Dual Battery System for Range Rover Classic
Results 1 to 8 of 8
    Oct 2006
    Walmer Heights, Port Elizabeth
    Thanked: 59
    Default Dual Battery System for Range Rover Classic
    hi
    i have a 1980 Range rover classic,
    i have a winch that i would like to install.
    there is an seperate earth wire already installed in the engine bay.
    apparently all i have to do is connect a battery up to this earth wire and then run
    a cable from the positive of the spare battery to the positive of the main battery,
    any suggestions?
    1999 Colt Rodeo 3.0 V6 4x4-Build
    1998 Pajero Gen 2 SWB 3.0 V6 4x4-Resurrection
    1997 Ford Ranchero Outback 4.0 - Build
    SOLD
    1979 Landrover Series 3 88" Ford 3.0 V6 - Build
    1980 Landrover Range Rover 3.5 V8 - Build
    1979 Landrover S2A 109" with Chev 4.1
    Alicedale
    I dont really know much about this. I would get a NL dual battery system from Echo4x4 in PE. Cant recall the price but extremely simple to install and very cheap compared to the others.
    Its also far safer than the system you have in the above.
    '16 Toyota Land Cruiser D/C v8
    '15 Toyota Hilux 3.0D4D
    Pune
    Thanked: 49
    If it's for the winch, I wouldn't bother......I ran my cruiser with a single battery and the KEW winch, and never had any issues. The dual battery system is useful if you have a fridge and there car stands with the fridge running. In that case, just connecting the poles won't help because you'll kill both batteries. Also not sure if your altenator can charge both at the same time.
    Oct 2006
    Thanked: 59
    i have done what Zantus said.
    works fine.
    have not done any major tests yet.
    SOLD
    Ladismith western cape
    Remember the following,
    1. Two batts connected in parrellel will run each other flat in a month or
    so, therefore any time spent without charging will take power out of
    each batt, the longer the time the more the loss!
    2. Standard alternators can not handle charging both batts at same time
    especially just after starting engine. They will look as if they are
    managing but you WILL blow it in the long run.
    3. Ideal second batts are deap cycle type, NOT suited to start an
    engine.
    4. How often do you use a winch If you do not draw power out the
    batt then you do NOT whant to keep charging it. Overcharging
    kills a batt!
    5. At the end of the day do it properly, either yourself as I did, but then
    you need to know something about what your doing, otherwise let
    people like LA sports or Cris Ingram R&D Offroad do it , they are not
    just a prity face. ha ha!
    Well thats just my opinion anyway !
    Quote Originally Posted by Racer-X View Post
    hi
    any suggestions?
    Oct 2006
    Thanked: 59
    I don't use the winch often.
    so it does not discharge the battery.
    i also do not use the winch without the engine running.
    SOLD
    Feb 2007
    melkbosstrand
    Thanked: 133
    Quote Originally Posted by karoo landy View Post
    engine.
    why is this?
    Current: Toyota FJ Sport Cruiser
    Previous: VW Amarok ULTIMATE 4motion (auto)
    Previous: Amarok 4motion (MT) with a few goodies
    Previous: Isuzu KB300 Dteq 4x4 not that many goodies
    Prevous: Isuzu KB360 4x4 with a few goodies
    Montclair Durban
    It has to do with the plate thickness and differing discharge rates, the LROC club KZN has a few items on the subject. You would like to know I fitted 2 deep cycle batteries, with 1 relay and 1 switch. yes it relies on my memory, but it works. I also upgraded my alternator to a 70 A one. 2 years later no problems yet.
    '79 Range Rover classic.
    Now sadly sold.
    88" series 3"Littlemule"my first diesel.No more Landys, all sold
  1. CTEK Dual Battery system and National Luna Power Pack
    By Celtic Angler in forum Camping, Fridges, Accessories
    Last Post: 2014/04/04, 09:08 AM
  2. Dual Battery System for Discover 4
    By Celtic Angler in forum Land Rover
    Last Post: 2012/05/14, 02:03 PM
  3. Dual Battery System
    By C J in forum Camping, Fridges, Accessories
    Last Post: 2011/08/19, 12:21 PM
  4. Voltage Drop Dual battery System
    By bushhappyfred in forum Camping, Fridges, Accessories
    Last Post: 2011/01/25, 07:30 PM
  5. Grand Cherokee Error code
    By Nick47 in forum Jeep
