Namibia Road Updates
Page 1 of 18 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 20 of 356
    Swakop
    Thanked: 474
    Default Namibia Road Updates
    Hi Guys
    As you know in the rainy season our road conditions change quite a bit. As I get updates from around the country I will post.
    10 Feb 2011
    • C14 UPDATE (Namib - Gaub Pass between Walvis Bay & Solitaire)
      The Gaub River is running and the Gaub Pass is closed. Please take the C14 from Walvis Bay over the Kuiseb Pass and turn onto the C26 towards Windhoek. Drive over the Gamsberg Pass and turn right into the D1265. Then take the D1261 to Nauchas. If the traveller has a 4x4 take the Spreetshoogte Pass, otherwise continue on the D1265 to the C24. Turn towards Windhoek into the C24 and take the MR47 to the C14. Take the C14 to Solitaire.
    • D3700 UPDATE (North - Between Ruacana & Kunene River Lodge)
      The road still has a lot of areas with deep water and although there are detours, these are in a very bad condition. A 4x4 with an experienced driver is required. It is advisable to drive to Kunene River Lodge on the C43 from Opuwo.
    • C13 (South - Between Helmeringhausen & Aus)
      The road is in a poor condition. A 4x4 is recommended. Please drive slowly.
    • C13 (South - Between Rosh Pinah & Aus)
      The C13 between Aus and Rosh Pinah is in very good condition.
    • C13 (South - Between Rosh Pinah & Noordoewer)
      The C13 between Rosh Pinah and Noordoewer is closed due to severe damage.
    Also apparently no access to Sossusvlei the last 2 days.
    "Meerkat"
    Namboyz
    modded 02' 105 series 4.5efi (big wheeled petrol thief)
  2. The Following User Says Thank You to AboutAfrica For This Useful Post:
    Swakop
    Thanked: 474
    Default the last few weeks
    Other updates over the last few weeks, please note this is info circulating in the tourism industry, I take no responsability should the info not be correct, road conditions can also change on a daily basis.
    D1206
    Between Rietoog & Büllsport
    The D1206 is in a very bad condition.
    ALTERNATIVE: take the MR47 between Rietoog and Nabaseb.
    08.02.2011
    C24
    Remshoogte Pass between Rehoboth & Solitaire
    Remshoogte Pass is CLOSED.
    08.02.2011
    07.02.2011
    D1275
    Spreetshoogte Pass
    Spreetshoogte Pass 4X4 only. Drive slowly!
    07.02.2011
    C19
    Between Solitaire & Sesriem
    The Tsondab River is flowing and travellers should please follow the road signs for the detour.
    07.02.2011
    C14
    Gaub Pass is CLOSED.
    ALTERNATIVE: From Walvis Bay take the C14 over the Kuiseb Pass and turn onto the C26 towards Windhoek. Drive over the Gamsberg Pass and turn right into the D1265. Then take the D1261 to Nauchas. If the traveller has a 4x4 take the Spreetshoogte Pass, otherwise continue on the D1265 to the C24. Turn towards Windhoek into the C24 and take the MR47 to the C14. Take the C14 to Solitaire.
    08.02.2011
    07.02.2011
    C14
    Between Solitaire & Maltahöhe
    The C14 between Solitaire and Maltahöhe is very wet and slippery. Drive slowly!
    08.02.2011
    20.01.2011
    C13
    For the C13 between Helmeringhausen and Aus a 4x4 is recommended. Please drive slowly!
    08.02.2011
    C13
    Between Aus & Rosh Pinah
    The C13 between Aus and Rosh Pinah is in good condition.
    08.02.2011
    04.02.2011
    C13
    The C13 between Rosh Pinah and Noordoewer is CLOSED.
    08.02.2011
    04.02.2011
    B3
    Between Ariamsvlei & Karasburg
    The B3 tarred road is CLOSED.
    ALTERNATIVE: Enter Namibia via Botswana or Noordoewer. Detours are expected to be constructed on the B3 by 09.01.2011.
    07.02.2011
    D463
    Road to Fish River Lodge and Vogelstrausskluft Lodge
    The D463 is damaged, but is passable. Please drive carefully and slowly!
    04.02.2011
    C12
    Between Seeheim & Holoog
    Part of the C12 is CLOSED. ALTERNATIVE: take the B4 from Keetmanshoop and turn into the D545. The road bypasses the closed area and re-joins the C12.
    04.02.2011
    21.01.2011
    C15
    Between Stampried & C17
    The road is wet and slippery. Please drive slowly!
    27.01.2011
    D1268
    Between the C21 & the C20
    The D1268 is flooded in places. Please drive to Bagatelle from Mariental and not from Kalkrand. Please drive slowly!
    08.02.2011
    25.01.2011
    C39
    Between Khorixas & Twyfelfontein
    The C39 between Khorixas and Twyfelfontein is in a very bad condition.
    ALTERNATIVE: Just east of Khorixas take the C35 south and turn onto the D2612 till you reach the Aba-Huab River. From here follow the road sign to the D3254 and to Twyfelfontein.
    08.02.2011
    C43
    Between Epembe & Epupa Falls
    Parts of this road are in a very bad condition.
    4x4 only
    C43
    Between Sesfontein & Opuwo
    4x4 only
    ALTERNATIVE: use the C35 from Kamanjab to Opuwo.
    08.02.2011
    25.01.2011
    D3700
    4x4 only.
    ALTERNATIVE: take the C43 from Opuwo to Epembe. From Epembe take the D3701 to the D3700 and Kunene River Lodge.
    08.02.2011
    20.01.2011
    M125 / C49
    Between Kongola & Katima Mulilo
    The C49 / M125 is very wet and slippery. 4x4 only
    There are road signs indicating a detour to Namushasha Country Lodge. Please drive slowly!
    25.01.2011
    C44
    From the B8 turn off to Tsumkwe
    The C44 is very wet and slippery. Please drive slowly!
    Several of the smaller roads around Tsumkwe are in a very bad condition. A 4x4 is required and caution should be exercised before crossing any flooded roads.
    25.01.2011
    "Meerkat"
    Namboyz
    Ladismith W/C
    Thanked: 8
    Pleeeeeeeese keep this updated, will be doing this area in 2 weeks time, Koes to Sossus and up to Xhorigas
    Lindsay Cameron
    Swambo MitsuOutlander
    The severity of an itch is determined by it's inaccesabilty
    Swakop
    Thanked: 474
    Quote Originally Posted by Milkman View Post
    Will try my best
    Will post what I hear when I hear.
    "Meerkat"
    Namboyz
    This is a great service.. please try to keep it up!!
    Pejeci
    2007 (Gen 4) Pajero 3.2 DiD GLS LWB
    Merc C270cdi
    Thumbs up
    Extremely valuable. you guys are doing a fantastic job!
    Nov 2006
    Piet Retief
    Thank you
    Vince Aslett
    2013 Pathfinder 2.5
    2011 Sprite Tourer SP
    2014 Venter Bush Baby
    Jan 2009
    Potchefstroom
    Thanked: 186
    Wat van die ferry by Sendelingsdrift?
    Ek kom die 21ste Maart van Swakop af en slaap oor op Aus en wil van daar af oor Rosh Pina na die Richtersveld.
    Sal mens dalk deur Oranjemund/Alexanderbaai kan oorgaan?
    Jan 2009
    Potchefstroom
    Thanked: 186
    Ek kry nou-net 'n e-pos wat wys dat die pad tussen Karasburg en Keetmans ook weggespoel het.
    Kan enige iemand bevestig?
    Swakop
    Thanked: 474
    should be getting new updates today.
    "Meerkat"
    Namboyz
    Swakop
    Thanked: 474
    Not Much new.
    The D2351 and and D2403, between Khorixas and Omaruru so to say, are all only 4x4 at the moment, as is the C39 direction Palmwag, and the Aba-huab river crossings at twyfelfontein. The C40 for by Grootberg Pass are also better with 4x4 as the roads are wet and slippery.
    "Meerkat"
    Namboyz
    Swakop
    Thanked: 474
    Also worth keeping an eye on:
    www.resafrica.net/namibian-roads/
    "Meerkat"
    Namboyz
    Thanked: 2739
    Default Road conditions in rainy Northern Namibia !
    My 2 cents worth. Just returned today after 3 weeks in Koakoland. Some of my info is therefore 2 to 3 weeks old. It is starting to rain heavily in the centre of this region, but as yet minimal rain in North-western Namibia. Due to change any day now.
    Travelling in this area now should only be done in a well-equiped 4x4 as conditions are worsening and lots of rain is expected.
    1) Ruacana to Kunene River Lodge.
    Kunene is flowing strongly but no gross flooding as of 3 weeks ago. The Angolans have opened the dam floodgates early to prevent the sudden floods of a couple of years ago. We took this route along the river, 5 water crossings in all, most of them short, deepest at knee level. Firm stony bottem to ride on. Also about 5 "detours" around deeper crossings, fairly hairy up steep slopes of boulders with some scary sideslopes but in a suitable vehicle- no problems.
    2) Kunene River Lodge to Epupa Falls
    We were advised by Pete Morgan owner of K. R. Lodge that the route along the river probably not passable now. He is very clued-up and if you phone him at the lodge he will gladly supply the latest info. We took the inland route, no problems.
    3) Very little rain in North-western Koakoland up to 2 weeks ago but may have changed. If you get stuck, there are very few other travellers in this area at this time. The river routes around Puros and Sesfontein were fine last week. The rivers are flooding but subside overnight. There is lots of rain in Damaraland. We managed the river routes down the Hoarusib and Hoanib rivers only getting stuck once, entirely my own fault. The Huab river is having lots of flash floods but by the next day has dried completely. Fortunately these river beds are of coarse sand with very little mud so crossing is not a problem if the water depth is safe.
    4) The B3 road to the Ariamsvlei/ Nakop border post is now open again after parts of the tar road were washed away last week. There are dirt road detours around the few areas where the road was destroyed. With further rain expected I am sure it will be closed from time to time. It is going to take some months to repair this road.
    Please do not allow any of the above to deterr any planned visit, seeing this beautiful country dressed in green is a wonderful sight. Just be flexible and careful and seek up to date local knowledge along the way.
    Stan.
  15. #14
    Swakop
    Thanked: 474
    Apparently all roads etc in the south open again for the moment, certain passes only 4x4 though. Will post if anything changes.
    "Meerkat"
    Namboyz
  16. #15
    Swakop
    Thanked: 474
    Ok, latest confirmations
    C24 Remhoogte pass 4x4 only
    Sossusvlei, road from 2x4 parking area to Vlei still closed to vehicles.
    "Meerkat"
    Namboyz
  17. #16
    Swakopmund
    we are going to Sossus this weekend - we are in a 4x4, but our friends are in a VW Kombi. will the Kombi be able to do the trip down from Windhoek to Solitaire ? we plan on going down Spreetshoogte (C26) and back up C24 to Rehoboth.
  18. #17
    Gerdau
    Hi there.
    We are planning a trip to Damaraland in middle March. We are planning to travel through Mata-Mata, Gochas, Stampriet and onto the mainroad at Hardap. Does anyone know the road conditions of these roads?
  19. #18
    Swakopmund
    Japie,
    I will be able to tell you a bit about this on Monday as we have friends driving the Stampriet road (to Gobabis) on Sunday.
  20. #19
    Swakop
    Thanked: 474
    for the time of year it always difficult to give exact road conditions as they could be bad, they get fixed and all is well, it rains and it back to bad. The roads change overnight in the rainy season.
    "Meerkat"
    Namboyz
  21. #20
    Swakopmund
    Hi Triple A !
    had any updates about the road to Sossusvlei yet ?
    thanks
  1. Namibia Road Trip June 2013
    By KampGat in forum Namibia
    Last Post: 2013/05/30, 05:48 PM
  2. Replies: 9
    Last Post: 2013/01/15, 09:39 AM
  3. Namibia - Road Side Assistance
    By micro101 in forum Namibia
    Last Post: 2012/08/10, 08:41 PM
  4. Botswana - Zambia Trip Report - July 2009
    By Paolo Candotti in forum Zambia
    Last Post: 2011/08/03, 02:40 PM
  5. Our trip to Namibia via Botswana
    By jaypee44 in forum Botswana
    Last Post: 2009/12/21, 01:16 PM
