Stuck - Page 169
Page 169 of 169 FirstFirst ... 69 119 144 159 160 161 162 163 164 165 166 167 168 169
Results 3,361 to 3,374 of 3374
Thread: Stuck
  1. #3361
    Strand
    Default Re: Stuck
    Hier stem ek 100% saam. Was so rukkie terug Atlantis duine toe. Een ou wat saam was met sy Freelander kon net net nie die duin uitkom nie. Ek heg hom met dewone towstrap gehaak en net liggies getrek om uit te kom.
    In my opinie was 'n recovery strap heeltemal oorbodig in hierdie geval. So ek dink definitief dis nie altyd nodig vir recovery gear nie.
    Henkus ek het `n volledige recovery kit wat ek baie selde oopmaak. Het twee 12t web slings met rated D-shackels wat altyd agter op saam ry. Gebruik dit 98% van die tyd. Ek kan nie regtig fout sien as iemand wat nie ernstig 4x4 net `n tow strap en shackles saam ry nie. Meeste recoveries is meestal net so `n trek en daar gaan jy.
  2. #3362
    May 2013
    Default Re: Stuck
    I agree - it's why I joined the forum. But there is a tactful way of asking a question or pointing something out that you would like to share.
    Yip you are right. Sadly there will always be the troll
  3. #3363
    Mar 2017
    Okahandja
    Default Re: Stuck
    Stuck together at Paaltjies. Click image for larger version.
  4. #3364
    Sep 2011
    Potch/Brits
    Default Re: Stuck
    Quote Originally Posted by Erwin Schimper View Post
    Would really like to hear that story
  5. #3365
    Mar 2017
    Okahandja
    Default Re: Stuck
    All I have in this. Received from a friend Click image for larger version.
  6. #3366
    Wartburg
    Default Re: Stuck
    "one vehicle driving in a 2-spoor track could not give way fast enough for an approaching vehicle due to the thick sand..."
    And this on a big field of sand, with 100s of tracks. They had to chose the same track? No brakes? The front tyres of both vehicles are straight ahead.
    Brown bottles were probably involved.
  7. #3367
    Jun 2017
    GERMISTON
    Default Re: Stuck
    They were headed to the same fishing spot, and were keeping their eyes on the goal
    Quote Originally Posted by carlp View Post
  8. #3368
    Sep 2018
    Not too far from Pofadder
    Default Re: Stuck
    But wait, there is something wrong here, the Hardbody didn't imediately kill all its occupants like the papers said it would.
  9. #3369
    Amorosa
    Default Re: Stuck
    Unfortunately Bartho who was one of the main contributors and kept this thread current passed away.
    He always found good material to post and even though most poked fun at the person that got stuck, there was lots to learn from he postings.
    Is this the guy with his BMW in Namibia? (Think Swakop)? What happened?
    Bush Lapa Miskruier 586
    Youtube Channel: https://www.youtube.com/channel/UCFS..._as=subscriber
  10. #3370
    Default Re: Stuck
    []Is this the guy with his BMW in Namibia? (Think Swakop)? What happened?[/QUOTE]
    Correct sadly.
    https://www.4x4community.co.za/forum...63#post4152363
    2006 Isuzu DMax 300Tdi DC 4x4
  11. #3371
    Langs die rivier, op n berg
    Default Re: Stuck
    Quote Originally Posted by Bex View Post
    Kyk mooi na daai foto. Die hardbody se bonnet doen wat hy moet. Die fortuner sin nie. Daai bonnet wat plat bly na stamp is n groter gevaar...
  12. #3372
    Default Re: Stuck
  13. #3373
    Jan 2010
    Mosselbaai
    Default Re: Stuck
    Lyk of daar n interresante recovery was.
    Jeep Wrangler TJ
    Volvo XC60
    Amarok AWD
  14. #3374
    Default Re: Stuck
    200 cruiser se winch gehak regs agter, en toe gewinch tot 200 begin sleep het. Toe ry ek verder uit
    By charlatan in forum Jeep
    Last Post: 2017/04/15, 11:31 AM
  2. Clutch pedal Stuck rock solid - Defender tdi
    By frogstar in forum Land Rover
    Last Post: 2013/03/27, 07:28 AM
  3. 1, no 2, no 3 vehicles stuck in Bridgemead
    By Dirk in forum Eastern Cape
    Last Post: 2011/10/03, 10:05 AM
  4. Grand Cherokee Error code
    By Nick47 in forum Jeep
  5. Some last resorts when your vehicle is stuck
    By Big Hilux in forum 4x4 Recovery & Recovery Gear
    Last Post: 2006/12/09, 09:13 PM
