Results 1 to 6 of 6
    Mar 2011
    Default Fortuner aircon problem
    Hi guys, I'm new to the forum and have been glued to it for the past few days going through all the useful info.
    My vehicle is a 2007 Fortuner 3D4-D and I have a problem when using the aircon. The water that gets created should drip out of the overflow pipe through the passenger footwell. For some reason mine is building up in the bottom of the fan housing and starts dripping onto the passenger side carpet.
    I'm assuming it's a blocked overflow but the pipe seems clear, so before I start taking it a part has anyone had a similar issue?
    Bellville
    Thanked: 1832
    Welcome to the forum Nick
    A friend had a classic experience in December. He took his Triton to the dealers to check something in the drive train .... The ac water kept on dripping on them, so they shoved a sparkplug into the overflow pipe ! Imagine hie surprise to see a sparkplug on his DIESEL vehicle. However, before he figured this out the whole passanger foorwel got drenched with water.
    It is also possible that dust collected and now blocks the pipe.
    Jan 2009
    Linyanti, Botswana.
    Thanked: 268
    Welcome to the forum Nick.
    I had the same problem. Dust becoming mud and then blocking the overflow pipe. Had it sorted by the stealers when I took it in for a service. Not a big issue to sort out at all.
    Toyota Land Cruiser 76SW 4.5D V8
    Toyota Fortuner 2.8GD-6 4x4
    Conqueror Comfort Platinum
    I don't trust anyone who's nice to me but rude to the Janitor. They lack integrity...
    Jan 2009
    Mbabane
    Hey Nick
    To echo Bush Boy- I had a similar problem in my 2008 Fortuner and it turned out to be a blockage. I did the clean up job myself using water pressure from a hose. I disconnected the discharge pipe from within the cabin(from front passenger side) and then flushed it and all was good. I also found a small blockage in the main unit itself where the discharge pipe connects to the unit, which I cleared with a small screw driver.
    The other unrelated problem you may experience is a loss of gas due to a leak caused by rubbing of the pipe that feeds the unit at the back of the vehicle. If you can get under your vehicle and check that the aircon feeder pipe to the rear is clear enough from the engine/gearbox.
    2022 Prado VX-L
    2016 2.2D Rav 4 VX
    2014 Lexus IS350 EX
    Mar 2007
    Thanked: 111
    Talking Bright Spark
    I reckon that Dealer has a bright spark in his workshop now as your mate shoved that sparkplug up an orifice where the sun does not shine??
    Mar 2011
    Thanks for the tips, I'll get my head under the dashboard as see what gives. It's a pain not being able to use the aircon when it's 36 degrees outside.
  1. Fortuner Fortuner Handling: Are you affected?
    By Dirk in forum Toyota
    Last Post: 2017/06/22, 09:22 AM
  2. Aircon problem
    By Johnna in forum Vehicle & Technical Chat - General
    Last Post: 2011/01/19, 07:56 PM
  3. Cherokee Power loss problem at 2000 rpm??
    By Fugs in forum Jeep
    Last Post: 2010/02/10, 09:28 PM
  4. Fortuner aircon trouble
    By KTP in forum Toyota
    Last Post: 2010/01/06, 10:43 PM
  5. Cherokee XJ Aircon not working
    By Biggles in forum Jeep
    Last Post: 2009/07/26, 05:12 PM
