Stuck - Page 169
Page 169 of 169 FirstFirst ... 69 119 144 159 160 161 162 163 164 165 166 167 168 169
Results 3,361 to 3,376 of 3376
Thread: Stuck
  1. #3361
    Strand
    Thanked: 242
    Default Re: Stuck
    Hier stem ek 100% saam. Was so rukkie terug Atlantis duine toe. Een ou wat saam was met sy Freelander kon net net nie die duin uitkom nie. Ek heg hom met dewone towstrap gehaak en net liggies getrek om uit te kom.
    In my opinie was 'n recovery strap heeltemal oorbodig in hierdie geval. So ek dink definitief dis nie altyd nodig vir recovery gear nie.
    Henkus ek het `n volledige recovery kit wat ek baie selde oopmaak. Het twee 12t web slings met rated D-shackels wat altyd agter op saam ry. Gebruik dit 98% van die tyd. Ek kan nie regtig fout sien as iemand wat nie ernstig 4x4 net `n tow strap en shackles saam ry nie. Meeste recoveries is meestal net so `n trek en daar gaan jy.
  2. #3362
    May 2013
    Thanked: 130
    Default Re: Stuck
    I agree - it's why I joined the forum. But there is a tactful way of asking a question or pointing something out that you would like to share.
    Yip you are right. Sadly there will always be the troll
  3. The Following User Says Thank You to tintin_85 For This Useful Post:
  4. #3363
    Mar 2017
    Okahandja
    Thanked: 688
    Default Re: Stuck
    Stuck together at Paaltjies. Click image for larger version.
  5. The Following User Says Thank You to Erwin Schimper For This Useful Post:
  6. #3364
    Sep 2011
    Potch/Brits
    Thanked: 581
    Default Re: Stuck
    Quote Originally Posted by Erwin Schimper View Post
    Would really like to hear that story
  7. The Following 3 Users Say Thank You to carlp For This Useful Post:
  8. #3365
    Mar 2017
    Okahandja
    Thanked: 688
    Default Re: Stuck
    All I have in this. Received from a friend Click image for larger version.
  9. The Following 2 Users Say Thank You to Erwin Schimper For This Useful Post:
  10. #3366
    Wartburg
    Thanked: 1194
    Default Re: Stuck
    "one vehicle driving in a 2-spoor track could not give way fast enough for an approaching vehicle due to the thick sand..."
    And this on a big field of sand, with 100s of tracks. They had to chose the same track? No brakes? The front tyres of both vehicles are straight ahead.
    Brown bottles were probably involved.
  11. #3367
    Jun 2017
    GERMISTON
    Thanked: 51
    Default Re: Stuck
    They were headed to the same fishing spot, and were keeping their eyes on the goal
    Quote Originally Posted by carlp View Post
    Pieter Du Plessis
  12. #3368
    Sep 2018
    Not too far from Pofadder
    Thanked: 357
    Default Re: Stuck
    But wait, there is something wrong here, the Hardbody didn't imediately kill all its occupants like the papers said it would.
  13. The Following 3 Users Say Thank You to Bex For This Useful Post:
  14. #3369
    Amorosa
    Thanked: 359
    Default Re: Stuck
    Unfortunately Bartho who was one of the main contributors and kept this thread current passed away.
    He always found good material to post and even though most poked fun at the person that got stuck, there was lots to learn from he postings.
    Is this the guy with his BMW in Namibia? (Think Swakop)? What happened?
    Bush Lapa Miskruier 586
    Youtube Channel: https://www.youtube.com/channel/UCFS..._as=subscriber
  15. #3370
    Thanked: 171
    Default Re: Stuck
    []Is this the guy with his BMW in Namibia? (Think Swakop)? What happened?[/QUOTE]
    Correct sadly.
    https://www.4x4community.co.za/forum...63#post4152363
    2009 VW Touareg 3l V6 TDi
    2006 Isuzu DMax 300Tdi DC 4x4 (sold)
  16. #3371
    Langs die rivier, op n berg
    Thanked: 2689
    Default Re: Stuck
    Quote Originally Posted by Bex View Post
    Kyk mooi na daai foto. Die hardbody se bonnet doen wat hy moet. Die fortuner sin nie. Daai bonnet wat plat bly na stamp is n groter gevaar...
  17. The Following 3 Users Say Thank You to Reenen For This Useful Post:
  18. #3372
    Thanked: 2689
    Default Re: Stuck
  19. The Following User Says Thank You to Reenen For This Useful Post:
  20. #3373
    Jan 2010
    Mosselbaai
    Thanked: 492
    Default Re: Stuck
    Lyk of daar n interresante recovery was.
    Jeep Wrangler TJ
    Volvo XC60
    Amarok AWD
  21. #3374
    Thanked: 2689
    Default Re: Stuck
    200 cruiser se winch gehak regs agter, en toe gewinch tot 200 begin sleep het. Toe ry ek verder uit
  22. #3375
    Jun 2016
    Randfontein
    Thanked: 1561
    Default Re: Stuck
ID:	562783Click image for larger version.
    Today was my turn. Lucky for a bypassing farmer with an SFA Hilux Lexus V8. If they say “ons kort eintlik n trekker” then you know you are properly stuck.
    Willie
    2016 Audi A3 1.8 TFSI SE S-Tronic 3Dr
  23. The Following User Says Thank You to FWM For This Useful Post:
  24. #3376
    Mar 2013
    Kirkwood
    Thanked: 98
    Default Re: Stuck
    There was pipe leak in the orchard, driver could not have known.
    Kubota 4x4 tractor, nose uphill
    Trees 6m apart
    That tank has 3000L Spray mix in it....
    Tried digging out, almost worked.
    Help arrived in the form of our JCB.
    Then the TLB couldn’t get the last 2 m to the trailer, also too wet.
    So, he had to use backhoe to push himself to get main bucket under the back of the trailer.
    (Towing was not going to work)
    Careful reverse maneuver out of orchard
    (TLB with 3 ton+ trailer in its bucket, and a tractor)
  25. The Following 2 Users Say Thank You to Fatcat256 For This Useful Post:
    By charlatan in forum Jeep
    Last Post: 2017/04/15, 11:31 AM
  2. Clutch pedal Stuck rock solid - Defender tdi
    By frogstar in forum Land Rover
    Last Post: 2013/03/27, 07:28 AM
  3. 1, no 2, no 3 vehicles stuck in Bridgemead
    By Dirk in forum Eastern Cape
    Last Post: 2011/10/03, 10:05 AM
  4. Grand Cherokee Error code
    By Nick47 in forum Jeep
  5. Some last resorts when your vehicle is stuck
    By Big Hilux in forum 4x4 Recovery & Recovery Gear
    Last Post: 2006/12/09, 09:13 PM
