BT-50 not starting
Results 1 to 7 of 7
    Jan 2011
    Bela Bela
    Default BT-50 not starting
    I am having a problem on one of my BT-50's, when I get in and turn the ignition on, all the dashboard lights come on, glow plug light comes on, then when I turn the key to start it its dead. Then if I switch it off and try again a few times it starts normally, and is fine for a couple of days. I've had the workshop at the place where i work look it over and they can't find anything wrong. Anyone have any advice or experienced similar problem?
    Would appreciate any help!
    Dec 2007
    Harties
    Quote Originally Posted by BCJ View Post
    Have the battery tested...
    And welcome to the forum
    I like anything with 4 or more wheels...
    I have just spoken to my old man who runs a bt-50 , he also has similar issues occasionally .
    Ford/Mazda are unable to assist/diagnose the problem .
    He has narrowed it down to the central locking / key system .
    He advised to manually lock the doors before starting . He didnt recall the exact sequence , but said that locking the doors manually usually gets the vehicle going .
    Im sure it has nothing to do with the door locks itself , however its a sequence that needs to be completed with the security system .
    Good luck , please give us feedback .
    Jan 2011
    Bela Bela
    Thanks for the feedback! I'll give it a try. I'm going to see if Rustenburg Ford/mazda can figure it out on its next service ( Which I doubt!)
    I'll let you know if they by some miracle manage to accomplish anything.....
    Also, does your Dad have any problems with his airbag light? Both of mine keep illuminating and I've had the one looked at 3 times - I've just decided to live with it now.
    We all have problems with our airbag light , Ive got the ranger and it also gives me hassles occasionally . Look under the ford section here ,
    http://www.4x4community.co.za/forum/...+ranger+airbag
    there is lots of info regarding the airbag light .
    Jan 2011
    Bela Bela
    Awesome thanks! Just managed to fix the airbag light problem on the double cab! But I can only find the airbag plug on my single cab under the drivers seat. Any idea where the plug is for the passenger seat?
    Really drives me insane now knowing how easy it is, and last time I took it in to Mazda, they kept it there for 5 hours just to do that!
    Thanks again!
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 190
    Guys had the same starting problem with my 2010 Ranger.
    The replaced the sensor around the key switch, apparently they go faulty and it does not sence the correct key. Had me anoyed abit, thee ar eno way you can bypass the safety system on the new ones. What if I am stuck in the middle of nowhere!
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
  1. Air con prevents engine from starting
    By October in forum Vehicle & Technical Chat - General
    Last Post: 2010/10/22, 01:27 PM
  2. Hard starting & smoking Treg
    By Trevor in forum Volkswagen
    Last Post: 2010/09/27, 03:43 PM
  3. Defender Td5 Starting Problem
    By ouranios in forum Land Rover
    Last Post: 2010/03/10, 07:49 AM
  4. More starting problems
    By Duka in forum Mahindra
    Last Post: 2010/03/08, 03:44 PM
  5. Grand Cherokee Hard Starting
    By fouriea in forum Jeep
    Last Post: 2009/06/23, 03:31 PM
