My Wilderness Trailer Modification Thread
Page 1 of 13 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 20 of 257
    Default My Wilderness Trailer Modification Thread
    We bought a Campmaster Wilderness trailer (Challenger BunduBasher) in 2009 and camping with our normal ground tent, the trailer was mostly used to transport our camping goods to the campsite. Then unpack most of it into our tent and park the trailer out of sight till we need it again. This was fine, as it was what we needed at that stage.
    I added a drawer rail for 3 ammo boxes with a fixed rack for 2 more ammo boxes.
    As the lid was easy to lift and keep open it was convenient to have the 2 ammo boxes in that location.
ID:	73753Click image for larger version.
ID:	73754Click image for larger version.
    There was space in the roofrack ontop of the lid for a table and we stored our plastic ‘catering’ table there.
    Any extra stuff could easily be secured ontop of the roofrack.
    After we fitted an Echo trailer-tent on top of our trailer, we did not open the trailer from the top anymore.
    We also could not use the top part of the roof-rack, so the only use for this section (±250mm high) was to store the plastic table.
    I started planning on removing the complete top door with roof-rack and to build a new frame that will have doors on the side of the trailer.
    After a few versions of this plan the final design was to have 3 doors on the one side (Kitchen area with microwave and all the crockery and cutlery) and 2 on the other side (Storage of 4 ammo boxes).
ID:	73757Click image for larger version.
ID:	73758Click image for larger version.
ID:	73759Click image for larger version.
    The door was removed as whole and no modifications were needed on the remaining body of the trailer.
    I made the frame from angle-iron and it fits on top of the trailer, secured with a few bolts & nuts. Rest of the frame is rectanglar tubing.
    The frame of the tent fits into the new frame by ±25mm
    The doors are made from 0.8mm mildsteel plate and are bended so that it is 40mm deep.
    We use this space to store glasses, utensils & mugs. Normal T-Handles with ±70mm shafts are used for the locks.
    On the inside I used aluminium T-section as support of the ammo-boxes and kitchen.
ID:	73762Click image for larger version.
    The “kitchen cupboard” is made from 9mm pine-plywood and the microwave is fitted on drawer rails, so it can slide out.
ID:	73764Click image for larger version.
    I removed the ammobox drawer rail and fixed rack I made last year, moving the drawer rail with the 3 ammoboxes to the back of the trailer. A new drawer rail is now in the front for the NationalLuna 90l Fridge/freezer.
    I got a few of the LED strip lights from Andrew Faber (AndyF) and that makes a huge improvement to the usability of the whole setup.
    Using 2 of the 30cm strips in the kitchen, one 60cm strip at the back of the trailer and another 60cm strip in the tent.
    Johan van Rensburg
    2009 Mitsubishi Triton 2.5 - Rocksliders - Bashplate - Radio Replacement
    DiWa Offroad Caravan
    Very good idea to put some of that "dead" space to good use. Also nicely executed. Congratulations.
    07 LC 79 4.2D (Brutus)
    Still have a flaky, rusty, leaky '05 Conqueror Conquest Trailer
    Congratulations,great ideas,very neat and well thought out.
    (M25)
    LandCruiser 200 V8td,ARB winchbar,Warn 12000lb winch,IPF spots,180W LED bar,180L Longranger aux tank,ARB rear bumper+dual wheel carriers(had-Kaymar carriers),OME suspension,TJM snorkel,raised axle breathers,roofrack,2 way comms,285/70/17 MT tyres,additional fuel filter system, upgraded brakes.
    nicely done.... thank you... It gave me a few ideas for my own mod!
    Delmas
    Thanked: 622
    baie mooi, geluk, geniet dit.
    Elize
    en ry saam met SarelF in
    VW AMAROK MET BLINKGATCAMPER:
    My Platkar:- Peugeot 208
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
    looks great !
    I would like to know what "foam" was used for the mug's storage and how you got the moulds cut out for the mugs.
    Libdoo, I got the foam from Pro Auto Rubber in Boksburg.
    Not sure what the correct naming is but it is sold in sheets of 1m x 0.5m x 40mm.
    A hole-saw cuts the foam very nicely, but I needed a ±85mm hole for the cups and wasn't willing to pay R100+ for a hole-saw for an once-off use.
    I used a tin cup from which I cut off the rim with a 'blikskêr'.
    When cutting the hole just rotate the tin and it cuts nicely and smooth.
    I then used a router to add the gaps for the handles.
    I also used the router and old electric-carving knive to cut the slots for the utensils.
    Johan van Rensburg
  8. The Following User Says Thank You to Skymaster For This Useful Post:
    Nigel
    Thanked: 2066
    Thanks Guys. Looking good.
    I will be needing to do this very shortly in the Troopie.
    Uniglide
    +27 zero eight 2 four 95 9252
    Thanked: 9
    Very nice, congratz, would like to know how the suspension on the "new" trailer is copeing with the added weight or doesn't this affect handling?
    V10 jnr, the weight of the new frame (excluding tent, microwave and kitchen stuff) was about half the weight of the lid & roofrack. The axle is a 2500kg axle and the tow handling was not affected. Well, not what I have noticed. The weight of the tent will most likely have the biggest affect on handling.
    The new frame only increased the height of the trailer by ±25mm.
    Johan van Rensburg
    Thanked: 28
    Very nice. One of the best conversions I have seen.
    2012 Freelander 2 SD4 SE
    Offtrax Outplay
    I forgot to mention in the above post that I also modified the SpareWheel swing arm.
    With the arm on the trailer it is always in the way and in the middle of the tent when the back door is open.
    So I removed the 2 bolts and replaced it with 2 pins fitted with quick-release safety pins
    When we get to the camping spot I can remove the spare wheel arm in a few seconds and put it under the trailer
    Johan van Rensburg
    Krugersdorp
    Quote Originally Posted by Skymaster View Post
    Hi Skymaster, i have a similar treiler and have also done a few modifications. Yours looks awesome. I alrready have a echo tent on, so if i modify to fit your design where the lis was should the tent still fir and reach the ground level when opended?
    Riaan (Rambo) - Today should always be our most wonderful day!
    2006 Toyota Hilux 3L D-4D D/C (BLOU-WA)
    2016 Toyota Hilux 2.8 Auto D/C (White Rhino)
    2017 Conqueror Companion (5-Ster)
  15. #14
    Hi Blou wa.
    As far as I know the Echo trailertents are designed to be 155cm from the ground (+/- 5cm).
    So if the final height of the trailer is in that ballpark, you should be okay.
    Ours still fits/reach the ground with a few cm's spare.
    (We're at Marakele this weekend and I will take some pics of the tent.)
    Johan van Rensburg
  16. #15
    Jul 2010
    Bellville
    Jitte, Lyk my my ou wa kan 'n bietjie doen met 'n "makeover". Baie oulike idees!
    2003 Toyota Condor 4x4 3l Diesel
    2001 Conqueror Offroad Trailer
    2014 Toyota Etios Sedan 1.5
    2002 BMW 318i (Sold)
  17. #16
    Hi Skymaster, is there a possibility to get the drawings from you?
  18. #17
    Quote Originally Posted by kalahariec View Post
    What are you looking for?
    Johan van Rensburg
  19. #18
    Delmas
    Thanked: 622
    Skymaster, jou snywerk by die koppies is baie mooi. Ons het verlede week gedoen met 'n gatsaag. Dit werk goed. Wil juis hierdie naweek so 'n modifikasie of twee op die bossewa se kombuis doen - wil glasbekers saamvat. Ek haat die melamine. Daai saamgeperste rubber is ietwat duur, so R200 per vel, maar dit werk fantasties. Het ook gekry by die ou in Boksburg.
    Elize
    Sarel 0828209413
  20. #19
    Thanked: 126
    Regarding the cutting of foam....
    I dont know if this high density foam can absorb water, but on foam that does absorb water do the following:
    Saturate the foam with water, then put it in the deepfreeze overnight. When it is frozen nice and solid, you can shape it with woodworking tools - jigsaw, file, rasp, saw etc. You can even shape and profile the sponge. When it thaws, you wring out the water, and have a nicely finished product.
  21. #20
    Delmas
    Thanked: 622
    Gert, is dit net vir hoe digtheid spons ? Die wat ons gebruik het was rubber - ek glo nie dit absorbeer enige water nie, maar die gatsaag het baie mooi gewerk - mooi afwerking en daarna het so hier en daar met 'n baie skerp mes gleufies ingesny. Dit is egter oulik dat hy 'n 'router" gebruik het, sal dit ook toets.
    Dankie
    Elize
    Sarel 0828209413
  1. Which off road caravan or off road trailer is the best?
    Last Post: 2017/10/06, 10:54 AM
  2. Reversing with a trailer behind your 4x4?
    Last Post: 2013/02/04, 12:51 PM
  3. Towing regulations
    By NEON DEON in forum Camping, Fridges, Accessories
    Last Post: 2009/12/11, 11:29 AM
  4. Leo or Conquest s - some advice needed?
    By Wiv in forum Camping, Fridges, Accessories
    Last Post: 2007/09/02, 10:49 PM
  5. Do you insure your trailer
    Last Post: 2007/01/25, 03:35 PM
