Terios owners - Page 10
Page 10 of 116 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 35 60 110 ... LastLast
Results 181 to 200 of 2307
Thread: Terios owners
  1. #181
    Aug 2010
    Kempton park
    Probly a very stupid question, but maybe not, do you guys think/know if the the lift kit will definately make a big difference?
    Alex
    2012 Mitsibushi Triton
  2. #182
    Live : Bethal , Work : Saudi
    Thanked: 252
    On standard its 205 mm lift kit its 255 mm with better articulation
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
  3. #183
    Aug 2010
    Kempton park
    Weet jy watter info om voor te vra by diahatsu sodat ek die kompleet "lift kit" kan kry, dalk part nommers ens?
    Alex
  4. #184
    Thanked: 252
    Quote Originally Posted by jurgen10 View Post
    Maybe the guys who have fitted the coils and freeflow can confirm the part numbers, Daihatsu Centurion quoted the following:
    Freeflow - Full kit including branches = R4047
    Part number - 82170 BROSPTER And they do not sell the branches seperately.
    Offroad Coils - R513 Each
    Part no : 82170 RR SPR TER
    (But no-one according to their system has stock)
    Noise Boys Silverton - Freeflow exhaust only (50mm)= R1590
    Dink die is wat jy soek Alex
    One life Live it
  5. #185
    Aug 2010
    Kempton park
    Ek sien hy het net coils op, wat van die shocks?
    Thanx vir die info Petrus
    Alex
  6. #186
    Part numbers for coil springs and freeflow for those that need it:
    1. Coil springs rear - 82170-RRSPR-TER
    2. Coil spring front - 82710-FRSPR_TER
    3. Freeflow - 82710-BROSP-TER
    This is how it was stated on my invoice from Daihatsu. Hope this helps.
  7. #187
    Aug 2010
    Kempton park
    Shocks?
    Alex
  8. #188
    I did not replace rear shocks. Purpose of my lift kit was mostly to have the trailer more horizontal when hooked up. Will only replace with longer stretching shocks when due for replacement.
  9. #189
    Aug 2010
    Kempton park
    Did you still get your 52mm lift?
    Alex
  10. #190
    Aug 2010
    Kempton park
    4x4bedinges, whats your view on this, do you think it is neccessary to replace shocks as well?
    Alex
  11. #191
    Thanked: 252
    Alex I will do the shock for the fact that it has better articulation with the longer shocks , The standard shock does not extend as far as the coils can go.
    I will do the full kit It works the same as any other off road suspension.
    But if I understand adalwolf correctly he did the kit just for lifting the trailer and not off roading that much.
    One life Live it
  12. #192
    Aug 2010
    Kempton park
    Yip, thats how i understand it as well, yes, i thought of that as well Petrus, BUT, i have heard of a few drivers that just did the coils, no shocks....thats why i asked, still new to the lift game, for what type of shocks do i ask for?wont they need a length of size or something?i heard Procom is a good choice.
    Alex
  13. #193
    Thanked: 252
    I think Daihatsu has the shocks also (I'm not 100% sure) I haven't found the tipe of shock still has to have a look at that wish I could go the old man emu route on the tossie like my Defender
    One life Live it
  14. #194
    I got about 35mm of lift plus new tyres gave me about 10mm extra lift - total 45mm. All I wanted was to level trailer behind Terios. I am not doing heavy 4x4'ing but lift will help on some two track roads with high 'middel mannetjies'. Overall I think a big improvement for general all terrain use.
  15. #195
    Aug 2010
    Kempton park
    Bedinges, do you own a Defender as well, or is it the ex?
    Alex
  16. #196
    Feb 2007
    Thanked: 107
    Default terios owners
    Pro Comp ES 9000's is what you would need.....it will mean a harder ride if fitted in conjunction with new coils when empty but once you have loaded the Terios and you start doing some offroad...I mean real offroad, you will be very glad you did fit the shocks. Remember that the lack of low range means that sometimes you are forced to use momentum to clear obstacles i.e. hidden twisters in deep soft sand, twisters when doing some mountaineous terrain etc.
    my 2c worth
    Paul
  17. #197
    Thanked: 252
    Just sold my defender Alex
    Only have the tossie now
    One life Live it
  18. #198
    Thanked: 252
    Thanks for that info Paul
    One life Live it
  19. #199
    Aug 2010
    Kempton park
    Thanx a lot Paul....
    Alex
  20. #200
    Aug 2010
    Kempton park
    Sopas gelees dat die Procomp ES9000 shocks verskriklik hard is, dat party mense se dit is onplesierig om te bestuur...begin nou wonder...mmmmm
    Alex
  1. Triton owners unite!!!!
    By Die SwartKat in forum Mitsubishi
    Last Post: 2011/10/07, 04:17 PM
  2. Replies: 21
    Last Post: 2009/11/09, 05:16 PM
  3. Discovery 1 Disco 1996 Owners Manual
    By Die Hard in forum Land Rover
    Last Post: 2009/08/11, 09:47 AM
