Proud of your softy place your 4x4 pic's here - Page 4
Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 61 to 80 of 211
  1. #61
    Langs die rivier, op n berg
    Thanked: 2663
    My softroader
    Atlantis
    Molopo
    Rostock ritz
    Duin 7
    Pelican point walvis baai
  2. The Following User Says Thank You to Reenen For This Useful Post:
  3. #62
    Earth
    Thanked: 1941
    ok here is few pictures of my Sunday trip to De Wildt
    We forgot camera so wife used my S3 to take pics
    I did both major axle twisters up and down but unfortunately my wife did not get pictures of me going up first one
    2007 Subaru Forester 2.5XT
    (most people don't agree)
  4. #63
    Earth
    Thanked: 1941
    second one up
    so try again
    and then rocky bit
  5. #64
    Rustenburg
    Thanked: 119
    Default Get ready
    For some flack!
  6. #65
    Riebeek west.
    Thanked: 17
    Veneficus, now thats a Softy
    Commander XK CRD GDE HOT tjoon - Strong like bull.
    OME, big tires, blah blah
  7. #66
    Apr 2008
    Haha, Andrew.......I was waiting and you are first! Flack is fine. Just a pity the flack did not result in the recovery. This happened on the track above the beach.
    Please keep one idea in mind...........you do not argue with the only person available to assist you. If he knows better and the ball will in all probability goes in his direction if it snaps, then he knows better. With the knowledge from this forum, as to what can happen, it was decision time. Abandon and wait for a week or attempt recovery with what is available, as safe as possible
    Then you also look at what is available. Rather use the old frayed strap that will hopefully give way before the ball, than any of the new straps. Also no snatch or jerking but ten abled bodies to push were available.
    This was also the second party that came to the recovery. The first got bogged down 200m from where we got stuck and in attempt to free himself, damaged his own vehicle's drivetrain. The eventual recovery was done only after the second vehicle got stuck across my tracks and had to be assisted by 11 people, to turn it around.
    It was also discovered that this VW did not have the recovery hook connection as the earlier model had on the rear. The supplied hook can only be used in front on this model.
    It is generally called a "learning curve". My mistake was to drop the speed and momentum when I started to appreciate the view and surroundings. This knowledge and experience came in handy when we did Sodwana beach in April this year. The vehicle can do it and be sure to know your vehicle's and your own limitations and capabilities.
    We will be visiting Kagga Kamma in December and I believe there are a couple of sandy patches to try......
    Andre ZR6AGA 8)
    2009 VW Tiguan 1.4 TSI Field & Track
  8. #67
    Feb 2013
    Melkbosstrand
    Hartenbos
    Sent from my Nexus 7 using Tapatalk 2
ID:	247563   Click image for larger version.
ID:	247564   Click image for larger version.
    Dusty
  10. #69
    Pune
    Thanked: 60
    Two videos of my Panda 4x4 Climbing, which is aguably the softest of the softroaders
    http://www.youtube.com/watch?v=1PdNmVG3vhw
    http://www.youtube.com/watch?v=f1ivK7i2Y6E
  11. #70
    Thanked: 568
    Quote Originally Posted by Barto View Post
    Two videos of my Panda 4x4 Climbing, which is aguably the softest of the softroaders http://www.youtube.com/watch?v=1PdNmVG3vhw http://www.youtube.com/watch?v=f1ivK7i2Y6E
    Impressive. When did you get a Panda?
  12. #71
    Pune
    Thanked: 60
    Neil, I got it about two months ago....will be bringing it to Atlantis sometime in the next few months.
  13. #72
    Thanked: 568
    Whats it got in terms 4wd system? CDL right?
  14. #73
    Pune
    Thanked: 60
    Viscous coupling in the centre, which works pretty quick....turn a tight circle on tar too quickly and you can feel it working. The Diff ratio is higher than the 2wd version for extra bit of grunt in gears 1 to 4, with 5th taller than the 2wd.
    Engine wise....well....it's only got 44kW
    It's horribly bad off-road, but good fun, puts a smile on my face and gives me about 12km/l
    Only mod I will be doing is a set of rally tyres on steel rims for gravel roads and the bit of off-roading I will do with.
  15. #74
    Thanked: 2663
    Either a panda or a jimny is on my wishlist for small 4x4 gravel car. Seen one while back in AD, did well, but he did loose his aircon radiator in frontal with dune
  16. #75
    Earth
    Thanked: 1941
    here you go
  17. #76
    May 2013
    Woesrand
    Default Making use of my free lesson
ID:	251091 Free lesson!
  18. #77
    Jhb
    Default Cederberg/N.Cape and S.Moz, Jan/May'13
    Some old pics from earlier trips, sorry about the bad quality!
    In Jan we took the West Coast - Cederberg - N Cape route back to Jhb, ended up alone in the mountains. Unfortunately don't have pics of our river crossing, which had a sand bottom with a sandy climb out the other side. Water was 400-500mm deep, not recommended for a Forester...
    Then we made a turn on Verneukpan. Epic place!
    Moz pics are near Ponta Mamoli in the South - beautiful scenery and the Foz handled the sandy climbs just fine!
Name:	201301 03 Cpt-Jhb Trip 058b.jpg
ID:	251665   Click image for larger version.
Name:	201301 05 Cpt-Jhb Trip 015b.jpg
ID:	251666   Click image for larger version.
Name:	201305 25 Moz 2213c.jpg
ID:	251667   Click image for larger version.
Name:	201305 25 Moz 2229c.jpg
ID:	251668   Click image for larger version.
Name:	201305 25 Moz 2331b.jpg
    ex: Forester X '10 ("dirty girl") - 25mm lift, bash plates, 235/60/16 ATs, etc.
    now: Forester S-edition '11 ("S-exy young thing") - Chett tune , King springs, bash plates, 225/60/17 ATs, etc.
  19. #78
    Live : Bethal , Work : Saudi
    Thanked: 235
    Barto ek het self n Panda Climbing gery en het die hele ribbokkloof roete by middelburg MP met hom gedoen al mods wat ek gedoen het was n nudge bar en bridgestone deuler bande.
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
  20. #79
    Mar 2012
    Pietermaritzburg
    Thanked: 20
    Mall crawling!
    1997 Land Rover DEFENDER 90 2.8i
    BFG AT's - Frontrunner Roofrack - Foxwing 270 Awning- Garmin 52LM-IPad T4A - CTEK 250S Dual battery system - OZ-TENT RV2 and Howling Moon1,4m Rooftop Tent - Cover Worx Visor covers - Melville & Moon seat covers Tuffstuff insurance....
    1997 Defender 90 2.8i
    2004 Defender 110 TD5 (sold)
    1999 Defender 90 TD5 (sold)
    2007 Freelander 2 (sold)
    2006 BMW E90 320D (sold)
    2005 POLO 1.9 TDI Swambo
  21. #80
    Earth
    Thanked: 1941
    Nice mall you have there Trevor
    I need to come visit it sometime
  1. Females
  2. Who is giving 4x4 a bad name?
    By Willem4x4 in forum The 4x4 Pub
    Last Post: 2009/11/14, 12:53 PM
  3. Have you ever broken a snatch or kenetic strap with your 4x4.
    By Big Hilux in forum 4x4 Recovery & Recovery Gear
    Last Post: 2007/02/09, 06:12 PM
  4. Post some pic's of your 4x4 on a rock
    By Big Hilux in forum General 4x4 Discussion
    Last Post: 2006/09/19, 10:25 AM
  5. Search Engines
    By benhur in forum General 4x4 Discussion
    Last Post: 2006/09/14, 09:42 PM
