Solar energy.....
Results 1 to 14 of 14
    Springs
    Default Solar energy.....
    Hi guys,
    I want to power my house by solar energy only, no municipal power.
    Has anyone out there done something simmilar or can anyone refer me
    to the specialists!
    Willie
    What is your plan?
    Will you be storing the energy in batteries for the night time?
    From what I understand it is prohibitively expensive.
    Godzilla - 1997 Range Rover 4.6 HSE
    Monty - 1972 Series 3 LWB (moved on)
    "Life's tough. It's even tougher if you're stupid."
    -John Wayne
    Springs
    I've heard of people actually living like that, (no municipal power)
    I need a lead in that direction (link or site)
    Oct 2006
    Pretoria (Rietvalleirand)
    Speak to Renzo at Bushpower (www.bushpower.co.za) He has quite a large installation at his house, although, if I remember correctly, he still uses some municipal power at times.
    Johan
    Pajero Gen 4 GLX 30 Year Heritage Edition - Grondpad
    VW Tiguan 2.0TDi - Teerpad
    Bushlapa Boabab 4.2 in tow
    Gaborone
    Speak to allan west at solar international in gaborone botswana , he is a helof a decent guy and really knows his stuff.
    Jun 2008
    how long you would have to be off the grid for in order to recoup your expenses? I wonder how much such a system would cost per kw/h
    just out of interest sake...
    Ironman Suspension
    40mm Body lift
    31x10.5x15 Cooper STTs
    Gaborone, Botswana
    What is the current "rand per watt" rate for solar panels?
    Kobus
    Nissan
    Ill check to make sure
    [email protected]
    +27824453301
    Suffolk, UK
    I would hang on for a couple of years if I were you. There are some big changes in the technology on the way which are going to make a big difference to the financial side of photovotaics........as well as to the embodied energy.
    Do you get The New Scientist in SA? If so, get the current edition, which has a big article on photovoltaics (as well as an article on grid-scale batteries, using molten metal for very efficient large-scale electricity storage). If you don't get it over there, then pester me enough and maybe I can scan it and post the articles on here.
    Mike
    "Mike for President" Freeflyd
    Sampie,
    The idea also appeals to me and I have given it a little bit of thought. Obviously there are people who do this commercially and know much more than me but here are my ideas completed in the following steps:
    1. Solar hot water heating is a must and preferably you should not use any electricity, with a bit of a lifestyle change it is possible, such as taking hot showers in the evenings and a colder morning shower to wake you up. Some modern solar heating system will be better but you will get some cold morning showers in winter.
    2. Convert all lighting to LED systems there are websites that sell these. I personally would consider converting the light circuits in my house to 12 or 24 volts and run the light off batteries removing the need for inverters. These batteries would be charged by solar panels. Also remember that the existing lighting circuits in your house are only rated to something like 16amps so you will need to be careful to use very economical LED bulbs.
    3. Heating of your house would need to be done by wood or gas fireplace, I have seen houses in the UK where wood burning stoves heat water that heats the house in winter, these can add a lot of atmosphere to a house but are not very popular in SA. They can also be used for cooking and boiling the kettle.
    4. Your plug circuits will need to run on 220 volt AC current and would need to be powered by an inverter. I am no expert but I would guess a 5000W inverter should power your plugs if you are carful to make sure not all your appliances are running at the same time. Not all inverters are created equal, you will need one that creates a true SIN wave as some of your appliances will not like the way most inverters produce AC current. Other members of the forum should be able to explain the difference as have only a little knowledge on the subject.
    5. Final step would be to give Eskom the finger. I would love to tell them to cut me off and watch all the neighbours lights go out during load shedding periods while I was unaffected.
    Good Luck, let us know what you do.
    -John Wayne
    Modimolle (Nylstroom)
    Sampie,
    As jy goeie inligting wil he wat by offroader aan haak, skakel vir Mauritz Perold by Safreleck in Midrand (0790135617). Hulle is in die proses om ons hele plaas en onwikkeing van die eskom grid af te haal met wind en solar krag. Jy is meer as welkom om my ook te bel (0797117195) en te kom kyk wat hulle hier by ons gaan doen in Nylstroom. Ps...my modder gat is nou nog lekkerder vir vas sit!!
    Groete
    Nico van Hulst
    www.kolobebushretreat.co.za The only place to live!!!!!!!!!
    ,2013 VW Amarok Bi TDI, 4Motion 8-Speed Auto, Seikel snorkel, Warn winch, replacement bumper, Seikel Field & Forest Suspension and speedo cruise for low range!!!!
    2005 Navara double cab 4x2 - Swambo Platkar
    Jul 2007
    Vishoek
    Wink
    Kobus, die laaste prys wat ek kon kry is so by die R25 p/w
    Quote Originally Posted by kolobejnr View Post
    Sampie,
    Groete
    My vrek Nico, gewonder of julle nog lewe daar in Nylstroom. As die setup klaar is wil ek ook kom loer.
    Jan 2007
    Eindhoven
    My FIL is in the business. Prohibitivly expensive to go totally solar. He currently does a solution for some lodges and farmers that combines solar with gas/petrol or diesel gensets. Delivers 3Kw. As soon as load goes above 2 kw the gen starts and supplys power. Batteries drop below pre defined level of charge it starts the gen to charge batteries etc. All different programmable options. Still veeeerrryyy expensive. Only worthwhile if you compare to initial ESCOM installation. So if you have a farm that doesn't have Escom and it is going to cost you a lot of money for the connection then it would be worthwhile looking at such a hybrid option. Full solar to give you between 1 and 5kw peak with an autonomy for a few days without solar is beyond scope of most mortals. Rather look at reducing your electrical requirements by using alternative water heating and cooking and use the solar for low energy lighting at night. etc Don't try to replace your current Escom connection with solar. You will never recover your capital cost.
    Deon Viljoen
    Boyscout
    2012 Land Rover Defender 90 2.2 Tdci S/W Sold
    2005 D2 XS TD5 Auto sold at 189000km
    2003 D2 GS TD5 Auto sold at 165000km
    1999 D2 GS V8 Auto sold at 178000km
    Boyscout, I agree prohibitively expensive.
    But giving two fingers up to Eskom Priceless.
    -John Wayne
  1. Converting to solar water heating: My own DIY project
    By O.B. in forum Camping, Fridges, Accessories
    Last Post: 2018/05/05, 01:07 PM
  2. DANGER! energy absorbed on snatching!
    By Engel in forum 4x4 Recovery & Recovery Gear
    Last Post: 2018/03/22, 06:24 AM
  3. Solar panel conundrum - Power in the Bush
    By Oceans247 in forum Camping, Fridges, Accessories
    Last Post: 2016/04/26, 03:17 PM
  4. Solar regulator as "DCtoDC" charger
    By IF in forum Camping, Fridges, Accessories
    Last Post: 2010/03/01, 08:50 PM
  5. 3rd battery, generator or solar panel?
    By Carl S in forum Camping, Fridges, Accessories
    Last Post: 2009/10/18, 10:52 PM
