Results 1 to 12 of 12
    East of PTA
    Post Source of Radiator water
    Hi
    Can I use bottled water (Nestle Pure Life) for filling the radiator?
    Otherwise, where is the best place to get water for the radiator?
    Rangeview Krugersdorp
    Thanked: 1662
    A tap ?
    Ford Figo 2016
    Gordon's Bay
    Thanked: 4378
    "the source of radiator water"
    sounds like the new Tomb Raider movie!!!
    is this a trick question?
    you can use the tap. water from a stream. at a push muddy dam water will be okay!!
    just put antifreeze in it if you are putting a significant amount in... top ups just plain old water....
    I don't think even Rolls Royces get bottled water in their radiators!!!!
    Gaborone, Botswana
    Thanked: 1671
    I'm sure the purified water will be fine. Remember to keep the water/anti-freeze in the correct ratio.
    I always use straight from the hosepipe (municipal supply).
    A cooling system in good order, should not loose water.
    Kobus
    Would there be an advantage to distilled water?
    Godzilla - 1997 Range Rover 4.6 HSE
    Monty - 1972 Series 3 LWB (moved on)
    "Life's tough. It's even tougher if you're stupid."
    -John Wayne
    De Kelders
    Thanked: 135
    I always keep a 2L bottle of 50% anti freeze handy for top ups if and when needed. The water part is straight from the tap.
    East of PTA
    According to some well respected forum members you should use distilled water:
    http://www.4x4community.co.za/forum/...led#post573649
    http://www.4x4community.co.za/forum/...led#post562442
    Of course, having the correct ratio of antifreeze is important, probably more so than the water source. 50% a good ratio for SA?
    Gordon's Bay
    Thanked: 4378
    I seriously would not worry about using distilled water.
    bottled water has minerals and salts in it ANYWAY - it's different to distilled water which is pure water....
    Anti Freeze - you should check your manual, mostly glycol based anti freezes are the norm. 50% is usually recomended, not REALLY required here though... if it's a bit watered down it's not going to hurt, tops ups at the gargae from their oily old bucker has never harmed a car!!!
    Bethlehem
    Thanked: 174
    Why not just buy the pre-mixed antifreeze for top-ups, i.e. already mixed in the correct ratio like tha caltex ones
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
    Thanked: 1662
    PS , bottled water is filthy !!! Don't you believe You magazine ?
    Ford Figo 2016
    May 2007
    My late Father only used rain water from the water tank, as it did not contain Chlorine. But, then, his '46 Chev Fleetmaster did not use antifreeze either.....
    I am not a complete idiot - there are still some parts missing
    Please don't send me a PM without direct contact details
    97 SVM 3000
    86 HiLux D/C
    Ballito
    hmm, I use rain water, but i dont have municipal. Its out of a borehole, and leaves heavy scale on anything hot.
    Basically clean water, and try not to mix different antifreezes.
    I have uses premix, it just gets expensive.....
    1997 Cruiser 1HZ - New Toy
    2003 Lexus IS200 - Daily
    2006 Alfa Romeo GT 3.2 - Trouble Maker
  1. Surface mount 12volt socket - where to source?
    By bearman in forum Camping, Fridges, Accessories
    Last Post: 2010/07/30, 01:57 PM
  2. SARS Source code
    By Uys in forum The 4x4 Pub
    Last Post: 2009/08/26, 08:46 AM
  3. Garmin - Cigarette lighter power source
    By Paul Venter in forum GPS & Mapping
    Last Post: 2009/04/15, 06:50 PM
  4. Printable maps from Map Source
    By Tricky Dicky in forum GPS & Mapping
    Last Post: 2008/10/15, 11:08 PM
