Results 1 to 6 of 6
    Default 4x4 "4L" light flashing
    Does anyone know of someone who knows what goes on with the 4x4 system on the K300 D-MAX in Port Elizabeth.
    Namely that the "4L" light flashes continuously no matter what I select on the 4x4 panel.
    I have given up trying to fix it myself
    Sep 2008
    Swakopmund
    Thanked: 174
    Just quickly checking: When the 4L Flashes, your vehicle is in Neutral and your clutch and brake pressed in and pushing the 4L Button again, does it flash slower and engage 4L or not?
    I found on my Auto if my 4L light flashes, I did something wrong and after I got into Neutral, press on the brakes and press 4L again, which after it engages 4L and I can go back to 4H and onwards to 2H.
    Fortuner 2.8 GD-6 4x4 Auto
    (Tough Dog Suspension / Frontrunner Roofrack and some more goodies...)
    Hi Sniper,
    I have tried everything, brake on, clutch in pushing all the buttons at once, but nothing works. When one of the buttons is pushed the "4L" light flashes faster, and the system goes into what I have selected. It goes into 4h or 4l and back to 2l with no problem, but it does not indicate 4x4 or what I have selected, the "4L" light flashes continuously. So no closes to the problem.
    Sep 2008
    Swakopmund
    Thanked: 174
    If you say the system goes into what you have selected and it goes into 4H, 4L and 2L, then it seems all ok, or is it only physically swithing to 4x4 and not indicating on the dash? 4H - indicates 4x4 High Range and 4L indicates 4x4 Low Range. When going back to 2H, which you say it does, does the 4L still flash?
    It sounds like you just need a quick reset at GM if it still goes into the 4x4 mode you want?
    Sep 2008
    You can reset yourself...simple procedure involving pressing all three buttons....check your manual
    Owen Shaw
    [email protected]
    Get your priorities correct. It is all a our being in Africa. Too often people get their priorities wrong and the bling becomes all important. If you can do it in an old bakkie I have the utmost respect for you. On a bicycle even better!
    Ballito
    try the reset in the manual, manuals are wealth of knowledge on new cars with all sorts of tricks in the small print. if that doesnt work the agent should be prepared to plug it in to the computer and find out what the error code is. they dont normally charge for doing a reset or similar.
    lights flash for all sorts of reasons on modern cars, to make you get them plugged in and the error code checked. for example, if both brake light bulbs are burnt out on a polo, the engine management light comes on, to make you skrik and go straight to the agent. its not always directly related.
    1997 Cruiser 1HZ - New Toy
    2003 Lexus IS200 - Daily
    2006 Alfa Romeo GT 3.2 - Trouble Maker
  1. The Baboon 4x4 Trail Queenstown
    Last Post: 2018/12/17, 03:33 PM
  2. Pajero CDL light flashing
    By Daneel in forum Mitsubishi
    Last Post: 2012/08/13, 06:06 PM
  3. Replies: 48
    Last Post: 2010/05/04, 07:29 PM
  4. 2002 Clubcab 2.4 4X4 LIGHT PROBLEM
    By Bra Mike in forum Mitsubishi
    Last Post: 2010/03/18, 09:20 AM
  5. Land Cruiser OD light flashing
    By Werner in forum Toyota
    Last Post: 2009/08/28, 05:49 PM
