Engel problem?
Results 1 to 4 of 4
Thread: Engel problem?
    Default Engel problem?
    Hi all
    My Engel works like a charm on 220V as well as 12V in the car. Recently it has been popping fuses (which I am assuming because of the elcheapo plugs I was using).
    Popping of fuses has stopped since I put proper plugs on. Now it melts the fuse.... Why is that?
    "A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster "
    By Jeremy Clarkson (I think)
    Nov 2006
    Hermanus
    The problem can be from both ends. First and cheapest option is to check your 12V supply from the battery. Make sure there are no shorts. Did you fit any power related kit lately? If the supply power is okay, rather take the thing to a repair specialist. I did, R5000 + for a new one is serious money. The termostat started giving problems after jumpstarting another oke and neglected to disconnect the plug.
    FJ Cruiser
    Echo Kavango
    Been thinking.... Does one get "cheap" fuses? The ones I am using now I got for nothing in Pinetown a few weeks back. They look ### and compared to the 35A fuses I got confirm this....
    Any possibility this is my problem?
    Further, if the fridge is faulty, can this happen on the 12V circuit only?
    Check for pinched or damaged cables . Always buy good quality.....might not be the problem.
    [email protected]
    +27824453301
  1. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  2. Quest problem with t4a and streetmaps
    By Johan Barnard in forum GPS & Mapping
    Last Post: 2014/01/01, 04:27 PM
  3. Engel not happy running on 220V . Fine on 12V .
    By PGJ in forum Camping, Fridges, Accessories
    Last Post: 2011/06/25, 01:53 PM
  4. Ford 2.5tdi problem.
    By DJLSchoemm in forum Ford & Mazda
    Last Post: 2011/04/12, 04:44 PM
  5. Toyota Hilux D4D 3.0L D/C 4x2- Handeling Problem
    By NicStix in forum General 4x4 Discussion
    Last Post: 2009/07/29, 12:53 PM
