Wow Charl, that really is a very usefull link, thanks!
http://www.greatlakesxj.com/tech.html
Including factory service manuals (42Mb download)
2005 Jeep Grand Cherokee 3.0
"The grey shoe". EFS Suspension | JK rims coming soon...
2000 Jeep Cherokee 4.0 Sport
Rubicon Express 3.5" Superflex Lift Kit | Rancho RS99009 / RS 99116 shocks | Custom Hack'nTap SYE + Double Cardan Driveshaft | RE Quick Disconnects | Unichip (164kW) | 31" Kumho KL71
2012 Jeep Grand Cherokee CRD Limited
Bush Lapa Miskruier B166
Mopar codes and other tools:
http://www.mymopar.com/tools.htm
Edit: Scrap that... seems to be only for older Dodge & muscle cars.
Could this be made "sticky" as a reference?
http://www.xjjeeps.com/tech_referenc...section=2&ID=0
More technical references.
This one found by Jeepster:
http://www.novak-adapt.com/knowledge...ge_gateway.htmA most crucial element of any good conversion is information. This is an integral part of the products we offer. Here are some informational resources that will aid you in planning a good conversion, or in restoring and maintaining your Jeep.
Here is an interactive directory of the major conversion issues
Found this at wagoneers.com 8). It's a Chrysler document from what I can gather.
They have a PDF with 576 pages of Wiring info and diagrams on the Grand Cherokee WJ.
Just a warning the PDF is 6.6MB for those on dial-up.
PM me if the link fails I have the PDF and can Mail or update the link.![]()
Here's quite an informative site I stumbled accross. Being an AUS site, it is quite relevant to our models (RHD). Not sure if one has to register to view.
http://www.ausjeepoffroad.com/forum/...ad.php?t=64361
Found these 2 documents form Dodge sites. Both of them relate to the 45RFE/545RFE gearbox (tranny) that is found in various Chrysler products including various Jeep models (WJ V8, WJ 3.1, WK ? and KJ ?)
NOTE: The 45RFE (4 Speed, 5 ratio, rear wheel drive, fully electronic) is a 545RFE without the flash program upgrade on the TCM for the 5th gear.
Assembly manual
Fault finding manual
An interesting article on the various Jeep transfer cases from old to new.
http://www.4x4review.com/tech/tCase-...de/default.asp
2005 R5 Tdi
Cruising in style!
Hi all
I have come across the whole GC (WJ) manual (including 3.1 diesel). It is all in PDF format. There are also other Jeep manuals at this address.
Check this link: http://www.offroad-monsters.com/foru...hp/t-1556.html
ATS Motorsport
30 SCHOONGEZICHT RD
BERGBRON
JOHANNESBURG
SOUTH AFRICA
TEL: 011 670 8400
FAX: 011 673 5185
[email protected]
These guys are great fast and cheap , if you need any JEEP parts the have stock and if the dont they fly it in
They are really worth a try
Wheel Bolt Patterns & Typical Lug Nut Torque Specifications
Bolt Pattern | Vehicle Description
5x5.5" '41-'86 MB & CJ Series
5x5.5" '62-'73 J Series & Full Size Wagoneer
6x5.5" '74-'91 J Series & Full Size Wagoneer
5x4.5" '87-'95 Wrangler YJ
5x4.5" '84-'01 Cherokee XJ & Commanche MJ
5x4.5" '97-'06 Wrangler TJ & TJ Unlimited
5x4.5" '02-Current Liberty KJ
5x4.5" '94-'98 Grand Cherokee ZJ
5x5" '99-'04 Grand Cherokee WJ
5x5" '05-Current Grand Cherokee WK
5x5" '06-Current Commander XK
5x5" '07-Current Wrangler & Wrangler Unlimited JK
Lug Size | Ft/Lbs Torque (Nm)
7/16" | 55-65 (75-88 )
1/2" | 75-85 (102-115)
9/16" | 95-115 (129-156)
5/8" | 135-145 (183-197)
12mm | 72-80 (98-109)
14mm | 85-95 (115-129)
Hi fellow Jeepers!
I have found a complete Chrysler Jeep Service Manual for the ZG which it says is very similar to the ZJ as sold here.
It is here: http://www.offroad-monsters.com/foru...hp/t-1556.html
I am currently going through the ZG/ZJ manual and it seems to be complete.![]()
2015 Volkswagen Amarok 2.0L BiTDI 4Motion d/c - "Grey Wolf"
2007 Volkswagen Golf Mk5 2.0L FSI GTI - "Midlife Crisis"
2001 Toyota Hilux 3.0L KZ-TE 4x4 Raider d/c - "Ysbeer" - SOLD
I've managed to get myself the manual for the 2002 onwards Jeep Cherokee KJ
The frikkin thing is 2500 pages worth so there goes my plan to have a hard copy printed![]()
2012 Fortuner 4.0 V6 4x4
My ex with a drinking problem
2005 Jeep Cherokee KJ 3.7L
I have a 2001 Chrysler Field Service Manual for XJ. It's a hard copy but I can copy / scan / fax anything that you might need.
Andre
Andre Louw
2010 JKU Rubicon
Please help if you know where I can get my hands on a copy.![]()
Hi, could you maby give us the link to the manual your talking about...
Seems almost anything you want is here:
Except the User/Owners manuals
Hi Johan,
I have an original Factory Service Manual (FSM) for the XJ. It's for the 2000/2001 models but there aren't that many differences back to '96. The FSM is not like a owners manual though - It's a 2000 page technical book usually used by dealers.
Unfortunately though, its a hard copy and is worth it's weight in gold! (To me anyway) If you let me know what you need, I can fax or scan.
Andre
Andre Louw
2010 JKU Rubicon
