Jimny ignition in the key BEEP BEEP!!!!!!!!!!!!!!
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 78
    Brackenfell
    Default Jimny key in the ignition BEEP BEEP!!!!!!!!!!!!!!
    Anyone else that's been driven crazy by this damn buzzer...?
    I disconnected mine, and showed someone else to how to do it, he suggested I post it here aswell, so he goes.
    It is very simple, will take about 1 minute. It only disconnects the buzzer on the ignition. The "lights on" buzzer will still work.
    Underneith the steering wheel is a cover that you pull open.
    Then you will see a plug with 2 green wires on the one side and a blue/yellow and white on the other side. disconnect this plug.
    I have cabletied mine to keep the wires from hanging lose.
    See photo's below for step by step instructions:
    1. Where to open Cover
    2. Cover clip details
    3. Plug to disconnect
    4. Plug disconnected
    5. Plug cabletied
    I know this Beep is very irritating, especially on a trail where you switch your car off from time to time. So i hope this will help with some blood pressure problems...
Name:	Step 1 Where to open Cover.jpg
ID:	68107   Click image for larger version.
Name:	Step 2 Cover clip detail.jpg
ID:	68108   Click image for larger version.
Name:	Step 3 Plug to disconnect.jpg
ID:	68109   Click image for larger version.
Name:	Step 4 Plug disconnected.jpg
ID:	68110   Click image for larger version.
Name:	Step 5 Plug cabletied.jpg
    Suzuki Jimny
    Extended diff & Trasfercase Breathers
    Old Man Emu
    Front Runner Roofrack
    BFG 215/75/15
    30mm Wheel Spacers
    Custom Rock Sliders
    20% Smash & Grab
    Sound Upgrade
  2. The Following 5 Users Say Thank You to BlueRocket For This Useful Post:
    Brackenfell
    Oops, i meant key in the ignition... not ignition in the key....
    Suzuki Jimny
    Old Man Emu
    BFG 215/75/15
    30mm Wheel Spacers
    Custom Rock Sliders
    20% Smash & Grab
    Sound Upgrade
    Loevenstein
    Thanks Bluerocket, my bloeddruk het nou weer gedaal na normaal.
    Ek kon daai Beep Beep!!!!!!!!!!!!!! nie hanteer nie.
    Paul Bothma ("Ore" so ken my familie my)
    2014 2.2 Ford Ranger XLS 4x4
    Thanked: 2074
    Anyone got a similar idea for a Hilux?
    It is driving met bonkers
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
    Jan 2007
    Thanked: 295
    Thanks. That will stop me from going nuts on the trail. Other Jimny owners BEWARE
    Vic
    2018 Suzuki Jimny -
    2012 Suzuki Jimny 1.5 - 215R15C's, Steel undies, lifted and locked. - CRASHED
    1984 Suzuki SJ410 - 245/75R15 Muddies, Nissan A15 Motor, OME's - SOLD
    Platkar - Suzuki Swift 1.4 GLS Auto
    Jul 2010
    Bellville
    Thanks a lot for this procedure
    the beeping was really annoying
    Jul 2010
    Thanks that beep is really irritating!
    Gauteng/ Boksburg
    Thanked: 14
    Tried tested and it works, Thanks
    Jun 2008
    Very nice. Thank you!
    Suzuki Jimny
    Bellville
    Thanked: 1755
    I believe you can programme it.
    Aug 2010
    JHB
    i cant hear no damn beeping ,, one advantage to be deaf on certain frequencies i guess
    Thanks, dit werk!!!
    2009 Suzuki Jimny, BFG's
    Tableview
    Nice simple fix to a really annoying "feature". For curiosity's sake anyone know what this set of leads is for? I am guessing it the signal to a controller that shows whether the key is in the ignition or not. I ams sure ti also get used to switch the light off once the key is in the ignition. I will check out the operation and confirm this or not.
    Thanks for the good work here guys.
    Live everyday as though it were your last and one day you will be right.
    Suzuki Jimny - Sookie - /\/ŻŻŻŻŻ\/\
    ZS3GS
    ZS1GS
  15. The Following User Says Thank You to cside For This Useful Post:
  16. #14
    Hillcrest, Malaysia
    Thanked: 4916
    Default carefull
    Hi guys,
    Please be carefull, and maybe somebody should speak to Suzuki.
    It is possible that more than just the buzzer has been disabled.
    I am thinking some ECU functions and safety features (airbags? etc). Legal/safety implications??
    Keith
    ZS5KAD
    3 V8's
    A V6 and an inline 4
  17. #15
    Brackenfell
    I'm not worried at all. Those wires is for the buzzer only. Even the "feature" that switches off the interior light when you push the key in the ignition still works.
    There is a small switch on the side of the ignition that switches the buzzer on and off when the ignition is turned, its only these wires that gets disconnected.
    Its like removing the switch in the door that switches the interior lights on and off, its got no influence on any electronics of the car.
    BUT if you are unsure about this mod, then rather do not do it!
    Suzuki Jimny
    Old Man Emu
    BFG 215/75/15
    30mm Wheel Spacers
    Custom Rock Sliders
    20% Smash & Grab
    Sound Upgrade
  18. #16
    Hillcrest, Malaysia
    Thanked: 4916
    Default Good
    Hi,
    If you saying that the wire is just a simple connection between the ignition and a physical buzzer. Well that sounds OK to me then.
    cheers
    Keith
    ZS5KAD
    3 V8's
  19. #17
    Krugersdorp
    Thanked: 60
    Thanks BlueRocket!
    Riaan
    2015 Toyota Land Cruiser 76 4.5TD V8
    2017 VW Golf 7.5 R
    2018 Touareg T3 3.0 V6 TDI Executive - SWAMBO
    2016 Bush Lapa Miskruier (Kampwa)
  20. #18
    Oct 2012
    Eks bly ek het die thread raakgeloop! Daai buzzer gaan my tor nog laat omval eendag!!
    Danie
    Nissan Hardbody KingCab 4x4
    Volkswagen Polo Maxx
    Jurgens Camplite
  21. #19
    Oct 2012
    Port Alfred
    Awesome!!! I Hate that buzzer!
  22. #20
    Mar 2012
    Thanked: 101
    Quote Originally Posted by BlueRocket View Post
    How sure are you? I'm not second guesing and am sure I'm also going to pull the plug but still do make sure, if anyone are planning to go to the workshop or maybe have the wiring diagram.
    As most of any switches in the car you will notice only use one lead as the body and or any other metal surface are the negative point in the connection. Thus making me think why the second wire?? Just a thought, I doubt it will effect airbags or anything majors but there might be two things running from that plug instead of only the buzzer.....
    Won't hurt if someone checks with the workshop when there.
    Creeper
    Jimny 1.3 - Radial cup Protectors, Front & Center Bash Plates, 50mm EFS's, Rock Sliders, Front Recovery Points, Snorkel.
    By charlatan in forum Jeep
  2. Grand Cherokee Error code
    By Nick47 in forum Jeep
  3. Ignition key stuck in my XJ
    By laura c in forum Jeep
    Last Post: 2009/11/26, 07:53 AM
  4. D4D Ignition Key Programming
    By Kiggs in forum Toyota
    Last Post: 2009/10/29, 07:15 AM
  5. Irratating beep when keys left in ignition
    By nazire in forum Mitsubishi
    Last Post: 2007/09/10, 10:31 AM
