ABS High pressure pump repair.
Results 1 to 3 of 3
    Default ABS High pressure pump repair.
    On Monday my wife phone hysterically the pajero is squeaking the ABS light and the one next to it is on and there’s no brakes.
    Fortunately my brother visited Monday afternoon and we started diagnosing the problem.
    We established that the pumps not running and the necessary 12v is present.
    The most difficult part of removing the pump motor is to get the two 5mm Allen keys retaining the mounting out.
    With the motor on the bench and stripped we found that one of the copper pads on the armature slip ring was off.
    With the armature repaired I assembled it last night and all is well.
    Obviously the difficult part was refitting the rubber mounting.
ID:	54966   Click image for larger version.
ID:	54967   Click image for larger version.
ID:	54968   Click image for larger version.
ID:	54969   Click image for larger version.
ID:	54970   Click image for larger version.
ID:	54971   Click image for larger version.
ID:	54972   Click image for larger version.
ID:	54974   Click image for larger version.
    1999 Subaru Forester 2.0S Turbo it’s got a turbo so it must be good 8)
    2000 Alfa GTV 3.2
    1998 Alfa GTV v6 Turbo
    Barberton
    Thanked: 1687
    Thank you so much.
    So your only cost was to have the armature repaired?
    Yes.
    If you do it like i did it will be +/- R700.00
    R1500.00 is what it will cost at the shop "Turbonutters" in pretoria.
    2000 Alfa GTV 3.2
    By charlatan in forum Jeep
  2. Grand Cherokee Error code
    By Nick47 in forum Jeep
  3. Defender 300 Tdi oil pressure very high
    By O.B. in forum Land Rover
    Last Post: 2010/02/12, 03:46 PM
  4. High pressure pump advice
    By Thirstie in forum General 4x4 Discussion
    Last Post: 2009/04/21, 01:47 AM
  5. Diving at altitude?
    By Biggles in forum Scuba Diving
    Last Post: 2008/08/25, 03:14 PM
