Results 21 to 24 of 24
    Thanked: 36
    Why on earth would you want to go the spitronics setup, the GEMs is a solid relaible system only let down by bad tampering like messing with the airflow setting
    If its heavy on fuel replace the ETC sensor (R380) and check MAF setting, also confirm fuel rail pressure, weak coil can aslo play a role here as to is a incorrect voltage to ignition
    30 years experience and knowledge certainly out weighs a 5min keyboard bashing on google
    Love's electrickery stuff and problems related to it as long as it dont go bang cos then its f......
    NO REPLACEMENT FOR DISPLACEMENT
    A V8 is where thunder is made
    100%WEE
    Quote Originally Posted by viperover View Post
    I don't need to replace but i would like to replace the ETC sensor sometime soon. I asked out of curiosity...
    Platkar driver...
    '99 Land Rover Discovery 3.9 V8i - SOLD
    Challenger Bundu Basher - SOLD
    I will drive a Land Rover again...
    Dec 2012
    Thanked: 23
    Just to get this right, what is the correct resistor for the za market then? Is it the Red wire, 180 ohms, Australia, Rest of world or is it the Green wire, 470 Ohms, UK and Europe - non catalyst. Does a higher resistance equate to a hevier fuel usage or is it the other way around?
    George
    Thanked: 50
    I would recommend the green 470 Ohm tune resistor.
    "Rest of World" means: "Lets run the engine so rich that even the crappiest fuel will not cause warranty claims." - well, that's what I think it means....
    Best regards
    Philip
    LR: '11 Rangie 5.0 S/C, '01 Disco 2 XS 4.6 V8
    Ford: '19 Ranger 3.2 XLS Manual SuperCab 4x4 (XLT is ergonomic disaster)
    Chevrolet: '70 C10 350ci / 700R4 (4-sp Overdrive) & '59 Apache (Stepside)
  1. Jaloers op nuwe Disco 4
    By Disco3 in forum Land Rover
    Last Post: 2010/06/11, 11:22 AM
  2. Discovery 2: 255/70 x 16, Disco II ES
    By BADPIG in forum Land Rover
    Last Post: 2010/06/01, 08:22 PM
  3. Discovery 2: I just drove a Disco II td5..
    By petermoffat in forum Land Rover
    Last Post: 2010/01/19, 04:38 PM
  4. Disco 1 CDL
    By Keenfish in forum Land Rover
    Last Post: 2009/09/01, 07:48 PM
