Results 1 to 20 of 24
    Thanked: 1272
    Default Disco 1 tuning resistor
    Disco 1 3.9 petrol 1997. Anyone familiar with the tune resistors?
    To cut a long story short I measured across pins 5 and 27 of the ECU connector and got near as as dammit 3900 ohms. I then (eventually) found the resistor (taped inside the loom) and indeed it is a white one as per Land rovers docs that says white 3900hms is UK/European with cats
    So somebody has switched to the UK/EU cat map with the resistor (I'm leaving out all the other horrors that I found, scope for many more threads on that).
    So what colour were the SA spec Disco 1 tune resistors? I would guess red as that is for Australia and the rest of the world but maybe they used the other green and yellow non cat resistors. Our local Landy guys are not sure.
    Feb 2012
    Thanked: 15
    Ever found out about this? I just located a red one on mine
    What would be the best suited for .za?
    Thanked: 1272
    Never took it further but I know the Aussies like to switch to the green one (470 Ohm) You can make up one yourself and try it. The white one is ONLY for use with the correct lambdas.
    Some fascinating stuff here http://code.google.com/p/rovergauge/
    '09 Suzuki Grand Vitara 3.2
    Thanked: 50
    I also had a red one in my '95 manual with no cats.
    Best regards
    Philip
    LR: '11 Rangie 5.0 S/C, '01 Disco 2 XS 4.6 V8
    Ford: '19 Ranger 3.2 XLS Manual SuperCab 4x4 (XLT is ergonomic disaster)
    Chevrolet: '70 C10 350ci / 700R4 (4-sp Overdrive) & '59 Apache (Stepside)
    Thanked: 50
    There is a bit about tune resistors here: http://www.v8engines.com/carbs-2.htm#Tune-resistor
    Best regards
    Philip
    Thanked: 50
    Even better:
    http://www.britishv8.org/articles/rover-14cux-efi.htm
    I suspect the green tune resistor would be for countries with true high octane petrol whereas the red one is for sad countries like ours where fuel quality is dubious.
    Best regards
    Philip
    Thanked: 50
    Quote Originally Posted by LRwit View Post
    I should add that high octane fuel is ONLY useful on high compression engines where it helps to avoid detonation/pinging/knocking. There is no benefit to be had by using high octane fuel on low compression engines.
    Best regards
    Philip
    Feb 2012
    Thanked: 15
    What octane was used in the UK 15 years ago then they mapped the ecu?
    Thanked: 1824
    Default Middle East
    My 3.5 V8 had the yellow resistor, Saudi..
    Feb 2012
    Thanked: 15
    K, I measured pin5 to ground, its on 470R - so its mapped for UK no cats,
    can't find any details on what the difference is between UK and Aus maps
    Thanked: 1272
    So you painted it blue so it changed to 470Ohm?
    I would hazard a guess that the UK map to be a bit leaner at WOT because of the better petrol quality.
    With the roverguage software you can examine the maps and look at the difference. I bet you would find they are almost identical.
    Feb 2012
    Thanked: 15
    I made the interface for rovergauge yesterday - pretty cool i must say, saw that everything seems to be working
    Feb 2012
    Thanked: 15
    it's uhmm, exactly the same...
    Feb 2012
    Thanked: 15
    Thanked: 50
    Quote Originally Posted by stretch View Post
    This makes me think that by applying different values of "tune resistor" has an analogue effect on the overall enrichment being applied by the ECU? - similar to tuning the screw on the MAF?
    Hmmm... Something to investigate one day...
    Best regards
    Philip
    Thanked: 1272
    Ho.
    I was almost right.
    If you can access the cat (white) map it should be different.
    If an analogue effect why bother with multiple maps? Maybe was intended for future use. The programmer did not adhere to the YAGNI principle. (You aint gonna need it)
    Thanked: 2220
    I fitted a variable resistor, trying all the maps, could not really feel any difference by the seat of my pants, except the one for cats, (mine is fitted with cats but resistor changed to red and lambdas unplugged)
    If I plug the lambdas back in and use the Cat map, it gets sick, maybe the lambdas are shot.
    Knysna
    Thanked: 630
    Stretch, which 2 maps did you compare?
    AUS/ROW vs UK?
    I have a red AUS?ROW resistor if anyone wants it. THe loom is scrap now
    Rob
    Disco 3 SE TDV6
    Disco 2 ES TD5. Custom map, V8 TC
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Feb 2012
    Thanked: 15
    Quote Originally Posted by Hagu13 View Post
    AUS/ROW vs UK?
    Yes, Aus and UK - exactly the same. /me starts saving for a spittronics
    What does it cost for the spitronics setup ? Rob ?
    Platkar driver...
    '99 Land Rover Discovery 3.9 V8i - SOLD
    Challenger Bundu Basher - SOLD
    I will drive a Land Rover again...
  1. Jaloers op nuwe Disco 4
    By Disco3 in forum Land Rover
    Last Post: 2010/06/11, 11:22 AM
  2. Discovery 2: 255/70 x 16, Disco II ES
    By BADPIG in forum Land Rover
    Last Post: 2010/06/01, 08:22 PM
  3. Discovery 2: I just drove a Disco II td5..
    By petermoffat in forum Land Rover
    Last Post: 2010/01/19, 04:38 PM
  4. Disco 1 CDL
    By Keenfish in forum Land Rover
    Last Post: 2009/09/01, 07:48 PM
