brandstof
Results 1 to 5 of 5
Thread: brandstof
    Jul 2010
    ha...ha...hartebeespoort dam is n lekke dam wa die vissies die heeldag byt...
    Default brandstof
    hi, ons beplan n trip angola toe volgende jaar. wil graag weet hoe vrylik beskikbaar is petrol en diesel onderskeidelik? kan iemand help?
    SENEKAL
    Het laasjaar in Angola getoer, teoreties is brandstof nie n probleem nie-----jy moet net soek na n vulstasie in n dorp wat die verlangde branstof het. As jy jou roete beskryf sal dit help
    Jul 2010
    dis maar +/-. dalk veranderinge in die terugkom slag
    Dag 1 - Jhb tot Gobabis
    Dag 2 - Gobabis to Ethosha1 - (Namutoni)
    Dag 3 - Ethosha 1 tot Ethosha2 - (Okaukuojo) of ons bly vir 2 dae in een kamp
    Dag 4 - Ethosha na TB1 in Angola
    Dag 5 - TB1 na TB2 in Angola
    Dag 6 - TB2 na Foz de Cunene/strand
    Dag 7 - Foz de Cunene to Tombua
    Dag 8 - Tombua
    Dag 9 en 10 - Lake arco
    Dag 11 en 12 - Namibe
    Dag 13 Namibe to Ruacana
    Dag 14 Raucana to Gobabis
    Dag 15 Gobabis to Jhb
    Howick
    Default Angola fuel
    Just got back from Angola - 3 Sept. Fuel not a problem in Angola in the larger towns - also diesel only cost R3.20 per litre!!!!!!!!
    Looking at your route you will easily get fuel in Tombua and Namibe.
    Just some suggestions in your planning - we have been up 4 times.
    Try use the small borders only - Ruacana and our new favourite Calueque. Avoid the main road from Cahama to Oshikango - still in bad condition.
    From either Ruacana to Foz du Kunene it will take about 2 and a half days driving time - you will need to spend at least two nights camping between Ruacana and the Foz.....you could probably push a bit but not worth it. Enjoy the drive.
    Make sure if you are driving the beach past Tigres you do it on spring low tide - also if driving this stretch think about getting a local guide. You can do the back route but that will take at lest a day.
    Let me know if you have any further questions or need some more advice.
    Jul 2010
    thanx pumba. wil do.
  1. Replies: 17
    Last Post: 2011/02/02, 09:31 AM
  2. Bande en brandstof verbruik
    By Delta in forum Isuzu
    Last Post: 2010/07/07, 09:56 AM
  3. Sosrento brandstof tenk probleem
    By Rensen in forum Kia
    Last Post: 2009/10/17, 12:26 PM
  4. Water-4-fuel
    By Sawdust in forum General 4x4 Discussion
    Last Post: 2008/11/13, 09:18 PM
  5. Brandstof!!!!!!
    By Rondloper in forum General 4x4 Discussion
    Last Post: 2008/03/13, 09:57 PM
