Results 1 to 10 of 10
    Exclamation Maintenance on a TD5 Disco 2
    I'm the new owner of a 1999 Disco 2 TD5 that just wants the best for his ride.
    What should I do, maintain, check, change on a regular basis to ensure that I and my Disco have many happy years together.
    PS: I'm not a technical, 4x4 boffin so keep it simple please
    I also mend to ask: How do you drive it correctly? I've been told never to drive in 5'th gear around town when your rpm might go below 2000. Never gun the engine over 3000 for long durations, etc.
    Thanks for everyone that's so willing to help out.
    Ruimsig
    Thanked: 46842
    Welcome.
    Regular oil and filter changes.
    Possibly change all coolant hoses now so you know that they are new
    PS: Neither are we
    Estee = S T = Sean Towlson, A Schrodingers Douche Bag GOF
    ''In Western society, it is not the facts or the truth that are important, but the correct presentation of information, even if it is a lie.''
    Clank, a 1979 Ex-SADF Series III 109 SW powered by a Toyota 2B Oil Burner
    Wuxi, China
    PS: Neither are we
    Very true, but you can go a long way with the RAVE manual
    fgrobler make sure you get one and you will be a boffin in no time.
    camelman
    I might be paranoid but it is a good idea to check or if neccesary replace all your major water hoses.
    Here is a list of what I would reccomend:
    - check dif oils, replace if dirty
    - check transfer case oil, replace if dirty
    - do gearbox service
    - replace engine oil & oil filters
    - replace air filter
    - replace brake fluid
    - check fanbelt & replace if in doubt
    - replace fanbelt tensioner pulley, if needed
    - replace diesel filter
    - grease propshaft
    It just depends what has been serviced recently, if you have a service record to check what has been done. Like I said I am paranoid
    2000 Pajero 3.5 Blister
    2002 Disco2 TD5
    Ruimsig
    Thanked: 46842
    Not paranoid Len, all of the above should be standard when buying a used vehicle, any vehicle for that matter. Good advice.
    Not only the RAVE but also this forum will assist in helping where possible. I have learned quite a bit since joining
    fgrobler, As a diesel is not a high revving engine it makes most of its power just above 2000rpm, so I would say just use common sense when driving and try keeping your RPM's on the lower side of 3000rpm .
    If you do rev it a bit harder do not do it for continuous periods, and also let it idle a bit before switching off the ignition after long drives, this will extend the life of your turbo.
    2002 Disco2 TD5
    Welcome to the Landy family! I'm also very non-technical (I work in-front of a computer all day) and I've also recently bought I disco 2 td5. The guy that sold me to me had it checked out before I got it, so I haven't done much myself to check it out yet. However, two things I would advise, check the water hoses as everyone suggests and then also check your u-joints/propshafts. Youtube has a couple of general how-to's u-joints, but its worth having this site in your bookmarks: www.discovery2.co.uk Detailed step-by-step instructions for quite a few DIY repairs are in there. Enjoy it!
    André Luus
    2000 Discovery II TD5 XS Auto (<del>Air springs</del> Second hand Coils, Dueler A/Ts) - Our first off-roader and loving it!
    Saving for: Madman EMS
    CT
    I know this sounds silly, but also check you have the right tools and your std jack is working. I bought my disco from a surposedly reputable dealer and only discovered the seels on the std jack were blown when I got a flat in the middle of the Karoo. Nothing like a long walk, with a p*ssed off wife and a screaming 2 year old waiting for you when you get back !
    As for checking it over, do yourself a favour and ask the guys on this forum for a good, local, landy specialist and spend a few bucks on getting them to give it a once over. As for servicing, this forum is full of guys who have been there, done that. Just ask, I continue to be amazed by the collective knowledge available here.
    As for driving, if you can afford it fit a "Madman" monitoriing system or equivalent. Not everyone seems to rate them, but my disco came with one and I am still amazed by how much higher the exhaust temp is on even a mild incline, into a head wind etc. This becomes really important if like me you are up and down the west coast - with a roofrack full and heading into the souther easter you are pushing against a significantly increased resistance. If yours is running std tyres etc, I expect you can happily cruise between 110-120 km/h under 3000 rpm. Not sure about anyone else, but I generally don't feel comfotable going faster especially when loaded up with the family on board.
    2011 Fortuner D4D 4x4
    2012 Mini-Metalian Trailer
    Wuxi, China
    Quote Originally Posted by silverspiders View Post
    The journey is the destination, why rush it
    camelman
  1. Discovery 2: Buying and running a Disco II (Td5)
    By Craigb in forum Land Rover
    Last Post: 2023/12/26, 07:58 PM
  2. Discovery 2: I just drove a Disco II td5..
    By petermoffat in forum Land Rover
    Last Post: 2010/01/19, 04:38 PM
  3. Disco TD5 in Def 110
    By Wollie in forum Land Rover
    Last Post: 2009/08/21, 08:46 AM
  4. Disco 2 Td5 Clutch Master cylinder
    By Janvz in forum Land Rover
    Last Post: 2008/04/14, 11:14 AM
  5. Disco TD5
    By Wielie in forum Land Rover
    Last Post: 2007/03/28, 11:56 AM
