Buff was stuck, they tried to dig it out with the grader which then got stuck and eventually hat to get a TLB in to dig out both.
Sent from my SM-T805 using SA 4x4 Community Forum mobile app
? No one getting stuck?
Quintin Kruse
My YouTube Channel - DIY 4-in-1 Inflator - Prado gear selector pin FIX - Prado TRC Hack
Links on Triton that's sold
DIY Rock Slider Thread - DIY LED Lightbar Thread - DIY iPad Mini Dash Mount
2004 Disco 2 Td5
Suzuki SJ410 (being rebuild)
VW Touran 2.0Tdi
Lotus 7 (replica - not a kit)
The photo doesn't show which route the Amarok took to get into a recovery position. But, more importantly, I learnt that the most important 4x4 accessory is the nut holding the steering wheel.
It's all down to experience and knowledge. I was once recovered by a Fortuner with almost bald tyres but the driver drove rings around me when it came to off-roading.
Henk
So understand
Don't waste your time always searching for those wasted years
Face up, make your stand
And realize you're living in the golden years
Hahahahait was at the Meadows 4x4 in PE on their river section. There are 3 route going up with the easiest on the right and the most difficult on the left. Normally we go up the middle and down the right, so actually quite easy to get up there. The route on the left was new and one of the passengers piped up "let's try that one....". It's a short hill but steep and the sand is soft so I was almost out but also dug myself in right at the end. I'm sure I could've made it if I tried harder but I'm not that windgat as the prado is my daily driver and not my toy
kidding
Amarok impressed me that day but he couldn't make it up that hill at all
I have more recovery gear but all I needed was a very gentle pull![]()
Quintin Kruse
Ex - 2005 Cherokee CRD
Getting stuck is sometimes half the fun and you get to learn more....and a lot of those smart arsses are only smart in hindsight or because they have picked up that first experience
For me it was a learning curve moving from something with a mechanical locker to something with traction control and so I know I'm part of the reason why I got stuck but it was a learning experience and good fun
We all need to keep contributing![]()
Quintin Kruse
Henkus ek het `n volledige recovery kit wat ek baie selde oopmaak. Het twee 12t web slings met rated D-shackels wat altyd agter op saam ry. Gebruik dit 98% van die tyd. Ek kan nie regtig fout sien as iemand wat nie ernstig 4x4 net `n tow strap en shackles saam ry nie. Meeste recoveries is meestal net so `n trek en daar gaan jy.
