Results 1 to 20 of 30
    Adelaide
    Thanked: 62
    Default Computer Fault Codes
    Here's a great link to computer fault codes on a Jeep and how to read the codes. I tried it on mine and works like a charm! No faults displayed... phew! What a relief!
    2012 Jeep WK2 Limited CRD
    2" Murchison Lift
    265/65R18 Dick Cepek Trail Country
    TJM sidesteps
    Uneek4x4 Recovery points
    Thanked: 8
    Thanks Renier, this sounds quite cool. I'm going to try it myself - will be curious to see if there are any mixture related codes stored after I've removed the cat.
    Will also print out a copy of this and keep it in the car - could come in very handy when a problem raises its head when one is in the Jeep's natural habitat..!
    2012 Jeep Grand Cherokee CRD Limited
    Bush Lapa Miskruier B166
    Adelaide
    Thanked: 62
    I have the same idea, keeping a printout handy in the glove box somewhere!
    2" Murchison Lift
    TJM sidesteps
    Thanked: 8
    Congratulations on your 400th post!
    I've done the check and it's quite cool have the dails sweep back and forth and all the lights go through their check routines. Luckily, mine also didn't come up with any error codes.
    Adelaide
    Thanked: 62
    Quote Originally Posted by gorman View Post
    Thanks - but it's about the 6th time I get there. Not that post counts bothers me as much as some other members...
    2" Murchison Lift
    TJM sidesteps
    Thanked: 8
    My car's battery died on me this afternoon - took the opportunity of fitting a Delphi maintenance free MS battery - quite a bit bigger than the one it replaced. In fact the one it had in surprised the guys at the battery shop - they said its way too small for a 4.0 litre engine.
    Anyway, I though I'd do the check and see if the fact that the battery was removed registered any fault codes, but it didn't. I guess it has to be disconnected for a longer period.
    Thanks to Pierre (Freakazoid) for the tip on Delphi being a good choice..
    Adelaide
    Thanked: 62
    How much is the damage??
    2" Murchison Lift
    TJM sidesteps
    Thanked: 8
    ....mmm, it was a steep R875 - but I was told that it should easily outlast the equivalent Exide which was R575 if I remember correctly. I used to be a fan of Willard but on my previous car I had to replace two in two years.
    Marina da Gama, Cape Town
    Could this be trimmed and made "sticky"?
    2005 Jeep Grand Cherokee 3.0
    "The grey shoe". EFS Suspension | JK rims coming soon...
    2000 Jeep Cherokee 4.0 Sport
    Rubicon Express 3.5" Superflex Lift Kit | Rancho RS99009 / RS 99116 shocks | Custom Hack'nTap SYE + Double Cardan Driveshaft | RE Quick Disconnects | Unichip (164kW) | 31" Kumho KL71
    Thanked: 8
    Sticky please!
    May 2007
    game reserve loius trichardt
    Default Help
    Anyone know what code P0320 is??
    Jeep taking their time...
    Nov 2006
    Alkimos, Western Australia
    Thanked: 1329
    P0320
    No Crank Reference Signal at PCM
    No reference signal (crankshaft position sensor) detected during engine cranking.
    P0320 (M)
    No RPM Signal to PCM (Crankshaft Position Sensor Signal to JTEC)
    A CKP signal has not been detected at the PCM.
    Dit Reent.... n Kraai Knetter.... Erens Poep n Vark.....
    JeepOnly Guest
    Quote Originally Posted by sarally View Post
    All codes for Jeep WJ can be found at:
    http://www.wjjeeps.com/faultcodes.htm#DTC
    JeepOnly Guest
    Hmmm, thanks to you guys for putting me onto this in the first place, and now I wont get any sleep tonight as I need to figure out why I received a code: 1685
    Adelaide
    Thanked: 62
    Jislaaik JD maar jy raak nou goed met hierdie dinge! Jy raak nou 'n regte Jeep ekspert!!
    2" Murchison Lift
    TJM sidesteps
    Feb 2007
    johannesburg
    Quote Originally Posted by JeepOnly View Post
    do not worry about it. I get aswell now and then. the important thing is .... it starts and this is all to do with the transponder in your key. "its a jeep thing" or "only in a jeep"
    Grand Cherokee oil burnerhttp://www.4x4community.co.za/forum/image.php?type=sigpic&userid=1166&dateline=1181595  777
    Pretoria North, Patryshoek
    Thanked: 3233
    Just seems that if you are a Jeep not, you have no choice but make a note of all these glitches..............
    +27 zero eight 2 four 95 9252
    Adelaide
    Thanked: 62
    Quote Originally Posted by henris View Post
    A certain answer springs to mind, but seeing as we have younger viewers on here from time to time, I'll not mention the two words. The first word is four letters and the second word three letters. So you do that now!
    I think it's better to discuss the problems that we do have, rather than pretending there's never any problems. Now take your Toyota and do as suggested above.
    It's not like there are no problems when I look at the Toyota side of the forum.
    2" Murchison Lift
    TJM sidesteps
    JeepOnly Guest
    Quote Originally Posted by Jeepster View Post
    Only one solution for you Jeepster. Go buy a make of car (you know what) that does not offer you self diagnostics. That way you will never know if there are any possible glitches. Or you could always go to your nearest branch of (any make or model) and ask them why so many of the staff are dressed in blue overalls
    Thanked: 3233
    OK OK.
    Tender subject I gather
  1. Reset Discovery Fault codes
    By janfloris in forum Land Rover
    Last Post: 2012/05/14, 10:19 AM
  2. Fault codes AGAIN
    By Johan in forum Jeep
    Last Post: 2011/01/21, 06:57 AM
  3. buying a WJ - Fault codes & pre-purchase check
    By Megagustodon in forum Jeep
    Last Post: 2010/07/26, 08:48 AM
  4. Jeep 2.7 Laredo fault codes
    By MRoss in forum Jeep
    Last Post: 2010/06/24, 03:50 PM
  5. Nanocom fault codes
    By andyrag in forum Land Rover
    Last Post: 2008/09/25, 07:58 AM
