15 000lbs winch installation on cruizer
Results 1 to 14 of 14
    Thanked: 982
    Default 15 000lbs winch installation on cruizer (pics)
    I will be doing a 15 000lbs winch installation today on a 4500 cruizer ldv. The problem is fitting it behind the bumper as the cavity is too small. The other problem is a strong enough installation for a 15 000lbs winch with a snatchblock that will double it so we will land up on 30 000 lbs with at least double safety factor. This all equates to 60 000lbs or 27t. So the minimum will be 8x m12 capscrews.
ID:	77919   Click image for larger version.
ID:	77920   Click image for larger version.
ID:	77921   Click image for larger version.
ID:	77922   Click image for larger version.
ID:	77923   Click image for larger version.
ID:	77924   Click image for larger version.
    Turnkey Construction Projects, Commercial, industrial, Domestic
    Importers: Diving gear, Compressed air cylinders for diving and airgun industry, 4x4 equipment.
    Manufacturers: Pofadder Kinetic ropes, Recovery kits, Synthetic winch ropes
    Vehicles: Modifications and installations, Special application vehicles
    Driver training: 4x4, Defensive
    [email protected]
    +27824453301
    Thanked: 7
    update seblief.
    Thanked: 982
    Klaar afgelaai. Sal pics post. Dis n samoosa winch daai
    Bothasig
    Thanked: 14
    Kan die onderstel van die Cruiser daardie klas van gewig dra? (60 000lbs)
    '02 Patrol 3.0Di GL
    Thanked: 982
    Stefan hy dra nie so baie gewig nie, dis n trek aksie. Die mounting is in lyn met die chassis op altwee kante. Onthou dis 15000lbs op n lee spoel en omtrent 10 000 op n vol rol. Dus 6.8t of 13.6 t maks met n snatchblock op ,maks kraglewering. As jy vinnig rem sal jou krag op n sleepstang hoog wees met n sleepwa. Onthou n snatchrope breek op 12t [pofadder] en daar is mense wat die goed al gebreek het. So die forces is nie soveel meer nie.
    [email protected]
    +27824453301
    Feb 2008
    Dronk-word-baai
    Thanked: 53
    Herman, neem asb 'n foto waar die hele Cruiser aan 'n boom hang vir die manne.. Ek dink dit sal 'n smart foto wees!
    1990 Toyota Hilux - In process..
    The more people I meet the more I like my dog..
    Real 4x4's have splash guards, not sump guards..
    Bothasig
    Thanked: 14
    Maak meer sin, dankie.
    '02 Patrol 3.0Di GL
    May 2010
    Halfway House (NOT Midrand!)
    Thanked: 7
    Quote Originally Posted by Engel View Post
    Surely andersom?
    A full spool will surely exert a bigger moment of force. Increasing as it fills up
    Pls educalate me
    Cory
    Sephulamthetho (Cory Voigt)
    'The cut worm forgives the plough'
    Nigel
    Thanked: 2075
    The force on the rope will decrease as the reel fills up, but the force on the motor remains constant. If the force on the rope goes down, the force on the mountings/chassis will also go down. It will match the force on the rope.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
    Bellville
    Thanked: 1773
    Quote Originally Posted by Cory View Post
    Surely andersom?
    Pls educalate me
    Cory
    The torque remains constant (well almost)
    Torque = Force x radius
    As the spool winds up the radius increase, a constant torque and larger radius means the Force is reduced.
    Pune
    Thanked: 60
    I agree with Henri and Chris' posts regarding the reduction in pulling force.
    Winch manufacturers usually make the pull per layer information available.
    Here's the specs for a Warn M15000. As you can see Engel was close with his "about 10000lbs" statement, it is actually 9840lbs pulling force on layer 4 on the Warn winch.
    http://www.warn.com/truck/winches/src/M15000.shtml
    Thanked: 982
    you have to see the size of the winch to appreciate the size!
    [email protected]
    +27824453301
    Oct 2006
    Redland Bay - Queensland
    It's also interesting how few bulbar suppliers can fit a winch larger than 10'000lb on their bulbars. I have a 12'000lb and ARB could not supply a bar suitably rated unless I go for the industrial type bar. On the other hand Ironman Bulbar could. ARB said it would interfere with the airbag deployment.
    Johan
    Toyota Hilux D4D SR5
    ZS6YR/VK4JHE
    Thanked: 982
    piektjas boetie
    [email protected]
    +27824453301
  1. Installation of a winch
    By Boomerang in forum 4x4 Recovery & Recovery Gear
    Last Post: 2010/10/13, 11:23 AM
  2. Hunting Hauler Portable Capstan Winch
    By culltony in forum 4x4 Recovery & Recovery Gear
    Last Post: 2010/04/20, 11:36 AM
  3. What is a winch on a 4x4
    By Big Hilux in forum 4x4 Recovery & Recovery Gear
    Last Post: 2007/02/19, 01:28 PM
  4. Patrol Winch installation
    By Engel in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/18, 05:20 PM
