Results 1 to 3 of 3
Thread: Gear Ratios
    Nov 2006
    Question Gear Ratios
    Hi guys
    Can someone help explain gear ratios...
    For Example, if Vehicle A has a 1st gear ratio of 1, and Vehicle B has a 1st Gear Ratio of 1.5, which 1st gear will be the one with more pulling power ?
    alos what is meant by the final drive ratio ? diff/gearbox ratio combined ?
    Ross.
    1995 Toyota Land Cruiser 80 VX - 1HD-FT Manual
    2011 Mission Jupitor Trailer with a list of goodies that is growing...
    http://public.fotki.com/RossS/
    Mozambique/Cape Town/Other
    Thanked: 27
    1.5 will have more pulling power. The bigger the number= the LOWER the ratio= more grunt. The proper term is torque multiplication. The grunt of your motor is being multiplied by the gear ratio.
    Final drive is your diff.
    * "Wat Spike probeer sê in sy min woorde" -Die Skim "
    Nov 2006
    Thanks !
    much appreciated
    By charlatan in forum Jeep
  2. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  3. Mazda Drifter 2.5TD gear ratios
    By pardus in forum Ford & Mazda
    Last Post: 2011/09/26, 03:01 PM
  4. Changed gear ratios?
    By dph in forum Mitsubishi
    Last Post: 2011/07/25, 10:43 PM
  5. 2008 wrangler crd gear ratios
    By ignoramus in forum Jeep
    Last Post: 2010/06/20, 03:31 PM
