in the morn is not good for your health!! lol!!!
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    COMBAT19: Large scale fogging and decontamination of coronaviruses
    [email protected]
    [email protected]
    +27824453301
    Thanked: 361
    Spiko, lets see some pics of that MCC Bar?
    Ross
    Jan 2011
    Thanked: 2348
    Default Fortuner Replacement Bumpe
    Herman, I'd understand everything a lot faster if everyone explained it like you do (in other words, like I'm an idiot). NOW I get it, thanks.
    The Tupperware bumper is affixed to the body.
    The 'Taxi-Crusher' to the chassis.
    The difference in movement is due to the NVH prevention measures added to the body but not the 'Taxi-Crusher'.
    Dankie Engeljie....
    Thanked: 1373
    r if everyone explained it I'm an idiot
    Soort soek soort ?
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
  1. Rear replacement bumper - Pajero Gen 3.
    By AndrewR in forum Vehicle & Technical Chat - General
    Last Post: 2009/11/22, 11:13 AM
  2. Replacement bumper advice
    By LandJero in forum Land Rover
    Last Post: 2008/02/26, 10:43 AM
